    Hide Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree6Likes
Old 07-23-2014, 05:33 PM   #6256
Tech Legend
Wild Cherry's Avatar
Black label
Just for you...
If you need more detail about inline battery set up feel free to ask..
[/QUOTE]
Any driver can copy a great set up, a Champion however will steal it .
If Jesus returned as a Rc car he be a Rc10 B5M
George W. Cherry
Wild Cherry is offline   Reply With Quote
Old 07-23-2014, 05:37 PM   #6257
vito's Avatar
I did a no no pick up a used 410 v 3 4x4
the happy racer
drango 410 v 4
am dyslexic
b5 mid motor
vito is offline   Reply With Quote
Old 07-23-2014, 07:00 PM   #6258
TOO-TALL's Avatar
If I install the ft blue rear hubs do I need to put a 2mm (or any washer)washer under the ball stud?
TOO-TALL is offline   Reply With Quote
Old 07-23-2014, 07:11 PM   #6259
Wildcat1971's Avatar
Trader Rating: 80 (100%+)
I think the hubs are stock 1mm below the lowest plastic hub setting. The sponsored guys have been running 3mm of washers in most setups.
Question. Brent posted his setup. he is doing 3mm on the inside rear camber link with it flipped to the low position... That is the same is it mounted high and 1mm washer right? so why are him, rivkin and others doing it that way?
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 07-23-2014, 07:20 PM   #6260
TOO-TALL's Avatar
So if I want more on power traction exiting corners I lower the ball stud at the shock tower......did I read that right in the back of the manual.
Maybe those guys are running on very high bit tracks.
Old 07-23-2014, 07:36 PM   #6261
skrichter's Avatar
Send a message via AIM to skrichter
[QUOTE=Wild Cherry;13420701]
I have yet to see/find a good setup for inline.
LiveRC.com | Dirt Heaven Hobby & Raceway
skrichter is offline   Reply With Quote
Old 07-23-2014, 07:56 PM   #6262
Super Moderator
Trader Rating: 17 (100%+)
do you really have that much grip that you have to slam the weight forward for more steering?
Tekno|JConcepts|ProTek|Amain|VRP|BOOMrc
Bob Barry is offline   Reply With Quote
Old 07-23-2014, 10:37 PM   #6263
Tech Legend
[QUOTE=skrichter
I have yet to see/find a good setup for inline.[/QUOTE]
only difference is the inline can change directions easier .
setup is no different from using the battery normal.
The traction is equal to running the pack in rear standard kit fashion.
The ESC mounted under the motor guard helps make more weight on the rear.
Then you get to ditch all that motor wire for less weight forward & above the battery.
I drive other B5 normal all the time and it always my ride drives better, more consistent,no stall in slower sharp corners ECT.
George W. Cherry
Old 07-23-2014, 10:44 PM   #6264
Tech Legend
Your the one running the Esc up front correct. ?
Not more steering, very smooth...
o my bob just learned something hopefully..
George W. Cherry
Old 07-23-2014, 11:17 PM   #6265
Tech Legend
were using 3mm, make sure your using a 8mm ball stud
George W. Cherry
Old 07-24-2014, 01:25 AM   #6266
racer_guy's Avatar
lookin for some help here fellaz. so today i put on the turnbuckles. ive read on this thread that the ft turnbuckles bind....mine move fairly free. there is however some stiffness in the steering. it moved butter before. im thinking its the red o-ring rubbing on the cups...anybody have this? also the front arm travel up/down is a tad on the stiff side. need to just be broken in? like i said i can rotate the turnbuckles fairly easy. thanks in advance.
W.E.D. Winning Edge Designs
racer_guy is offline   Reply With Quote
Old 07-24-2014, 04:00 AM   #6267
mxracer458's Avatar
Trader Rating: 47 (100%+)
for you guys that run 13.5 what gearing you running? i run on a fairly large indoor track
mxracer458 is offline   Reply With Quote
Old 07-24-2014, 06:30 AM   #6268
I am running 29/72 with 30 deg timing on my reedy.
Old 07-24-2014, 07:28 AM   #6269
Rybeau40's Avatar
What speed does everyone run their servo at on the controller? i have mine down to 55 because it gets too twitchy any higher. I run a Futaba 4pls.
Kyosho Lazer ZX-6R 10.1 Orion pro, Spektrum 6040
Team Associated B5M, Hitec servo Mod class, 10.0 Orion
Futaba 4PLS
Support your LHS.
Sponsored by my wife who gives me no grief
Rybeau40 is offline   Reply With Quote
Old 07-24-2014, 07:41 AM   #6270
I never limit my servo speed. I run .06ms speed servos. I hate to limit myself, I prefer to get better with my trigger and steering.
