    Hide Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree7Likes
Old 05-19-2014, 08:02 PM   #4576
suby723's Avatar
Trader Rating: 21 (100%+)
Originally Posted by splking1 View Post
Are you talking about hartsons setup sheet that AE has posted
This setup: **use b5r rear arms also** http://www.petitrc.com/setup/associa..._IRCR20140406/
Pics of the car here: **setup sheet is incorrect for the car shown** http://www.petitrc.com/setup/associa...oma2014041113/
suby723 is offline   Reply With Quote
Old 05-19-2014, 08:25 PM   #4577
How does Hartson keep the battery in the car? Velcro, double sided tape?
Associated B6D, HobbyWing XR10 Stock Spec, Schurr Speed 17.5, Sanwa MT-44, Savox 1258TG
Associated T5M, HobbyWing XR10 Stock Spec, Schuur Speed 17.5, Sanwa MT-44, Savox 1258TG
Associated B64D, HobbyWing XR10 Pro, Schuur Speed 13.5, Sanwa MT-44, Savox 1258TG
Cueball22 is offline   Reply With Quote
Old 05-19-2014, 08:27 PM   #4578
gticlay's Avatar
Tape, unfortunately.
gticlay is offline   Reply With Quote
Old 05-19-2014, 08:31 PM   #4579
J_Bone's Avatar
Originally Posted by Wild Cherry View Post
Stalling is something most mid motor designs battle.
In the middle of the corner the car stalls when rotating in the corner
Inexperienced drivers may not notice, experience driver can .
Problem is worst when having to much weight towards the rear of car and chassis roll is limited.
OK, I understand. I was battling that this weekend.
J_Bone is offline   Reply With Quote
Old 05-19-2014, 09:20 PM   #4580
*IDEA*
I noticed when installing my motor today in my build, there is a small gap underneath it once tightened down. The chassis would be a great heatsink! I'm sure someone can tool a piece of aluminum to fit between and transfer some of the heat to the chassis to help keep temps down. Putting a "curve" to hug the motor would keep it from moving around.
Please remember this post to whomever makes this and possible sells it, I want a demo
NovaCX12 is offline   Reply With Quote
Old 05-19-2014, 10:17 PM   #4581
Originally Posted by Buggy kid90 View Post
Team Durango 10x12x0.1mm Differential Shim Set (10)
[TDR310033]
****MAP*Price:*$2.49
These work the centro gear case had the same problem and what do you mean cut gears you cut them your self or some one makes them.
Thank you!
DWill is offline   Reply With Quote
Old 05-19-2014, 10:24 PM   #4582
Originally Posted by Matt Trimmings View Post
Yep… that's where I got them. This tranny is soooo smooth now and while I haven't weighed it to know exactly how much it is noticeably lighter than me other B5M that's all stock. Now I just need the shims to take some of the slop out of the diff bearing and I'll be set.
I have a friend that has a machine shop. I having a aluminum top shaft drop shipped to him. He's going to machine off the gear teeth on the top shaft to match the width of the cut idler gear.
I lose a bit more rotating mass and gain just a bit more acceleration and RPM.
Old 05-20-2014, 03:52 AM   #4583
eper's Avatar
Trader Rating: 14 (100%+)
Originally Posted by NovaCX12 View Post
*IDEA*
Kinda bad idea what happens if u case a jump. All that force is going through that motor. Not sure people would b comfortable with that
new milford ct,
WOLCOTT HOBBIES.. TEAM SCREAM..PRO-LINE RACING,,RC Truck Stop, and FTM grip
I CALL IT HOW I SEE IT!!!!!
eper is offline   Reply With Quote
Old 05-20-2014, 09:29 AM   #4584
offroad dude's Avatar
Trader Rating: 25 (100%+)
Has anybody changed from a RB6 to B5M and can comment on the difference for better or worse.
offroad dude is offline   Reply With Quote
Old 05-20-2014, 10:17 AM   #4585
Trader Rating: 22 (96%+)
I can talk to a local that switched a little later and get his opinion
dezertranger96 is offline   Reply With Quote
Old 05-20-2014, 10:17 AM   #4586
A few RB6MM guys at my local track went B5M and like them. Cheaper parts and durable. Both are great cars, pick your passion.
bambambennett is offline   Reply With Quote
Old 05-20-2014, 10:26 AM   #4587
I already have a RB6 I just wanted to know is it worth getting the B5M and buying all new stuff. However, if this car is that great I don't mind changing.
Old 05-20-2014, 10:41 AM   #4588
I don't think a B5M would be so great you should immediately change. When your RB6 is ready for replacement, then consider it. The price point of the car is very appealing, but you do need a few upgrades here and there but it still ends up cheaper than a RB6. And finally AE went metric
Old 05-20-2014, 11:24 AM   #4589
vito's Avatar
I pick up a fantom works 17.5 motor
the happy racer
drango 410 v 4
am dyslexic
b5 mid motor
vito is offline   Reply With Quote
Old 05-20-2014, 12:32 PM   #4590
jjwitczak's Avatar
hello people! so i got my B5M a week ago, i came here to learn some racing setups/tips. After reading a few hundred posts, i noticed that people were having motor temp issues?
So, as of now I am only concerned about my B5M running its motors hot, because my driving style- is aggressive and i run 8.5 turn for 2wd modified class at our indoor dirt track.
I thought I saw somewhere- someone suggesting that we cut out the stock B5M body's side scoops? The scoops' positionings look right and the right side scoop looks like it lines up with the motor so should it stream cool air straight on the motor? OR would it be disastrous, weakening the body? Any tips or advices will be appreciated! Pic is attached for reference.
Subscribed.
"JJ"
AE B6D
SMC powered
jjwitczak is offline   Reply With Quote
