    Hide Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree7Likes
Old 07-16-2014, 10:31 PM   #6061
Shark413's Avatar
Trader Rating: 24 (100%+)
I have a quick question, when I was building the rear drive shafts the bag had four pins. Two were for the CVD and two were for the axle/wheel hexes. My question is are they the same size? I couldn't see any difference between the four pins (I measured with calipers) but in the manual they have two different parts numbers.
AE B5M - Tekno SCT410 - Kyosho SC6, SCR & RB6 - HB D413
SCVRC - Santa Clarita Valley RC & HotRod Hobbies
Shark413 is offline   Reply With Quote
Old 07-17-2014, 06:05 AM   #6062
Speed Freak RC's Avatar
I found the same thing. I believe they are the same, and the manual shows different part numbers because of the CVD rebuild kit vs just the pins.
Speed Freak RC is offline   Reply With Quote
Old 07-17-2014, 06:43 AM   #6063
Originally Posted by hcopp View Post
ended up ordering 3 sets of ceramic balls from acer racing - $6.99 for 14. can't beat that.
With all of this diff talk.... the outdrives should be totally fine, right? not really a way those can get damaged except on the outside of em?
outdrives wear where bone connect to them. replace them when you see the outdrives have grooves gouged in them from wear. if worn badly, use a dremmel to grind off burrs to remove bearings.
Micah123 is offline   Reply With Quote
Old 07-17-2014, 07:02 AM   #6064
I've heard mixed reviews on the schelle/ avid vs stock slipper. Some say the stock is way better....Thoughts?
hcopp is offline   Reply With Quote
Old 07-17-2014, 07:17 AM   #6065
Wildcat1971's Avatar
Trader Rating: 80 (100%+)
stock is way better? That is complete bull sh@t. The schelle and avid are the same slipper. And both are 100 times better than the stock.
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 07-17-2014, 07:26 AM   #6066
Tech Legend
Wild Cherry's Avatar
If you use the Avid or Schelle ?
Use white pad on the back of spur & 2 red pads on the outside.
What's difference in performance between the three slippers
VTS
Very smooth, great slipper for lower traction.
Avid or Schelle
Smooth , hits a little harder then the VTS.
Vented twin yellow pads
I feel is the best.
Has great feel with lighter throttle or making smaller jumps.
Any driver can copy a great set up, a Champion however will steal it .
If Jesus returned as a Rc car he be a Rc10 B5M
George W. Cherry
Wild Cherry is offline   Reply With Quote
Old 07-17-2014, 08:59 AM   #6067
bilster44's Avatar
[QUOTE
[/QUOTE]Uh, this would REALLY depend on what class you are running, and what surface you are running on.
"Let Your Racing Speak"
bilster44 is offline   Reply With Quote
Old 07-17-2014, 09:15 AM   #6068
Trader Rating: 20 (100%+)
I was actually just about to order an Avid slipper. What is the preferred pad setup to go with the Avid slipper used in 17.5? Will be running on medium to high bite indoor clay (and carpet in the future)?
GTSSTANG is offline   Reply With Quote
Old 07-17-2014, 09:19 AM   #6069
I use 3 whites in stock. I add a red for mod. If you are ordering from avid, get the custom kit and the spurs you want. white/red/white will hit a little harder. white/white/white is a little smoother.
Old 07-17-2014, 09:21 AM   #6070
Thanks.
Old 07-17-2014, 09:23 AM   #6071
Does anyone know of any light weight shorty lipos that use a 5mm bullet connector?
Old 07-17-2014, 09:25 AM   #6072
if you find one let me know, lol. All I can find is 4mm. Right now all 3 cars are wires for 5mm. But TQ racing has bullets that are 4 and 5mm.
http://www.ebay.com/itm/like/291186035565?lpid=82
Old 07-17-2014, 09:37 AM   #6073
We probably won't see a 5mm bullet connector light weight 2s, because the 5mm setup weighs a little more.
The 4mm/5mm bullet is probably the best compromise if running the two battery types., but I am not too sure about that extra 5mm being exposed on 4mm.
Old 07-17-2014, 09:49 AM   #6074
yeah, that was my concern also. I was thinking more so for the charge leads.
Old 07-17-2014, 09:49 AM   #6075
3srcracing's Avatar
Trader Rating: 25 (100%+)
Most lightweight shorties you will have a hard time finding 5mm, however Protek carries a 3200 shorty that only weighs 155grams when they usually weight 200+grams.
Check it out:
http://www.amain.com/product_info.ph...ts-74V-3200mAh
Also on another note, how many MAH do you think you need for a 10 minute main?
3srcracing is offline   Reply With Quote
