    Hide Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree9Likes
Old 07-15-2014, 10:06 AM   #5986
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
Originally Posted by hcopp View Post
Thanks for the info,
Question about the lift test. You mean hold the rear wheels and give it power right? Do you give it content power or just pull it quickly? When my slipper was set to stock (nut flush with end of top shaft) I could pull the throttle and the car would raise all the way up and stay there....
the stock slipper is crap. It is way too strong and heavy for stock racing. I hold the trigger for 1-2 seconds. Not very long. I am not looking to kill the pads. If your wanting to run the AE spurs, just get the FT vented slipper pads and goto a 2 pad system for 17.5. Most people goto the avid/schelle slipper. I did. I tried the 2 pad and the vts and didnt like either.
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 07-15-2014, 10:10 AM   #5987
Roger that. Ive been looking at the schelle for the next upgrade. Any preference vs that and the avid?
I suspect it is the diff then, since I rebuilt it and it is noticeably looser than it was before, but following the guide at the top I thought I had it honed in. Ill adjust tonight. Thanks for all the help, greatly appreciated!
hcopp is offline   Reply With Quote
Old 07-15-2014, 10:21 AM   #5988
Shark413's Avatar
Trader Rating: 24 (100%+)
Originally Posted by Wildcat1971 View Post
hmm, I dont get it. Even if I got the alum screw kit, its not 60 grams of less weight. Maybe there is lead in my tires, lol. I was comparing tires last night. some of mine are 6-8 grams each per tire........Wait....are you running chassis tape? I am and its probably 15-20 grams alone.
Yeah that does sound kind of light, I will put it back on the scales and double check.
Here it is on the scale right after I finished building it.
AE B5M - Tekno SCT410 - Kyosho SC6, SCR & RB6 - HB D413
SCVRC - Santa Clarita Valley RC & HotRod Hobbies
Shark413 is offline   Reply With Quote
Old 07-15-2014, 10:26 AM   #5989
Suspended
Dont let WC trick you, he loves the #2 hole
Only after a few beers
Pimp Formally Known as OG
PFKAOG is offline   Reply With Quote
Old 07-15-2014, 10:45 AM   #5990
Honestly, aside from the spurs, the avid and the schelle are the same. You can order custom kits from AVID wit the spurs you want. I.E. 2x 69 tooth spurs. The schelle comes wit ha 72 and 76 for stock. At least that is what the website says. I run the AVID Triad in mine. Both have been updated for the B5 series. Personally, I would rather order the custom Avid kit with 2x 69 tooth spurs, since that are the most useful to me. The 75 is not overly usefull IMO.
Old 07-15-2014, 10:47 AM   #5991
I am sure you were correct. Are you running a chassis protector?
Old 07-15-2014, 11:18 AM   #5992
Super Moderator
Trader Rating: 17 (100%+)
this wins the internet
Tekno|JConcepts|ProTek|Amain|VRP|BOOMrc
Bob Barry is offline   Reply With Quote
Old 07-15-2014, 11:25 AM   #5993
BIGSKI15's Avatar
Trader Rating: 18 (100%+)
The 2 hole with 3mm spacing is equivalent to the plastic hub using he upper middle hole.
Originally Posted by Wild Cherry View Post
Have no clue what the #2 hole is sorry, suggesting the location because it's where most of the team has been using.
Me too..
Its longer then the camber setup with the plastic hub & middle camber location.
B6D
B5M
Airtronics M12
BIGSKI15 is offline   Reply With Quote
Old 07-15-2014, 11:35 AM   #5994
Shark413's Avatar
Wildcat, when I weighted it I did not have a protector on it but I do have one that I plan on adding. I am currently running the VTS slipper, but I have a Schelle slipper coming, so hopefully that will offset some of the weight of the protector.
Old 07-15-2014, 11:42 AM   #5995
lol, seriously? That weight was with the vts? wtf am I 1594?
My protek 130ss is 63.8g
The Savox LP is 44.5g, so about 20g less. That is fine. but we are 90 grams apart and I removed the battery strap and foams, lol. That was 20 grams...You saved 20g with the pucks, so that is 40g difference. where the heck is the other 50g, lol. I even have the lighter tq13 awg wire instead of the heavier 12awg wire. my pack is 212g. yours is what 200g?
Old 07-15-2014, 11:44 AM   #5996
Shark413's Avatar
I run shorty packs in my two buggies and SC trucks, so I have a good selection to choose from to get the weight that works the best for my setup/track. Most of them weight between 200-210 grams with the Promatch 3500mah being the lightest at around 155 grams and the RevTech being heaviest at 210 grams.
Losi Xceleron, ProMatch 4800 and 3500mah, Turnigy 4.2, RevTech 5000mah, Venom 3800mah.
Old 07-15-2014, 11:49 AM   #5997
I am using the promatch 4800's in your pic. I weighted them at 212 on my scale.
Old 07-15-2014, 11:51 AM   #5998
Trader Rating: 59 (100%+)
tires can weigh up to 30 grams more than other tires... super soft compound is considerably heavier than clay compound
i'd be surprised if the aluminum screw don't drop it close to 40 grams.
rc23 is offline   Reply With Quote
Old 07-15-2014, 11:53 AM   #5999
hmm, I have some typo clay and SS at home. I will compare later. I knew SS was heavier than Soft, but never really used clay before. The "new" srs might become a clay tire track. Still seems too new to tell. If I could get to 1550-60 without having to change out my electronics or buy pucks, that would be nice
Old 07-15-2014, 11:55 AM   #6000
Tech Legend
Wild Cherry's Avatar
Cool
Attachment 1215089
Thanks , my hubs did'nt include the diagram.
Any driver can copy a great set up, a Champion however will steal it .
If Jesus returned as a Rc car he be a Rc10 B5M
George W. Cherry
Wild Cherry is offline   Reply With Quote
