    Hide Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree6Likes
Old 06-24-2014, 10:03 AM   #5551
Speed Freak RC's Avatar
Originally Posted by vfrninja View Post
Just finished my mm build and have encountered a problem. I assembled my gearbox with ceramic bearings to start. There's a rough spot somewhere and I've checked the gears for debris and it's clean. The two halves of the gearbox don't close all the way in a couple spots too. Anyone have these issues too?
I had the same issue. Put the top shaft in the case, then the first idler next to the top shaft and put the case halves together. Spin the top shaft and see if it's free. Then do the same with the other idler gear. I bet you will find one of the two idlers feels rough.
Speed Freak RC is offline   Reply With Quote
Old 06-24-2014, 10:06 AM   #5552
Wildcat1971's Avatar
Trader Rating: 80 (100%+)
Originally Posted by Speed Freak RC View Post
I just did the same thing yesterday and put Lunsfords on mine. I used my calipers to measure the distance between the cups (exposed part of turnbuckle) and re-set the lunsfords to that measurement when I put it back together. Went quick and easy, and all my settings are exactly the same.
yeah, I was planning to do that...but I like to tinker, lol. I am currently using LONG links front and rear. I plan to goto inside/inside front and inside/outside 2 hole in the rear. So my measurements wont be the same. Since i am using kit front positions, I plan to use the kit measurements up front and then adjust from there. The rear is super easy and not even worth talking about, lol. Maybe tonight I will start polishing my balls and start working on it. I saw a guy at the track using the DE setup wheels and was debating if that was even worth it.
Also, I posted a cup binding video last week. I might do a small before and after polishing one to demonstrate how much you can free them up with a dremel and some 800 grit. I just spent the entire weekend moving and now unpacking, so my RC free time has been hampered.
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is online now   Reply With Quote
Old 06-24-2014, 10:09 AM   #5553
mschumi101's Avatar
Trader Rating: 21 (100%+)
Send a message via Skype™ to mschumi101
Originally Posted by Wildcat1971 View Post
Yeah, camber is easy to set. My issue is, when I change camber, toe changes also. Its a back an forth thing. I will try the ruler method you suggested for toe, as my eyeing it method takes a while, lol. Again, I can do it, I just dislike it, lol. Was looking for an easier/faster way to get the toe and camber right. Again, camber is easy. But it messes with toe, so i go back and forth.
The camber shouldn't affect the toe. I have never had that problem on any of my cars. Just make sure to drop the car and settle the suspension before each link you adjust, and after you adjust each link to make sure the car is settled. You can easily push the car down and have one corner measure to -1 camber, but as soon as you settle it have it be -1.5 or something like that. Same goes with adjusting toe. Settle-measure-adjust-settle-measure- repeat. Additionally when adjusting front toe I like to do it with the car on so that the steering doesn't move and is held in place by the servo. Helps eliminate changes from ackerman.
Associated B5M Reedy 7.5 | Xray T4 ORCA 17.5
Orange Powered!
Previous: B44.2 | TC5R | TC5 | B4.2 | B44 | Slash | E4RS | TA05R | TT01
-Ted
mschumi101 is offline   Reply With Quote
Old 06-24-2014, 10:17 AM   #5554
I push down to the max then release. Isn't that the same as dropping the car? Seems like it would even be more consistent.
Micah123 is offline   Reply With Quote
Old 06-24-2014, 10:21 AM   #5555
mschumi101's Avatar
Yeah, pushing it all the way down or dropping it should do the same thing. On my touring cars I always push down then release. But with buggies I prefer to drop them as that is how they will settle after a jump. Just my logic, but both methods should achieve the same results.
And by pushing down I meant when you are actually adjusting the link itself. And you fail to settle the car after adjusting. Sorry, should have made that more clear.
Orange Powered!
-Ted
Old 06-24-2014, 10:23 AM   #5556
If you drop of push the car down, it should return to the ride height settings. I like to drop it to because its more fun, lol.
Old 06-24-2014, 10:41 AM   #5557
Camber will always affect toe. Don't believe it? Pop the inner ball cup off the caber link and tilt the wheel in and out using the camber link. You will see the toe also changes, although it's not a whole lot when your talking small camber adjustments. That's why its a good idea to adjust camber first before you move on to toe.
Old 06-24-2014, 10:46 AM   #5558
+1
scythe23 is offline   Reply With Quote
Old 06-24-2014, 10:49 AM   #5559
J@UNE's Avatar
Default Tlr wheels
Just wanted to share for those like me that are just trying without letting go their TLR cars.
I did this mod a while ago on my team-c vehicule so ive re-use it on the b5m. Ive cut the 22 front hex and drill them bigger. Used cuntershunk screw and a 1mm spacer to get same offset.
Official Team Associated RC10 B5m Mid-Motor Thread-image.jpg   Official Team Associated RC10 B5m Mid-Motor Thread-photo-1.jpg
Jon Gagnon
DirtTrax - Team FLR
J@UNE is offline   Reply With Quote
Old 06-24-2014, 11:18 AM   #5560
suby723's Avatar
100% correct.
suby723 is offline   Reply With Quote
Old 06-24-2014, 11:20 AM   #5561
Photocycler's Avatar
Trader Rating: 34 (100%+)
what is a good competitive servo, motor, esc setup for this buggy? Will be running on an indoor carpet track
Photocycler is offline   Reply With Quote
Old 06-24-2014, 11:28 AM   #5562
I am really liking the hacker motor and esc's orion makes a nice esc as well. As for servos you can't go wrong with savox
Old 06-24-2014, 11:30 AM   #5563
There's thousands of choices out there. Best bet is to read up on the different equipment your considering and make your own choice.
Old 06-24-2014, 12:18 PM   #5564
Jcozz's Avatar
Trader Rating: 20 (95%+)
Just converted one of my b5's to a B5M. Super easy conversion. Took about 1.5hr and it's a mid now! Anybody have a good starting set up for indoor ozite carpet? One of My local tracks just went carpet and have no clue where to start besides putting in a gear diff And lowering ride height.
Jared Cozzocrea
HobbyPro PRS1 / HobbyPro SB401 / Fusion Graphics / Mayor RC
Premier RC Raceway and Hobbies
Dave's RC Tracks
Jcozz is offline   Reply With Quote
Old 06-24-2014, 12:25 PM   #5565
mschumi101's Avatar
Now that I think about it, this would be true. If the car had 0 degrees of kickup/caster in the front, then it shouldn't affect it... correct? But with the buggies having 25-30 degrees, it would somewhat affect toe. But only in small increments as you stated. My mistake! Thanks for pointing that out.
Orange Powered!
-Ted
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
