    Hide Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree6Likes
Old 07-13-2014, 09:23 PM   #5926
Wildcat1971's Avatar
Trader Rating: 80 (100%+)
3 long days of racing are over. Well, I rather enjoyed the MM car in 13.5 Super Stock. I need to think about if I want to try a light weight MM 17.5 setup. I hate dumping another $200 into a stock car. I might just run mod for a while. So much fun to lay power down.
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is online now   Reply With Quote
Old 07-13-2014, 10:11 PM   #5927
kwilke's Avatar
Trader Rating: 172 (100%+)
Send a message via AIM to kwilke
anyone having a problem getting the b5m to turn in ?seems like it has wicked push. running same set up seems like everyone is other than shock pistons ?has good exit steering.
Bluegrass Hobbies
www.bluegrasshobbies.com.
kwilke is offline   Reply With Quote
Old 07-13-2014, 10:19 PM   #5928
Haven't heard anyone complain of not enough steering entering a turn. What is your set up? Still rumning gull arms amd tower? If running flat arms go back to gull arms and tower
robbie_gtc is offline   Reply With Quote
Old 07-13-2014, 10:22 PM   #5929
kwilke's Avatar
still running the stock arms and shock tower
Bluegrass Hobbies
Old 07-13-2014, 10:25 PM   #5930
kwilke's Avatar
white springs all the way around
rear hubs split
bottom of shocks all out
2nd hole on tower front and rear
25 kick up .5 on hub
stock locations on turnbuckles
0 in rear hubs
3 toe and 1 antisquat
Bluegrass Hobbies
Old 07-13-2014, 10:56 PM   #5931
Jake S's Avatar
Trader Rating: 65 (92%+)
Send a message via AIM to Jake S Send a message via MSN to Jake S
rear hubs split
0 in rear hubs
move the rear bottom to inside is the "std" setup in the rear. rest of it looks like what 95% of people with a b5m are running.
what tires? what is everyone else running? foams?
if your running 1.6s all around, going to 3 x 1.4s will gain some steering.
what battery? where are your pads? if a shorty try moving it back to gain off-power steering.
is my setup car is very balanced, and has a slight on power push allowing the car to be driven harder, most of which is the Tight diff setting.
VooDoo Racing Cells | Flying Farmer RC | Trackside Hobby | Prochko Paintz | RG1
Jake S is offline   Reply With Quote
Old 07-13-2014, 10:56 PM   #5932
Pittsdriver's Avatar
I run flat arms and tower, white springs all around and have gobs of turning.
B5
B5M
T4.2
Pittsdriver is offline   Reply With Quote
Old 07-14-2014, 02:05 AM   #5933
Trader Rating: 22 (96%+)
4x1.3 taper down vs 3x1.4
dezertranger96 is offline   Reply With Quote
Old 07-14-2014, 02:14 AM   #5934
Default Ball Diff Rebuild Kit
Need part number and manufacturer.......ae, mip, etc.
Micah123 is offline   Reply With Quote
Old 07-14-2014, 02:32 AM   #5935
joykiller44's Avatar
what weight oil for the frount & rear??
joykiller44 is offline   Reply With Quote
Old 07-14-2014, 03:56 AM   #5936
mxracer458's Avatar
Trader Rating: 47 (100%+)
do the flat arms calm the car down vs the gull wing arms?
mxracer458 is offline   Reply With Quote
Old 07-14-2014, 04:05 AM   #5937
kwilke's Avatar
running 4 hole pistons front shock oil 32.5 rear 27.5 .tires don't seem to affect it at all. closed cell aka foams. loose or tight diff affect the steering ?
Bluegrass Hobbies
Old 07-14-2014, 05:49 AM   #5938
found at teamassociated.com
7677
Old 07-14-2014, 10:03 AM   #5939
Jake S's Avatar
4 hole piston with 32.5wt is most likely letting your front end "dump" on entry i would suggest going up to atleast 35wt if not 37.5.
if the aka closed cell fronts are too new, any car will push if they are unmodified foams.
is what hartson was doing to soften up a new foam to increase traction this weekend.
and if your diff is too tight your car will feel like it pushes on entry - because the rear wont rotate.
Old 07-14-2014, 10:11 AM   #5940
Jake S's Avatar
http://www.bfastrc.com/b-fast_pro_dr...ts_for_ae.html
Diff Rings (2), Carbide Diff Balls (14),
Caged Ceramic Thrust Balls with Grooved Races (1)
B5 order B-FAST part # P66-2-CC $27.75 (best deal imho)
http://www.amain.com/product_info.ph...al-Rebuild-Kit
is the ae part for the rebuild, but does not include the diff balls (need 14x for b5 application)
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
