    Hide Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree7Likes
Old 06-05-2014, 09:32 PM   #5071
Trader Rating: 20 (100%+)
Does anyone know what length ball studs are used on the new Factory Team rear aluminum hubs?
GTSSTANG is offline   Reply With Quote
Old 06-05-2014, 09:39 PM   #5072
gticlay's Avatar
Depends on which hole you want to put that shaft in.
gticlay is offline   Reply With Quote
Old 06-05-2014, 09:43 PM   #5073
I guess it also depends on the shim you use too.
Old 06-05-2014, 09:45 PM   #5074
Wildcat1971's Avatar
Trader Rating: 80 (100%+)
you have to use shorter ones over the bearing or your will ruin the bearing.
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 06-05-2014, 09:56 PM   #5075
Good to know. Thanks
Old 06-05-2014, 09:57 PM   #5076
Are there any milled motor plates available yet?
Old 06-05-2014, 10:14 PM   #5077
inline
fdpRASTA is offline   Reply With Quote
Old 06-05-2014, 11:29 PM   #5078
HBRob's Avatar
Trader Rating: 61 (100%+)
Send a message via Skype™ to HBRob
Those running everything inline and trimming the plastic braces, are the hard plastics being used instead of the kit plastics?
If you are talking about chassis plastics, no. I am using hard on some of the suspension components.
**Privateer** - Getting Out 11/12/16
TLR 22 3.0 | TLR 22T 2.0 | TLR 22-4
Fantom Racing | Hobbywing | Futaba
#ocrcarmy
HBRob is offline   Reply With Quote
Old 06-05-2014, 11:42 PM   #5079
Tech Legend
Wild Cherry's Avatar
Just the forward inside stud hole needs care & a shorter ball stud (6mm).
Rest use a 8mm stud..
Your going to use the rear inside stud location on the hub & include 3mm spacer under the stud.
Any driver can copy a great set up, a Champion however will steal it .
If Jesus returned as a Rc car he be a Rc10 B5M
George W. Cherry
Wild Cherry is offline   Reply With Quote
Old 06-06-2014, 03:12 AM   #5080
Hi everyone
Does your front wheel on full lock hit the front suspension arm?
Mine sure does.
ryan73 is offline   Reply With Quote
Old 06-06-2014, 03:32 AM   #5081
eper's Avatar
Trader Rating: 14 (100%+)
Does it do it when the car is sitting static or when u are holding it in the air? Also u could jus adjust your end points on your radio.
new milford ct,
WOLCOTT HOBBIES.. TEAM SCREAM..PRO-LINE RACING,,RC Truck Stop, and FTM grip
I CALL IT HOW I SEE IT!!!!!
eper is offline   Reply With Quote
Old 06-06-2014, 03:54 AM   #5082
mxracer458's Avatar
Trader Rating: 47 (100%+)
how does flipping the inserts in the rear hubs from the up and down position effect handling?higher more traction or vice versa?
mxracer458 is offline   Reply With Quote
Old 06-06-2014, 06:18 AM   #5083
insert holes up=higher roll center
insert holes down=lower roll center
Depends on how "locked in" or "freed up" you want the rear. There are many existing threads around here cussing and discussing the whole roll center thing ...
will5879 is offline   Reply With Quote
Old 06-06-2014, 08:52 AM   #5084
T-BirdJunkie's Avatar
Location: Norwood, OH...and CCRCR and The OhioRCFactory
Send a message via AIM to T-BirdJunkie Send a message via MSN to T-BirdJunkie
Originally Posted by Cpt.America View Post
From what car/platform? Because the studs and ballcups from the 210/410 are the worst studs and ballcups on the market. I would run the Kyosho ballscups and lunsford studs if looking for an alternative.
Just because you can't figure out how to build them properly doesn't make them bad. I just replaced my 2 year old ballcups on my DEX210 with new non-Dimec X cups.
If you don't allow yourself to make mistakes, you'll never allow yourself to succeed
T-BirdJunkie is offline   Reply With Quote
Old 06-06-2014, 09:06 AM   #5085
