    Hide Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree6Likes
Old 06-25-2014, 07:53 AM   #5581
Originally Posted by Wildcat1971 View Post
How were your temps in 17.5 at SRS?
Good ever since I switched to hacker it hasn't been an issue. 31/72 40 degree timing coming off at 135 after 6 min
scythe23 is offline   Reply With Quote
Old 06-25-2014, 08:31 AM   #5582
Tech Legend
Wild Cherry's Avatar
Default B5R indoor carpet setup details
Originally Posted by BIGSKI15 View Post
I'm on vacation and one of the indoor tracks is carpet. I ended with Michael schoettler's set up because tcrc is said to have very high traction. I also installed a gear diff with 3000 weight oil.
The shop carries a lot of carpet tires and they suggested dboots terabytes in either A or B compound. I ran B compound only because they were out of A.
It is very good although I wish that I had gray springs to try.
It was my first time ever on carpet so I really wasn't sure but it has been great so far.
Also, there are carpet set ups on petitrc.com.
Went though the trouble & got some setup details for carpet .
Let me know how this works for you please..
Front
Ae orange or red spring
1.6 x 2 piston
35w oil
2 mm under tower ball stud
1 degree camber
19mm ride height
shock position middle on tower & outside on arm
Rear
Ae green spring
1.7 x 2 piston
30w oil
outside chassis camber mount & inside rear hole on alloy hub
No shim under rear chassis camber stud
2 degree camber
2000 w gear diff
3/0 or 3/1 toe & anti squat
78/23 8.0 Reedy Sonic
Reedy short pack
Mount battery inline , Esc in the rear under water fall, trim the battery braces off.
Schumacher mini pin, not sure which compound..
Any driver can copy a great set up, a Champion however will steal it .
If Jesus returned as a Rc car he be a Rc10 B5M
George W. Cherry
Wild Cherry is offline   Reply With Quote
Old 06-25-2014, 08:47 AM   #5583
ToddMcM's Avatar
I'm so confused by some of the numbers I've seen posted on gearing and timing for this buggy.
I'm at 33/69 with 25 degrees of timing via ESC not endbell. Is the B5m trans 2.6:1? If so that puts my FDR at 5.44:1 which is significantly higher than some of the setups I've seen posted. Car is coming off after 5-6 minutes at 120 degrees F. Currently running RSX and D3.5 17.5 (ya, I know the RSX is overkill but it will eventually end up in a 4wd buggy, but that's beside the point).
Any input?
I race 1/1 scale, 1/8th scale and 1/10th scale.
ToddMcM is offline   Reply With Quote
Old 06-25-2014, 08:50 AM   #5584
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 156 (100%+)
Any input?
If you are running any timing in the ESC and race at OCRC, then thats a no-no. Depending on motor, 33/69 with timing on the motor sounds about normal for blinky (what you should be at) 17.5 buggy. Each motor is different from another, and the gearing that works for me might not be best for you even if they are the same motors.
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 06-25-2014, 08:53 AM   #5585
yes most of the posts that you see here with similar gearing refer to 17.5 blinky no esc timing is allowed
Old 06-25-2014, 09:10 AM   #5586
Wildcat1971's Avatar
Trader Rating: 80 (100%+)
Hmm, not bad temps at all. What is your race weight?
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 06-25-2014, 09:27 AM   #5587
Not sure I haven't weighed it. I have put on titanium tb's aluminum top shaft nova slipper to lighten up the drive train but that's it for weight. Running a full size servo and aeromodel 4800 90c battery weights 255 so im guessing around 1640ish. I am running the Phantom body with all the vents cut out for airflow. I'llbe aat w3 on Friday if you wanna check it out. Car runs great now I just gotta see where to find the upgrades for the person driving it lol
Old 06-25-2014, 09:29 AM   #5588
racer_guy's Avatar
Originally Posted by TOO-TALL View Post
Anyone have a fix for all the play in front wheel bearings?thought the play was in the trailing inserts so I glued them in this got rid of alot of the play, but there is still more I would like to get rid of.I can see the screw holding the axle in moveing around....maybe aftermarket bearings??
these claim to fix the problem
http://www.teamassociated.com/news/l...ll_Bearing_Set
W.E.D. Winning Edge Designs
racer_guy is offline   Reply With Quote
Old 06-25-2014, 09:44 AM   #5589
cool. I have the triad slipper and Ti TBs, and the topshaft is on my to do list. I am surprised your temps were that low with a weight over 1600. Have you run this setup on W3? Curious to see if temps are lower at SRS due to less wheel spin
Old 06-25-2014, 09:51 AM   #5590
ToddMcM's Avatar
Good to know! I'm an 1/8th scale guy, so just learning the ropes on the 1/10 buggy stuff. Was just easier to play with timing on the esc. I'll put it in "blinky" mode and adjust the end bell though.
And good to know I'm geared in the proper ballpark. I'm planning to do some more testing plus minus a pinion tooth to see any gains/losses.
So far, having so much fun going so much slower than I'm used to! I'm still a full second off of the really fast guys though even on my best laps.
Not sure how I'll ever make that up with the limited time I get at the track; but I'll have fun trying!
Thanks again for your time and input.
Old 06-25-2014, 12:02 PM   #5591
Temps are about 5-10 less at srs. Warehouse I was coming off at 122 with my telemetry and srs it was around 112-115. My telemetry is almost always exactly 12 deg cooler than actual temps so w3 I run 134ish and srs 126ish. I was running the same gearing with my tekin rs pro/trinity 17.5 combo and was pushing 160 at w3. The hacker has really impressed me I'm running the hacker esc and motor and I have noticeably more power and much lower temps
I have ceramic diff bearings too
Old 06-25-2014, 03:45 PM   #5592
TOO-TALL's Avatar
Originally Posted by racer_guy View Post
www.skyski.com
www.foilforum.com
"Hey Baby want to make fourteen dollars...the hard way??" ----Rodney Dangerfield--Caddyshack.
TOO-TALL is offline   Reply With Quote
Old 06-25-2014, 06:23 PM   #5593
Tech Legend
@ the track
Just installed a set of K springs, red rear & gold fronts...
Been using Ae white rear & grey front.
Going to try um out right now.
Old 06-26-2014, 03:17 AM   #5594
MiCk B's Avatar
It's Schumacher yellow for carpet.
With a medium insert.
Tyre
Link: http://www.racing-cars.com/pp/Old_Ca...EVO/U6608.html
Insert:
Link: http://www.racing-cars.com/pp/Old_Ca...cal/U6734.html
MiCk B. :-)
http://www.dublinmodelracing.com
http://www.p-dubracing.co.uk
http://www.msdmodels.ie
MiCk B is offline   Reply With Quote
Old 06-26-2014, 08:01 AM   #5595
Tech Legend
TY MiCK
Only ran the springs one pack.
They seem ok, felt very similar to the Ae .
Won't know for sure with out a running in a club race next.
Most of our fast guys are using the combination I am testing.
George W. Cherry
Currently Active Users Viewing This Thread: 9 (2 members and 7 guests)
eragot, tvih
