    Hide Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree7Likes
Old 07-17-2014, 09:51 AM   #6076
Wildcat1971's Avatar
Trader Rating: 80 (100%+)
Originally Posted by 3srcracing View Post
Most lightweight shorties you will have a hard time finding 5mm, however Protek carries a 3200 shorty that only weighs 155grams when they usually weight 200+grams.
Check it out:
http://www.amain.com/product_info.ph...ts-74V-3200mAh
I would get this one, since they are the same battery and the 100c rating on the protek is fictional.
http://www.promatchracing.com/prodde...prod=2S350090C
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 07-17-2014, 10:01 AM   #6077
Trader Rating: 20 (100%+)
I just bit the bullet, and ordered a Trinity Titanium XL shorty w/4mm. My B5m is my only car with the 5mm connector, so I may use another ESC for stock.
GTSSTANG is offline   Reply With Quote
Old 07-17-2014, 10:12 AM   #6078
skrichter's Avatar
Send a message via AIM to skrichter
Anyone else seem to notice, what appears to be a cut rear motor guard on Cav's B5M? Look closely, and you will see it.
Rivkin's B5M is missing the screws in the motor guard as well.
LiveRC.com | Dirt Heaven Hobby & Raceway
skrichter is offline   Reply With Quote
Old 07-17-2014, 10:15 AM   #6079
Why do that? Flex?
Old 07-17-2014, 10:24 AM   #6080
Scratch that.
Old 07-17-2014, 11:22 AM   #6081
lbckevin's Avatar
Trader Rating: 89 (99%+)
Yes for flex....a lot of creative ideas
Kevin Smith
Hobbywing * Pro-Line * MIP * Paint Monster
lbckevin is offline   Reply With Quote
Old 07-17-2014, 11:25 AM   #6082
Yes, on the 22 platform people running carpet in mid config are loosening the bottom screws of the waterfall to gain flex...
B5M
22 2.0
B44.2
TC4
SC10 4x4
Pellefa is offline   Reply With Quote
Old 07-17-2014, 11:34 AM   #6083
Tech Legend
Wild Cherry's Avatar
$5 says the battery brace has been Dremal away..
Whoops
Scratch that ..
Did not check out both images..
Any driver can copy a great set up, a Champion however will steal it .
If Jesus returned as a Rc car he be a Rc10 B5M
George W. Cherry
Wild Cherry is offline   Reply With Quote
Old 07-17-2014, 02:05 PM   #6084
vito's Avatar
I got a new wing mount from a main its a tad tall then my rear wing mount is this the updated one?
the happy racer
drango 410 v 4
am dyslexic
b5 mid motor
vito is offline   Reply With Quote
Old 07-17-2014, 04:19 PM   #6085
bilster44's Avatar
Originally Posted by GTSSTANG View Post
What is the preferred pad setup to go with the Avid slipper used in 17.5?
White/red/white for those conditions.
"Let Your Racing Speak"
bilster44 is offline   Reply With Quote
Old 07-17-2014, 04:27 PM   #6086
bilster44's Avatar
Originally Posted by Wildcat1971 View Post
Why do that? Flex?
I just do this to mine for a wee bit of flex and cooling
Old 07-17-2014, 04:30 PM   #6087
Shark413's Avatar
Trader Rating: 24 (100%+)
We probably won't see a 5mm bullet connector light weight 2s, because the 5mm setup weighs a little more.
The 4mm/5mm bullet is probably the best compromise if running the two battery types., but I am not too sure about that extra 5mm being exposed on 4mm.
The 4/5mm bullet combo connector weights more too. I was running them but decided to remove them and go with straight 4mm bullets on my B5M and save the 5mm shorty packs for my SC truck. Also the 4/5mm combo plug sticks out and causes fitment issues with the body, and as you mentioned can short if the exposed ends touches something conductive.
AE B5M - Tekno SCT410 - Kyosho SC6, SCR & RB6 - HB D413
SCVRC - Santa Clarita Valley RC & HotRod Hobbies
Shark413 is offline   Reply With Quote
Old 07-17-2014, 04:53 PM   #6088
vito's Avatar
wc did I get the right one?
the happy racer
drango 410 v 4
am dyslexic
b5 mid motor
Old 07-17-2014, 05:17 PM   #6089
Originally Posted by hcopp View Post
ended up ordering 3 sets of ceramic balls from acer racing - $6.99 for 14. can't beat that.
With all of this diff talk.... the outdrives should be totally fine, right? not really a way those can get damaged except on the outside of em?
Definitely the right price. Hope they perform as my rebuild with ceramics is now complete. Had to do it twice because I did not clean parts 100%. My guess is that folks who are having issues rebuilding ball diffs are not aware that all parts have to be perfectly clean. The least bit of contaminate will bugger the whole rebuild. Motor sprayed and compressed air all parts and broke in with my drill motor. Smooth as butter and ready to roll. I purchased ceramics from local racer who does not care for ceramics. So far, I am totally pleased. Will try to post after several races to update on wear.
Micah123 is offline   Reply With Quote
Old 07-17-2014, 06:10 PM   #6090
Just rebuilt my diff as well. Did the lift test and could finally hear the slipper slip though I did get a the slightest bit of chirp and then just stopped. The schelle slipper is coming tomorrow so I am going to wait to do any more tooling around. The diff rebuild went well. and I made sure to put it on the tight side for the slipper testing. I dunno if I am just giving it too much gas. running 79/21 (i think) and a lot of boost on my esc I'm wondering if its simply just too much power for the lift test and am in fact blowing it out. regardless... one small chirp won't kill anything (if you say it does I think ill live for a few runs and then do another rebuild, and i tightened it about 1/8 turn after that. who knows maybe I'm not exactly sure what the chirp actually sounds like.
Thanks for everyone's help as always. You guys are a great resource and have taught me a ton in the last few weeks. Always appreciated.
hcopp is offline   Reply With Quote
