    Hide Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree7Likes
Old 05-23-2014, 11:10 PM   #4696
racer_guy's Avatar
Originally Posted by racer_guy View Post
so i made a stupid mistake. ordered aluminum c and d mounts...but i accidentally ordered the ones for the b5 instead of the b5m. super mad at myself. we will see if amain has a heart for stupidity.
amain has great customer service. gonna give me store credit and all is well.
W.E.D. Winning Edge Designs
racer_guy is offline   Reply With Quote
Old 05-24-2014, 12:28 AM   #4697
Tech Legend
Wild Cherry's Avatar
Originally Posted by racenut123 View Post
Trying to decipher setups for the rear aluminum uprights and alum inner camber mount. Anyone have suggestions where to start when using these? Not really seeing in setups how these can be implemented into the setup sheet. Am I missing something?
Using both alloy hub & camber mount is the stiffest.
Plastic hub & camber mount has more flex & has extra grip.
A combination like alloy hub & Hard plastic camber mount is my recommendation to start with for good traction.
Myself using the the hub with numbers facing towards the shocks & the rear inside camber hole with 3mm shim under the stud.
The main advantage to using the alloy hub is the ability to adjust the camber stud up or down depending on traction conditions.
GTI
Don't need alloy hubs , the plastic is a awesome piece.
Still, my black alloy hubs stay on my ride.
Tip: When using alloy hubs do not use the 6mm camber stud on the plastic hub.
Move up to the 8mm stud for max strength.
When tighting the set screw for suspension pin don't snug it down real tight as it can make the hub blind.
Any driver can copy a great set up, a Champion however will steal it .
If Jesus returned as a Rc car he be a Rc10 B5M
George W. Cherry
Wild Cherry is offline   Reply With Quote
Old 05-24-2014, 06:40 AM   #4698
Trader Rating: 28 (100%+)
Thanks WC.
Team I'm Over It
racenut123 is offline   Reply With Quote
Old 05-24-2014, 08:05 AM   #4699
Tech Legend
Will be testing the bump steer mod today, lowering the stud on the
steering knuckles 1mm..
George W. Cherry
Old 05-24-2014, 08:40 AM   #4700
Cridd's Avatar
Trader Rating: 16 (100%+)
For stock racing, I'm using a 72 benefit of running a 69 would be moving the motor back a bit, is it noticeable?
Chris
B6D / T5M / SC5M
Cridd is offline   Reply With Quote
Old 05-24-2014, 12:27 PM   #4701
bilster44's Avatar
Originally Posted by Cridd View Post
is it noticeable?
Indeed it is.
"Let Your Racing Speak"
bilster44 is offline   Reply With Quote
Old 05-24-2014, 03:25 PM   #4702
Trader Rating: 140 (100%+)
BAM!!!
RC RACING DESIGNS..
slick1 is offline   Reply With Quote
Old 05-24-2014, 03:37 PM   #4703
gticlay's Avatar
Originally Posted by slick1 View Post
BAM!!!
Purdy. Can we see more pix?
gticlay is offline   Reply With Quote
Old 05-24-2014, 03:39 PM   #4704
gticlay's Avatar
OK
Since you put it out there, which team drivers said don't bother? You may feel you are helping but in reality you are just coming off smug. I have the hubs. I am trying to see where others may start. I like vertical ball studs and was the reason I bought them. You are not using them.....see where I am going with this?
Sorry, that could have come off that way. Basically, I don't like it because you have to be careful which hole you put your ballstud in because the stock ballstud can thread into the bearing carriers and wreck them. It offers no performance advantage, it's just bling that is more difficult to use than the stock part.
Old 05-24-2014, 04:14 PM   #4705
Send a message via ICQ to JiuHaWong
BAM!!!
Called it! It was only a matter of time!
Nice looking chassis!
오늘의 청소년들이 미래의 문제를 처리 할 준비가 병 슬프게도 있습니다 우려하고있다.
JiuHaWong is offline   Reply With Quote
Old 05-24-2014, 04:20 PM   #4706
Tech Legend
Seen quite a few plastic hubs break.
Collected three blue tabs off the track so far, have you priced those tabs ?
You use caution in the forward inside stud hole, rest are no big.
Your stuck with a stud that's lower then what the fast guys R using..
You will never see a alloy hub break from a hard landing.
Just bling ? O really now....ha !
George W. Cherry
Old 05-24-2014, 04:50 PM   #4707
vito's Avatar
the happy racer
drango 410 v 4
am dyslexic
b5 mid motor
vito is offline   Reply With Quote
Old 05-24-2014, 05:58 PM   #4708
Cridd's Avatar
I don't see a real benefit from running the new alum. hubs, that could change but so far have not seen any set ups and explanations on benefits that make them a purchase. They do look really cool though.
Chris
B6D / T5M / SC5M
Old 05-24-2014, 06:00 PM   #4709
Cridd's Avatar
Carbon fiber chassis, nice, what is the weight difference ? How does it drive?
Chris
B6D / T5M / SC5M
Old 05-24-2014, 06:05 PM   #4710
Well you probally have to drive it a little slower because yhere is not that much weight down low to keep the car planted like with the aluminum chassis
xTotalghost is offline   Reply With Quote
