    Hide Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree9Likes
Old 06-01-2014, 09:51 AM   #4951
gticlay's Avatar
Originally Posted by vito View Post
thank you I got a round lrp 200mm all the shop had
That will totally make you slow. All that extra weight and it's just wrong Vito.
gticlay is offline   Reply With Quote
Old 06-01-2014, 09:52 AM   #4952
vito's Avatar
so the flat one go under the battery
the happy racer
drango 410 v 4
am dyslexic
b5 mid motor
vito is offline   Reply With Quote
Old 06-01-2014, 02:48 PM   #4953
suby723's Avatar
Trader Rating: 21 (100%+)
My b5m geared 72/33 with a 17.5 reedy sonic with 43* timing never goes above 160 degrees. The car is at 1562g rtr. With my 7.5 78/21 I never go above 130. No heat problems at all for me. People that run 69/32 run into heat issues.
suby723 is offline   Reply With Quote
Old 06-01-2014, 03:17 PM   #4954
mxracer458's Avatar
Trader Rating: 47 (100%+)
at 1562 did you do anything to lighten it up?
mxracer458 is offline   Reply With Quote
Old 06-01-2014, 03:39 PM   #4955
3srcracing's Avatar
Trader Rating: 25 (100%+)
I'm at 1620grams and geared 69/33 and have no heat problems. I'm about 130*.
Reedy Sonic 17.5 w/ 42* timing
3srcracing is online now   Reply With Quote
Old 06-01-2014, 03:48 PM   #4956
mxracer458's Avatar
what does this thing way bone stock?
Old 06-01-2014, 05:22 PM   #4957
Cridd's Avatar
Trader Rating: 16 (100%+)
Like 1600 give or take for electronics.
Chris
B6D / T5M / SC5M
Cridd is offline   Reply With Quote
Old 06-01-2014, 05:26 PM   #4958
Ok i know this is a loaded ? But I'm buying a new motor, I would like to race mod but usually only have 1 mod main and it's almost all sponsored drivers so I'm sticking to stock. I have a trinity fantom v4 17.5 and I have been told the sure speed and hacker motors are the fastest and rUn the coolest for stock. What are your thoughts on the 2...or another u think k is good. Thanks
scythe23 is offline   Reply With Quote
Old 06-01-2014, 05:26 PM   #4959
Tech Legend
Wild Cherry's Avatar
kinda silly going by someone's so call weight their claiming..
They can miss the body , tires ECT..
Just saying..
Big weight tip
AE rim's are lighter then the rest & by a fair amount.
Easy couple gram per wheel.
Any driver can copy a great set up, a Champion however will steal it .
If Jesus returned as a Rc car he be a Rc10 B5M
George W. Cherry
Wild Cherry is offline   Reply With Quote
Old 06-01-2014, 05:27 PM   #4960
vito's Avatar
so take it back and buy a flat one?
the happy racer
drango 410 v 4
am dyslexic
b5 mid motor
Old 06-01-2014, 05:35 PM   #4961
Or is the trinity d 3.5 that much better? I can run that at my club races I don't do roar
Old 06-01-2014, 06:11 PM   #4962
Mincks_Brian's Avatar
Thumbs up
WEIGHT SAVING TIP FOR 17.5 DRIVERS AKA EVO WHEELS OR AE WHEELS ARE A WAY TO GO . If looking to save weight !! Have not finished my 5m yet but I'll be doing some weight test with JCONCEPTS wheels AE wheel and AKA EVO WHEELS .
Thank You to My Sponsors , Hy-Traction Juice .
AIRTRONICS-JCONCEPTS-LUNSFORD-TEKIN-PROTEK-LSRSPEEDWAY-DARKSIDE DESIGNS-
Mincks_Brian is offline   Reply With Quote
Old 06-01-2014, 07:06 PM   #4963
Tech Legend
Just go over head with your motor wires Vito,
Easier to install & replace if you have trouble with.
George W. Cherry
Old 06-01-2014, 07:35 PM   #4964
T-BirdJunkie's Avatar
Location: Norwood, OH...and CCRCR and The OhioRCFactory
Send a message via AIM to T-BirdJunkie Send a message via MSN to T-BirdJunkie
Raced the car outdoors on Friday night. Fluffy track with tons of dust...
The car has so much forward bite it should be illegal. I'm really digging this car.
Any ideas to keep the rear from getting loose under braking? I have to dial back way more brake than I have in the past with my RM Durango or B4.2 to keep it from swapping ends under hard braking. How will removing antisquat negatively affect the car otherwise?
If you don't allow yourself to make mistakes, you'll never allow yourself to succeed
T-BirdJunkie is offline   Reply With Quote
Old 06-01-2014, 07:59 PM   #4965
Tech Legend
get use to , mid motor takes time .
Also mid hates heavy braking.
Practice to be smoother entering corners and smoother on throttle .
Personally run about 15% softer brake then if using a rear motor .
George W. Cherry
