    Hide Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree7Likes
Old 08-02-2014, 05:53 PM   #6511
Trader Rating: 137 (100%+)
Originally Posted by Wild Cherry View Post
JP
Ck front tire
Brand new front tires lack steering until they are scuffed in.
If tires are ok
Move battery forward a little.
In your best guesstimation how long would you think this takes? tires seem to take a long time to break in there. How could one speed up this process?
jpcopeland1 is offline   Reply With Quote
Old 08-02-2014, 05:54 PM   #6512
Alloy mounts are stronger & offer more tuning options.
add lead ballast or use saddle packs for more weight.
Let us know how it worked out.
Doh! no saddles or ballast weight. I know I should not have sold that saddle pack I had lol... I also see where a lot of the team guys are running the aluminum camber mount low. Is that just a matter of flipping it and adding the 3mm of washers? Sorry to be a bug, but it was a handful today.
Old 08-02-2014, 06:12 PM   #6513
Wildcat1971's Avatar
Trader Rating: 80 (100%+)
Originally Posted by jpcopeland1 View Post
My brother and I made the jump to these cars. He races stock, I race stock and mod. Were at LRH today, pretty damp, but still I would say high bite. Running typos both of our cars pushed like mad, mod car so bad it slammed into the wall a few times, like I had no side bite at all. Car also seems to be very light in the front and rear. Running a standard sized shorty, all the way back, standard sized servo, as stated typos (clay compound), B5 front arms and tower (both cars), 2X1.6 pistons with 32 1/2 front, 30 rear. My setup is just not working very well at all. Any thoughts? I have all of the aluminum stuff for it, but have not put it on yet. Car felt like it was skating through the turns and not carving them like my other mid-motor cars have in the past.
are you running the Rm rear arms also? the car is very heavy. should not need a lot of weight even for mod. I dont know your track, but tires here need a certain amount of wear. Seem like the tires need to be ghost pins. I was also told to shave off the outer edges of my rear tires for side bit. Most of the mod guys here run clay slicks as well. Even some stock guys. So maybe we have more traction than you.
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 08-02-2014, 06:35 PM   #6514
TOO-TALL's Avatar
A new modification has surfaced.
Raising the rear roll center by shimming the rear arm mount 1mm.
Have to grind 1mm off bottom of shock tower as well.
Makes for more roll & less grip I believe. Free's up the rear end for improved handling.
Intresting....wont this change the anti-squat also?
www.skyski.com
www.foilforum.com
"Hey Baby want to make fourteen dollars...the hard way??" ----Rodney Dangerfield--Caddyshack.
TOO-TALL is offline   Reply With Quote
Old 08-02-2014, 06:56 PM   #6515
Cridd's Avatar
Trader Rating: 16 (100%+)
Try raising your roll center to get the car to come around.
Chris
B6D / T5M / SC5M
Cridd is offline   Reply With Quote
Old 08-02-2014, 07:03 PM   #6516
Tech Legend
Wild Cherry's Avatar
does not effect the squat , both blocks get raised 1 mm.
Only try if your interested in less traction & wish to free up the car .
Any driver can copy a great set up, a Champion however will steal it .
If Jesus returned as a Rc car he be a Rc10 B5M
George W. Cherry
Wild Cherry is offline   Reply With Quote
Old 08-02-2014, 07:20 PM   #6517
wayboarder's Avatar
Trader Rating: 14 (100%+)
Thumbs down
Definitely not new. Guy with a 3d printer has been making 1mm offset pills in SoCal for quite some time now. Can go up or down with them. He makes Schelle slipper eliminators too as well as other things for b5's. Welcome to the party. I'm sure it'll take off just as well as the inline electronics setup has.
Oh what's that I see? Spencer rivkin with a lightened chassis? Hmmmm so much for needing those lead plates.
wayboarder is offline   Reply With Quote
Old 08-02-2014, 07:37 PM   #6518
TOO-TALL's Avatar
aahh....both blocks.that makes since
www.skyski.com
www.foilforum.com
Old 08-02-2014, 07:58 PM   #6519
Tech Legend
wayboarder
Get with it !
was using raised blocks with my B2
20 years ago...
George W. Cherry
Old 08-02-2014, 08:07 PM   #6520
suby723's Avatar
Trader Rating: 21 (100%+)
The inline setup is an absolute joke! Thats the worst setup to run on the car. Its funny how only 1 post wh0re thinks its the best ever and adding weight blah blah blah.. i have yet to see an actual legit ae driven run that setup.
Btw was Spencer running an ae lightened chassis or stock milled out? Im running slrc lightened chassis on my stock car and its unbelievably dialed.
suby723 is offline   Reply With Quote
Old 08-02-2014, 08:41 PM   #6521
Trader Rating: 29 (100%+)
where can i buy a Schelle slipper eliminators?
thanks
ronzo is offline   Reply With Quote
Old 08-02-2014, 10:01 PM   #6522
Tech Legend
Oman
Cali still has no answer for the Tacompton ???
Ha Ha Ha
George W. Cherry
Old 08-02-2014, 10:50 PM   #6523
Cridd's Avatar
I think the inline has some potential, just don't have the time to dremel up my car and test.
Chris
B6D / T5M / SC5M
Old 08-02-2014, 10:54 PM   #6524
Tech Legend
Cribb my boys are'nt allowed to use it.
They talk about E mail for permission.
Just saying..
George W. Cherry
Old 08-02-2014, 10:59 PM   #6525
ryanpatrickgore's Avatar
Trader Rating: 14 (94%+)
I've driven both inline and stock battery configurations back to back Thursday night , same battery same setup essentially.. Stock setup would stall out and was a bit slower turning. I prefer the inline.
When I had my rb6's... I preferred inline as well
ryanpatrickgore is offline   Reply With Quote
