    Hide Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree7Likes
Old 07-05-2014, 06:36 PM   #5731
Rybeau40's Avatar
I noticed a lot of the pro setups use 80-90% brake. i can't get above 40% without spinning out. What gives?
Kyosho Lazer ZX-6R 10.1 Orion pro, Spektrum 6040
Team Associated B5M, Hitec servo Mod class, 10.0 Orion
Futaba 4PLS
Support your LHS.
Sponsored by my wife who gives me no grief
Rybeau40 is offline   Reply With Quote
Old 07-05-2014, 06:41 PM   #5732
I believe that is 80-90% of whatever they have programmed on the esc. They may only have the esc setup for 50% brake
robbie_gtc is offline   Reply With Quote
Old 07-05-2014, 08:25 PM   #5733
BillPear's Avatar
Send a message via Yahoo to BillPear
Originally Posted by lbckevin View Post
I run the Reedy 14g and its works great for 17.5
Aw Kevin they sucked you back in
BillPear is offline   Reply With Quote
Old 07-05-2014, 09:32 PM   #5734
Tech Legend
Wild Cherry's Avatar
[QUOTE=Rybeau40;13381712]I noticed a lot of the pro setups use 80-90% brake. i can't get above 40% without spinning out. What gives?[/
Should also consider the pro set up listed were being used at big events where traction is very high and anyone usually runs more brake as
grip increases.
Any driver can copy a great set up, a Champion however will steal it .
If Jesus returned as a Rc car he be a Rc10 B5M
George W. Cherry
Wild Cherry is offline   Reply With Quote
Old 07-05-2014, 10:16 PM   #5735
on the brake setup.. most pros use very good speed controls and radios... they set everything up at 100% on radio before setting up speed control and then adjust from there.. usually 80% brake is good start point.. then test to get car to work as needed.. you don't want to lock up the back end only slow the car very quickly.. this will give you your fastest corner speed .
rickster is offline   Reply With Quote
Old 07-06-2014, 10:41 AM   #5736
Graham11's Avatar
Trader Rating: 21 (100%+)
Hey guys, I've had my b5m since March but just getting to race for first time this weekend coming up, what parts are breaking that I should have handy or what aluminum pieces are necessary for durability? Thx for the help
Graham11 is offline   Reply With Quote
Old 07-06-2014, 02:01 PM   #5737
3srcracing's Avatar
Trader Rating: 25 (100%+)
What affect does the inline setup give the car?
Is it worth doing? (ESC in cradle)
3srcracing is offline   Reply With Quote
Old 07-06-2014, 04:51 PM   #5738
Speeds up the chassis roll from side to side by centering the weight in the chassis lengthwise.. This also reduces side bite though, which is not a ggod thing for the tracks I run at. I am not a fan unless you run on a track with lots of switchbacks, jumps in turns, or really high bite clay or sugared/carpet surfaces. Sometimes quick handling makes the car way harder to drive IMO.
bambambennett is offline   Reply With Quote
Old 07-06-2014, 05:12 PM   #5739
Rybeau40's Avatar
Quick handling is what mid-motor is all about no?
Futaba 4PLS
Support your LHS.
Old 07-06-2014, 05:36 PM   #5740
Picked up the MIP topshaft today and noticed the bi-metal pucks were $62 at my local shop (seems like an absolute steal) so thats next on my list. Looking forward to stripping the car down and giving it its first deep clean and rebuild.
hcopp is offline   Reply With Quote
Old 07-06-2014, 07:15 PM   #5741
lbckevin's Avatar
Trader Rating: 89 (99%+)
That's a great price and they are perfect for 17.5 buggy. I love my MIP pucks.
Kevin Smith
Hobbywing * Pro-Line * MIP * Paint Monster
lbckevin is offline   Reply With Quote
Old 07-06-2014, 08:21 PM   #5742
Wildcat1971's Avatar
Trader Rating: 80 (100%+)
well the "hard" parts wont take any abuse. I have broken a front tower and a front bulkhead. That is it.
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 07-06-2014, 08:37 PM   #5743
anyone running on med/high bite with largish jumps? My MM car is just dragging across the ground too much. I can actually see is slow down when it lands from the friction of the chassis on the clay. I am already running 1.6 pistons in the back, but I am running 1.4s in the front with 37.5 oil. grey springs front and white rear.
Also, I picked up an orion r10 pro for my MM mod buggy. And it just seems to run kinda warm to me. I have the radio at 90% throttle and the timing set to 10 deg on my reedy 8.5. I had it at 20 deg, but the esc was getting to 156 deg. It dropped to 140 when I lower the motor timing. I am running 25/75 gearing and a short packs, so around 1620 grams. My viper ran cooler. I am just surprised at the temps. Also my cap is mount to the the heat sink, so maybe less air flow. But i have no where else to put it until i get smaller receiver.
Old 07-06-2014, 08:42 PM   #5744
Default b5 rear arm on b5m
What does the changing to the B5 rear arm do? or what is the diffrence?
Watkins is offline   Reply With Quote
Old 07-06-2014, 08:43 PM   #5745
more traction. It moves the arm/hubs forward to put more weight over the rear tires.
