    Hide Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree7Likes
Old 01-22-2014, 09:21 AM   #571
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
Originally Posted by Davidka View Post
Let's outline what "FT" means or did mean.
  • Graphite plastics - hasn't been the case since before the B4.1
  • Threaded shocks - comes with this
  • ti turnbuckles
  • coated shock shafts
In recent years "FT" has added alloy rear hubs and hexes, both of which are unnecessary (If you're not going to adjust rear width the pin drive is adequate).
Also interesting to note, when was the last time AE offered a "Team" level B4 kit? If I'm not mistaken, that went away with the release of the B4.1, if not before.
Factory Team = strong Kool Aid.
To me, Factory Team Kit means that they are selling a kit that has the words Factory Team on it.
Now if you want to debate what made up a Factory Team Kit based on history then yes you are almost if not 100% correct.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 01-22-2014, 09:27 AM   #572
Wildcat1971's Avatar
Trader Rating: 80 (100%+)
It looks like AE has all of the usual option parts, but I noticed there are not any alum rear hubs. I know they are not required, but thought it was a little odd in todays rc market. It is one of those things that sells, but does not help performance.
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 01-22-2014, 10:07 AM   #573
I'd like to see a pic with saddle packs installed. From the pics, the stock battery strap doesn't look like it would work all that great.
So, what's everyone doing for batteries? Saddle, shorties, or the new brick? I was thinking of buying so saddles so I can use them in other vehicles, but now I'm thinking shorties.
Corners is offline   Reply With Quote
Old 01-22-2014, 10:08 AM   #574
C4PT4IN's Avatar
Originally Posted by Carranza76 View Post
The fast mod guys at our track (two of them are running reedy and are Team C drivers) run low 16 and high 15's on that layout currently. That vid was shot a few weeks ago from my understanding.
Oh I knew what 'they' were running But I'm a 'tad' bit slower
C4PT4IN is offline   Reply With Quote
Old 01-22-2014, 10:50 AM   #575
I am thinking you might jumper the packs up front where the esc is.
Old 01-22-2014, 10:55 AM   #576
The saddles are exactly the same size as the brick pack side to side. only diff is what wildcat said. you use a small jumper
Bubonic-X is offline   Reply With Quote
Old 01-22-2014, 10:58 AM   #577
bilster44's Avatar
Can the middle of March get here any s l o w e r ?
"Let Your Racing Speak"
bilster44 is offline   Reply With Quote
Old 01-22-2014, 11:04 AM   #578
I am on the fence about the MM after reading what Maifield and the Engineer said. I find it very odd that they are not really trying to sell the MM as being for the masses. Yeah, I know MM is not for the masses, but I would feel better about buying a MM if they could at least lie to me, lol. Maifield says its a tire game. Well, I race outdoors on watered clay with mixed traction from heat to heat. If I have to look at the track and pick the perfect tire each time, I think I might be better off in RM. I will probably still get one, just to see for myself, but those guys are dashing my hopes. lol
Old 01-22-2014, 11:16 AM   #579
Mason's Avatar
It all works together. Tires are just the first step, probably the most important step because with out the proper grip level your suspension set up isn't doing what you're expecting it to.
Mason McCombs
NewRed Hobbies & Indoor Facility
Off-Road, Dirt Oval, Crawlers & Pullers
Mason is offline   Reply With Quote
Old 01-22-2014, 11:28 AM   #580
yeah, the right tires are always important. You need those correct before tuning. I was more concerned about having to match the tire more closely to the ever changing traction. More so than the RM. I had a car once that was VERY tire sensitive. As the water evaporated through an 8 minute main, the car would go from locked in to 4 wheel sliding. Where as my B4 I could toss on tires that worked and run all day and only make minor changes to my line. Anyway, my point was that the AE driver and Engineer are not really "selling" the MM. They talked way more about how they maintained the b4 geometry on the RM, but also make jumping and easy of driving changes. I thought they made more of a case for the RM than a MM to the buyer. But he also said, we would only buy one car, because we will run the config that works locally. So, it seemed he was selling to the club racer that does not travel more so than the racer who does. Which is probably the best way to sell product. Way more slow locals than fast traveling drivers, lol.
Old 01-22-2014, 11:34 AM   #581
Yes, but look at the strap. The strap is "Y" shaped and want I want to know is how securely the stock strap will hold down the saddle packs. It looks like the back outside corners of the packs won't have anything holding them down.
Old 01-22-2014, 11:37 AM   #582
I would think there is enough covered in the middle section to keep them from falling it. The way the foam is on the side, I would think they have some friction on them as well. Again, I dont think the packs are going any where.
Old 01-22-2014, 12:08 PM   #583
MM video
+ YouTube Video
Old 01-22-2014, 12:11 PM   #584
hmm, why does the youtube video not embed?
Old 01-22-2014, 12:24 PM   #585
BRSracing's Avatar
Trader Rating: 53 (100%+)
Well it looks like at least two B5M's exist.
BRSracing is offline   Reply With Quote
