    Hide Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree7Likes
Old 06-09-2014, 09:37 PM   #5131
Trader Rating: 18 (100%+)
Think I might end up getting the M after all. And before anyone ask yes, this is simply because of the article about MM taking over. Haha
If you build it I will break it!
EB48.4 - B6 - B64 - TC7.1 - F6
iTz Nicholas72 is offline   Reply With Quote
Old 06-10-2014, 06:41 AM   #5132
racer_guy's Avatar
well, its official. http://www.redrc.net/2014/06/team-as...es/#more-82101
W.E.D. Winning Edge Designs
racer_guy is offline   Reply With Quote
Old 06-10-2014, 07:03 AM   #5133
Wildcat1971's Avatar
Trader Rating: 80 (100%+)
I converted one of my RM cars last night. Sadly a few screws were missing so I will need to hunt for some in my rc piles. I am looking forward to running it back to back against my RM car for comparison. Now, I need a body and wing. Also, I built the car with the f/r RM car arms. The MM conversion overall went ok. The fit and finish was not great. Many of the screws that mounted the plastics to the chassis had screw holes that didnt line up. So I had to flex and manipulate several screws to get them in.
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 06-10-2014, 07:13 AM   #5134
Originally Posted by Jason Turner View Post
Oops I have been running 3 trailing with hubs forward and 2mm ackerman what will changing to what you mentioned do?
I have changed just the inserts too and could not tell a whole lot of different from all 3 changes being made in tandem. With only the inserts changed, you are running a longer wheelbase, and a more aggressive ackerman setup. (less ackerman washers = less aggressive steering).
Deluxe312 is offline   Reply With Quote
Old 06-10-2014, 07:26 AM   #5135
Wildcat. I have a stock b5m body you can have its in great shape I just got the proline one. I can give it to you at the warehouse
scythe23 is offline   Reply With Quote
Old 06-10-2014, 07:36 AM   #5136
Originally Posted by scythe23 View Post
Little help, I want to try out the 3mm trailing I read that that will help with more mid to exit steering, is that correct? Anyhow can I just change inserts or will switching from the 4mm to 3mm trailing insterts require me to shim anywhere else. Sorry if this is a dumb question Im just trying to figure this out. Thanks
I am going to run the 3mm on my car because....something is wrong with the 4mm inserts. My bearing barely function with them, yet they are smooth in the +3.
Old 06-10-2014, 07:38 AM   #5137
I just put on flat arms and shock tower and switched to 3mm inserts to try at the warehouse so if I make it tonight I'll let you know what the difference I felt
Old 06-10-2014, 07:56 AM   #5138
sounds good. I am looking forward to running MM. I tried the TLR and didnt care for the edge of my seat driving. I am hoping the MM B5 work well indoors on medium bite. Plus the new mist system at w3 seems to keep the track consistent.
Old 06-10-2014, 08:00 AM   #5139
NoNothing's Avatar
Originally Posted by racer_guy View Post
well, its official.
God those are ugly mills. I'd definitely polish those bad boys up a bit.
It looks from pictures that it's just the stock plate with some weight milled out.
Wonder if I could take my stock plate to a machine shop
NoNothing is offline   Reply With Quote
Old 06-10-2014, 08:03 AM   #5140
Mason's Avatar
I think they need to work on their programming to clean up the mill marks. It's probably doing the "fastest" work but definitely not the prettiest.
Mason McCombs
NewRed Hobbies & Indoor Facility
Off-Road, Dirt Oval, Crawlers & Pullers
Mason is offline   Reply With Quote
Old 06-10-2014, 08:04 AM   #5141
Mason's Avatar
Personally I rather see the finned design come back.
Mason McCombs
Old 06-10-2014, 08:05 AM   #5142
Well I'm FAR from the best driver but the warehouse has awesome traction now even if it does get super humid I'll take it. Even with my limited driving skills the b5m hooks up great. You gonna run stock or mod? Only a few of us run the mm in stock but I still love how it handles
Old 06-10-2014, 08:26 AM   #5143
Tech Legend
Wild Cherry's Avatar
We used a set of those fancy scales for weighting the car at each wheel.
Turns out if you go with the inline short battery ?
Whether you mount the esc in front or rear of battery ?
Same weight distribution...
Also will share the same weight distribution as the RB6 & TLR 22 when using inline short pack.
So ?
Get the battery forward and loose the spaghetti look & weight from having all that wire.
Any driver can copy a great set up, a Champion however will steal it .
If Jesus returned as a Rc car he be a Rc10 B5M
George W. Cherry
Wild Cherry is offline   Reply With Quote
Old 06-10-2014, 08:31 AM   #5144
I plan to run mod with it, but for now I will run 17.5, just because i wanted to compare the 2 cars. I am still trying to decide what mod motor I want. Probably a reedy, and somewhere between an 8.5 and a 10.5. I just sold a reedy 8.5 /face palm
Old 06-10-2014, 08:36 AM   #5145
Lol I hate when I do that. Wish I was good enough to run mod...oh well practice practice. Mod competition is stiff at w3, he'll last week rivkin lapped second place
