    Hide Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree7Likes
Old 05-27-2014, 07:11 AM   #4786
Originally Posted by HBRob View Post
I'm at about 1530 right now. Biggest issue is corner entry steering which I've going to work on again this week. Just have a couple hours on it so far working through tuning. Other than that no problem. I'm running on med/high grip clay.
Did you notice a big diff in corner entry steering when you reduced weight? Wonder how things would be at just under 1500g?
Micah123 is offline   Reply With Quote
Old 05-27-2014, 07:14 AM   #4787
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 156 (100%+)
Originally Posted by Rybeau40 View Post
Anyone the B5m with 0 anti-squat yet? Also, does the kit come with the aluminum C/D arm mounts or is this a must have upgrade beyond the kit?
The kit comes with plastic mounts, the aluminum mounts (and inserts) are needed if you want to go to 0 anti squat. They make it alot easier to adjust anti squat as well.
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 05-27-2014, 07:15 AM   #4788
Mason's Avatar
did you corner scale the car first? if you made the usual weight savings adjustments that everyone thinks they need to do then you're f/r static weight bias might be a bit off for the spring rates you were originally using.
Mason McCombs
NewRed Hobbies & Indoor Facility
Off-Road, Dirt Oval, Crawlers & Pullers
Mason is offline   Reply With Quote
Old 05-27-2014, 06:06 PM   #4789
Tech Legend
Wild Cherry's Avatar
@ the track
Traction is rather high even for Trcr, ghost's or even slicks are performing well...
So for tonight's club race going to take a leap with the setup.
Moving rear chassis camber stud to out side position
Switching to 2.5 /1 toe block...
Any driver can copy a great set up, a Champion however will steal it .
If Jesus returned as a Rc car he be a Rc10 B5M
George W. Cherry
Wild Cherry is offline   Reply With Quote
Old 05-27-2014, 07:11 PM   #4790
RaceDayHobbies's Avatar
Originally Posted by Cridd View Post
What is the best way to remove the anodizing from the blue FT turnbuckles...on my b5m.
Easy Off oven cleaner. Spray it on, let is sit for a bit and wipe off.
Play around with how long you leave it on. I would start with a fairly short time .
RaceDayHobbies is offline   Reply With Quote
Old 05-27-2014, 08:30 PM   #4791
HBRob's Avatar
Trader Rating: 61 (100%+)
Send a message via Skype™ to HBRob
Unfortunately made the mistake of going straight to lightening without running the car box stock first, so I don't have a good feel for how it 'was'. But yes, agree, plan is to make some adjustments to battery placement, springs and shock setup tomorrow. Feel everything else should be set.
**Privateer** - Getting Out 11/12/16
TLR 22 3.0 | TLR 22T 2.0 | TLR 22-4
Fantom Racing | Hobbywing | Futaba
#ocrcarmy
HBRob is offline   Reply With Quote
Old 05-27-2014, 09:25 PM   #4792
Cridd's Avatar
Trader Rating: 16 (100%+)
I need to play with shock set up too. Need to lighten up shocks and springs since car is about 100 grams lighter then when I started. Thinking of dropping 2.5 to 5 weight all around and going down one spring rate from stock set up....don't know if that sounds right.
Chris
B6D / T5M / SC5M
Cridd is offline   Reply With Quote
Old 05-27-2014, 09:48 PM   #4793
suby723's Avatar
Trader Rating: 21 (100%+)
Works like a charm however it wont remove the blue from the turnbuckle.
suby723 is offline   Reply With Quote
Old 05-27-2014, 09:59 PM   #4794
3srcracing's Avatar
Trader Rating: 25 (100%+)
Firs time out with the car today, wow A LOT better then the B5. Car was hooked up until the main then the traction was gone for some reason. (everyone was loose) One thing is for sure once this car get's loose it's a handful.
Dont know how you guys are so light, I'm sitting at 1620 with reedy 17.5, Savox 1257, Racers Edge Shorty, LRP SXX, Schelle slipper.
3srcracing is offline   Reply With Quote
Old 05-27-2014, 11:01 PM   #4795
HBRob's Avatar
For me first shot is battery, going to move forward about 1-2 sm pads to deal with all the weight I took out of the back. Next will be 1 down on rear springs if that doesn't do it. Saving oils for last as I think I'm already a bit on the thin side
Several others running as light or even lighter than I am at ocrc, so also going to take a look around for comparison sake tomorrow.
Ah the fun of trying to tune a new car.
#ocrcarmy
Old 05-27-2014, 11:34 PM   #4796
Tech Legend
Car handle the extra grip very well.
The outer rear camber stud really surprised me just how good it performed.
2.5/1 helped the car feel much smoother for the slicks I had to use tonight.
George W. Cherry
Old 05-28-2014, 05:32 AM   #4797
Mason's Avatar
Starting to sound a little faster Cherry.
Mason McCombs
Old 05-28-2014, 07:27 AM   #4798
Tech Legend
Mason
I'm not sure what your track is like , if you have good traction you need to go inline.
The car drives so much better, the kit setup cannot even compare.
Each time I let another racer try my ride they start grinding right after .
No longer telling others to try or test the inline..
Advising & telling them to just do it ..
George W. Cherry
Old 05-28-2014, 09:29 AM   #4799
gticlay's Avatar
Weighed my car this morning and it's a real pig. 1671 grams. Looks like if I were to go to a shorty I would loose 70g plus if I move the ESC back into the battery brace another 10g or so? Man, I'm not sure how you guys get your cars so light!
gticlay is offline   Reply With Quote
Old 05-28-2014, 09:37 AM   #4800
Wildcat1971's Avatar
Trader Rating: 80 (100%+)
most of them are using the 150gram super light shorty. That saves you 50-70g grams over a normal shorty. Then Pucks, alum topshaft, alum pinion, alum screws, shorty servo, slipper eliminator, Ti turnbuckles, Ti front axles and so on. A shorty servo is about 20 grams lighter than a full servo.
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
