    Hide Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree9Likes
Old 07-14-2014, 09:37 PM   #5971
Shark413's Avatar
Trader Rating: 24 (100%+)
My buggy weights 1509g RTR. Schurr Speed 17.5, MIP pucks, aluminum top shaft, Savox 1251 low profile servo, aluminum screws, venom 3800mah shorty, 13awg wire, Tekin RS Gen2, Dirtwebs, MIP Bypass pistons, Jconcepts links, everything else stock.
Hot Bodies? I messed up the paint job and needed a big sticker to cover it. I didn't want to waste the AE stickers.
AE B5M - Tekno SCT410 - Kyosho SC6, SCR & RB6 - HB D413
SCVRC - Santa Clarita Valley RC & HotRod Hobbies
Shark413 is offline   Reply With Quote
Old 07-14-2014, 09:41 PM   #5972
steelers82's Avatar
anybody know which way to install the FT alum rear hubs, as far as which is left and right? does the 0 degree thats painted on them go towards the front of the car or rear?
John 3:16 " For God so loved the world that he gave his one and only son,that whoever believes in him shall not perish but have eternal life"
steelers82 is offline   Reply With Quote
Old 07-14-2014, 09:46 PM   #5973
aeRayls's Avatar
To the rear.
The "0" faces the shock on either car.
Team Associated~Reedy~LRP~XP Digital~JConcepts~92zero Designs~Big Horn Designs~
Go that way really fast... if something gets in your way... TURN!
aeRayls is offline   Reply With Quote
Old 07-14-2014, 10:17 PM   #5974
Would like to hear how lighter buggy is handling compared to heavier buggy. Currently am at 1552g and am considering a 3500 smc battery that would put me under 1500g. Am concerned that a lighter battery may negatively effect the handling of a mm buggy.
Micah123 is offline   Reply With Quote
Old 07-14-2014, 10:28 PM   #5975
Tech Legend
Wild Cherry's Avatar
suggesting
Use 8mm ball stud #91048
Use the rear outside hole for stud & 3 mm under stud
Only slightly snub grub screw on hub
blue Lock Tight on grub & stud
Any driver can copy a great set up, a Champion however will steal it .
If Jesus returned as a Rc car he be a Rc10 B5M
George W. Cherry
Wild Cherry is offline   Reply With Quote
Old 07-14-2014, 10:48 PM   #5976
Shark413's Avatar
One other thing, all the fast guys at my track that run B5M's all said to switch to the B5 RM arms front and rear.
Old 07-15-2014, 12:06 AM   #5977
joykiller44's Avatar
What shock pistons do you guys recommend 3x1.4 or 2x1.6 in the front shocks and what oil? On b5m
joykiller44 is offline   Reply With Quote
Old 07-15-2014, 05:48 AM   #5978
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
hmm, I dont get it. Even if I got the alum screw kit, its not 60 grams of less weight. Maybe there is lead in my tires, lol. I was comparing tires last night. some of mine are 6-8 grams each per tire........Wait....are you running chassis tape? I am and its probably 15-20 grams alone.
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 07-15-2014, 07:44 AM   #5979
BIGSKI15's Avatar
Trader Rating: 18 (100%+)
Just installed these and used the number two hole. Why do you suggest the rear outside hole? What will improve?
Originally Posted by Wild Cherry View Post
suggesting
B6D
B5M
Airtronics M12
BIGSKI15 is offline   Reply With Quote
Old 07-15-2014, 07:52 AM   #5980
try it youll like it !
Solo1 is offline   Reply With Quote
Old 07-15-2014, 07:59 AM   #5981
Tech Legend
Have no clue what the #2 hole is sorry, suggesting the location because it's where most of the team has been using.
Me too..
Its longer then the camber setup with the plastic hub & middle camber location.
George W. Cherry
Old 07-15-2014, 08:08 AM   #5982
Me too..
Dont let WC trick you, he loves the #2 hole
Old 07-15-2014, 08:26 AM   #5983
Forgot to mention -
After rebuilding my tranny the other day and driving for about a half hour the car started to make a really high pitched whining noise when I would hit the throttle. Definitely sounded like the slipper, but personally I think I overtightened it a bit yet it sounded loose. Unless I am mistaken on how a loose slipper sounds. When picking the car up and giving it power it sounds perfectly fine.
Anything I should be worried about? I rebuilt the slipper when I got home but haven't had a chance to test it out. Maybe ill do it in my driveway just to see how it sounds.
hcopp is offline   Reply With Quote
Old 07-15-2014, 08:49 AM   #5984
Originally Posted by hcopp View Post
Forgot to mention -
I have heard loose diffs sound just like loose slippers. IMO, loosen the slipper. Check the diff and do the 2-3 inch lift test. If you can do the 2 in lift test WITHOUT slipping the diff, your good. BTW, the diff only sounds like a loose slipper when it is VERY loose, like 1-2 turns off. If you are close, but not yet there, it will "bark" different sound
Old 07-15-2014, 10:01 AM   #5985
Thanks for the info,
Question about the lift test. You mean hold the rear wheels and give it power right? Do you give it content power or just pull it quickly? When my slipper was set to stock (nut flush with end of top shaft) I could pull the throttle and the car would raise all the way up and stay there....
