    Hide Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree7Likes
Old 07-02-2014, 08:15 PM   #5701
noob question. How do you guys measure camber? I have a slight amount of toe-out which a local driver recommended. Do you measure with the wheels set to make the car go straight despite them being slightly outwards, or do you center up each wheel individually and then measure? Thanks.
hcopp is offline   Reply With Quote
Old 07-02-2014, 08:25 PM   #5702
Turn you car on and let the servo center. Drop your car from about 10 in up and let suspension settle. Then measure with a camber guage
scythe23 is offline   Reply With Quote
Old 07-02-2014, 08:48 PM   #5703
vr6cj's Avatar
Trader Rating: 124 (100%+)
So if your going run the D4 I had to rotate the endbell so to mount the motor screws. Just FYI
vr6cj is offline   Reply With Quote
Old 07-03-2014, 07:57 AM   #5704
Mason's Avatar
had to do that on the d3.5. nothing new.
Mason McCombs
NewRed Hobbies & Indoor Facility
Off-Road, Dirt Oval, Crawlers & Pullers
Mason is offline   Reply With Quote
Old 07-03-2014, 07:58 AM   #5705
Mason's Avatar
and to take into account the slop/slightly deformed wheels and tires, rotate them a quarter turn and check again. rinse, repeat.
Mason McCombs
Old 07-03-2014, 03:26 PM   #5706
You can also bolt on a set of rims with no tire glued on to make it easier to read
Old 07-03-2014, 03:52 PM   #5707
Trader Rating: 59 (100%+)
you should always set your camber with the wheel straight in the front. If you are running toe out you should center the wheel and set it. This is common practice in 1/8th as sometimes you run a large amount of toe out. Youll get 15 different answers on this, but this is the correct way.
rc23 is offline   Reply With Quote
Old 07-03-2014, 04:02 PM   #5708
vito's Avatar
iam back online need wire and I be running esc hook up and mortor
the happy racer
drango 410 v 4
am dyslexic
b5 mid motor
vito is offline   Reply With Quote
Old 07-03-2014, 06:46 PM   #5709
Thanks!
Old 07-03-2014, 06:53 PM   #5710
Took mine out for its fifth run today. Its an indoor clay track with this one jump that is giving me hell. I am running a Tekin RS Gen 2 - Killshot 17.5 - 32/75 gearing and Gold Barcodes. I feel I just don't have much punch to get over this jump.
It is a small jump that lands on a tabletop which immediately has another jump at the end of the table. When I hit it perfectly I can clear the landing by maybe 3 inches. I will try to attach a picture of the current layout but it doesn't show the jump well.
I am running blink at the track as thats what I will eventually race with, but what would you guys recommend I try out to get a bit more punch? What gearing should I run? Timing on the motor appears to be at 20 degrees, which is how it was when I got it (don't know if this is normal or not).
Any ideas for the best setup? I also run at an indoor hard surface track, but run 21/79 (I Think) with tons of boost and that works really well for me.
Thanks for the reading the hodge podge of info, appreciate any input.
Old 07-03-2014, 07:07 PM   #5711
my friend runs that motor and esc combo. Try going to 31/72 with 30deg timing that seems to be a really good gearing set up and your track isnt much different than ours. Also you running the high torque killshot and not the rmp one right?
Old 07-03-2014, 07:59 PM   #5712
Wildcat1971's Avatar
Trader Rating: 80 (100%+)
deleted
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 07-03-2014, 08:21 PM   #5713
3srcracing's Avatar
Trader Rating: 25 (100%+)
Just got done installing and sanding gears.. Will report back how they are.
3srcracing is offline   Reply With Quote
Old 07-04-2014, 08:59 AM   #5714
Thanks, turns out it is a 72t spur, I misread the manual when I was double-checking what the stock spur was. Wouldn't increasing the timing reduce the low end, therefore giving me less punch to get over that jump? Maybe I just need to perfect the entry into those jumps and thats how it will be. Dropping a tooth on the pinion should help though I assume.
Side question, do new top shafts and pucks help with these situations? i.e. do those modifications give you more punch since there is less rotational mass?
Old 07-04-2014, 09:04 AM   #5715
dropping 2 teeth on the pinion will make a noticeable difference in your bottom end so you should be able to up your timing but that is an easy change to play with. The aluminum top shaft imo is a must buy, the mip one is the lightest and for 15 dollars you lower your rotating mass and get a smoother gear mesh. I haven't put the pucks in yet but did put in the top shaft and ceramic diff gears which did give me a little snappier response and a cooler running motor.
Oh like i asked also are you running the high torqe or high rpm killshot?
