    Hide Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree6Likes
Old 05-25-2014, 09:28 PM   #4756
Pittsdriver's Avatar
Originally Posted by Fabulous View Post
Currently 1506 with battery strap and battery foam. pic is without battery strap and foam
How the hell did you get down to 1506?
B5
B5M
T4.2
Pittsdriver is offline   Reply With Quote
Old 05-25-2014, 09:53 PM   #4757
joykiller44's Avatar
Originally Posted by JiuHaWong View Post
Called it! It was only a matter of time!
Nice looking chassis!
i want one
joykiller44 is offline   Reply With Quote
Old 05-25-2014, 09:54 PM   #4758
i want one
Old 05-25-2014, 10:09 PM   #4759
Tech Legend
Wild Cherry's Avatar
Originally Posted by Nick_n View Post
Wildcerry: What made you decide to put the esc in back instead of in front of the battery?
To free up the car's traction, gain stability in the corners & improve weight balance for better jumping & landings.
Any driver can copy a great set up, a Champion however will steal it .
If Jesus returned as a Rc car he be a Rc10 B5M
George W. Cherry
Wild Cherry is offline   Reply With Quote
Old 05-25-2014, 10:35 PM   #4760
Originally Posted by asc6000 View Post
I believe he meant switching (changing) the car itself from mid to rear.
Im sorry my fault. I meant switching between two cars and being able to drive. One rear motor and one mid motor.
rcbrad27 is offline   Reply With Quote
Old 05-25-2014, 10:38 PM   #4761
Originally Posted by BLKXJ96 View Post
I have both cars built and running, I switch between the two all the time. I take both cars to the track, if the Mid motor car starts to fade I run the Rear motor car. Both cars drive the same but different under different conditions...if that makes sense.
Well now that i have heard that from several people im hooked on getting b5m in additon to my rear motor b5
Old 05-25-2014, 10:52 PM   #4762
BLKXJ96's Avatar
In most cases a mid motor car will tend to be faster as long as the traction is there. When the traction is gone the mid motor cars will be a handful and have to be "babied" around the track. When they spin or slide...it happens right now. you may not have time to correct.
Jeff
RC10 Team Car, Gold Pan, RC10 B5m B5mCE, Sc5m, Rc8B3e, B6
BLKXJ96 is offline   Reply With Quote
Old 05-26-2014, 02:06 AM   #4763
Default Too Light?????????????
Anyone reduce the weight of their b5m to around 1500g? How does it handle? Been told that reducing weight of car to around 1500g affects handling and requires a whole new setup. Would like to go lighter but not if it is going to affect car in a neg way.
Micah123 is offline   Reply With Quote
Old 05-26-2014, 04:45 AM   #4764
if I go from 1 b with the a hubs and switch to 1 b with the b hubs and drop 1 mm from the inside ball stud will it keep the rear flatter in the corners and keep about the same camber gain as the 1 b with the a hub ?thnx
Mike Richardson
At the track having fun with my friends
blingy is offline   Reply With Quote
Old 05-26-2014, 05:35 AM   #4765
Trader Rating: 74 (100%+)
Was racing on a medium to low grip outdoor track this past weekend. The car lacked forward bite when exiting corners, especially when entering the straight and trying to get on the throttle a bit harder. I laid the shocks all the way down in the rear, which helped a little. I moved the rear hubs all the way forward and that helped a little. I then decided to try the B5 RM rear arms on my B5M . . . and that helped a lot! I'd guesstimate it's like moving the rear hubs froward another 2mm. You still can't pin the throttle exiting corners, but I can certainly get on the throttle sooner and harder and the car tracked straighter.
The only complaint I have at this point is the lack of mid corner to exit steering. The car has really good entry steering. And if you charger the corner hard and let it rotate on it's own it will gain that exit steering. But if for some reason you don't maintain momentum in to the turn, it's really hard to get it to steer out of the turn.
Associated (2x)B6D, B64D, T5M, SC5M
TLR 22-4 2.0, SCTE 3.0
Mugen Seiki MBX7R Eco, MBX7R Nitro, MBX7T Eco, MBX7TR Nitro
XRAY 17 XB4
Yokomo YZ-2 CA
Wease is offline   Reply With Quote
Old 05-26-2014, 08:35 AM   #4766
I would like to say congrats to Mike Hudson over in Spokane.. he raced the Hank Perry Race this weekend with the b5m... was his first time driving the car .. literally as his first pack with it was in practice the day of race... He got 2 packs in of practice.. there were a bunch of team guys there and a large 2wd class...
he qualified 7th... not sure what he got in first A.. second one he finished 5th.. and after just a little more setup he won the last A main! Awesome driving.. Mike drives for team associated, airtronics and venom and jconcepts..
oh.. he also tq'd and won mod truck. great drive!
The track was a big outdoor track that was also running 1/8th elect and gas.. so was a true test showing b5m can work great outdoors too.
rickster is offline   Reply With Quote
Old 05-26-2014, 08:37 AM   #4767
Tech Legend
same or equal
George W. Cherry
Old 05-26-2014, 12:13 PM   #4768
Cridd's Avatar
Trader Rating: 16 (100%+)
Front;
1.6
32.5
grey
Rear;
1.6
30
white
I see a lot of grey set ups, may have to try.
Chris
B6D / T5M / SC5M
Cridd is offline   Reply With Quote
Old 05-26-2014, 12:18 PM   #4769
Cridd's Avatar
What is the best way to remove the anodizing from the blue FT turnbuckles...on my b5m.
Chris
B6D / T5M / SC5M
Old 05-26-2014, 12:21 PM   #4770
Suspended
Oddly enough, soaking them in pee will take it off. I think it has something to do with the acids in pee.
Pimp Formally Known as OG
PFKAOG is offline   Reply With Quote
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
joesiv
