    Hide Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree9Likes
Old 05-16-2014, 08:11 AM   #4516
Trader Rating: 22 (96%+)
It is supposed to make more rear grip, or something to that nature
dezertranger96 is offline   Reply With Quote
Old 05-16-2014, 08:13 AM   #4517
Tech Legend
Wild Cherry's Avatar
Ty dezert.....
Any driver can copy a great set up, a Champion however will steal it .
If Jesus returned as a Rc car he be a Rc10 B5M
George W. Cherry
Wild Cherry is offline   Reply With Quote
Old 05-16-2014, 08:17 AM   #4518
vito's Avatar
its my birthday Monday time to build my mid kit
the happy racer
drango 410 v 4
am dyslexic
b5 mid motor
vito is offline   Reply With Quote
Old 05-16-2014, 08:22 AM   #4519
SilentHunter's Avatar
Happy BDay Vito! Save yourself some time and dremel out everything from previous posts and install rm front and rear Arms, front shock tower , locktite rear hub ball studs and front axel screw right away. Enjoy the build, one of my favorites to date.
SilentHunter is offline   Reply With Quote
Old 05-16-2014, 08:55 AM   #4520
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
Originally Posted by SilentHunter View Post
READ!!! Or go talk to your "teammates" Your on this site all day I can't explain it any easier. It locks the rear end down when running on high to med grip. More rear traction. %25 more grip (sarcasm)
I hope people in this hobby can figure out what is upside down when installing the rm arms.
He probably has you on ignore.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 05-16-2014, 10:14 AM   #4521
suby723's Avatar
Trader Rating: 21 (100%+)
Using b5r rear arms flipped DONT move the arms 1 to 2mm forward. Its .75mm forward to be exact.
suby723 is offline   Reply With Quote
Old 05-16-2014, 10:39 AM   #4522
Sorry, I wasn't exactly sure, I'll fix my post
Old 05-16-2014, 11:02 AM   #4523
gticlay's Avatar
It's pretty well established that the RM arm mod is 2mm forward.
gticlay is offline   Reply With Quote
Old 05-16-2014, 11:55 AM   #4524
Mason's Avatar
Originally Posted by davidbarton87 View Post
Guys over in the rear motor thread have been talking about raising the front hubs, figured I would share over here as well. Used a technique that Luke Smith used on his Centro to raise the hub 1mm. If you were looking for a basically free way to try out the raised hub here is the way to do it. If you dont like it then move the 1mm spacer to the top and you have the original hub position.
I'm not seeing the modification done. Are they grinding on the steering arm, changing/grinding out shoulder bushings or ??? I was under the impression that new shoulder bushings with various thicknesses on the shoulders would be coming out so you could adjust this.
Mason McCombs
NewRed Hobbies & Indoor Facility
Off-Road, Dirt Oval, Crawlers & Pullers
Mason is offline   Reply With Quote
Old 05-16-2014, 12:03 PM   #4525
Mason's Avatar
offset bushings.. where the hell was the 8th AE spamletter this week about these being released??
http://www.teamassociated.com/parts/details/91403/
Mason McCombs
Old 05-16-2014, 12:16 PM   #4526
markt311's Avatar
Trader Rating: 32 (100%+)
Cause they were in stock for the last 1 1/2 months
PR Racing Bellgate Distributors
Caster Racing Parts
311 RC Graphics
markt311 is offline   Reply With Quote
Old 05-16-2014, 12:27 PM   #4527
Mason's Avatar
Does anyone else have other cooling mods they've done?
One's i'm currently aware of are the motor band mounted fan, waterfall mod/mount.
Anyone doing scoops or vent holes on the body? gator teething or shimming the gear cover?
My motors currently are running okay. I've been thinking about helping that out a bit in the future but I'm currently mired with a heck of a time keeping my tekin rs cool. It has the latest software (i believe) and I'm in blinky mode with some wimpy mod motors (10.5/13.5). We use a lot of heavy brakes on the currently layout and I'm sure some of that is the problem for the regular RS. Unfortunately with the 10.5 (same elec setup as my previous B4 and never had an issue like this) i've been between 23/81 and 27/81 with very little speedo change (170F!) so I've dropped to a 13.5 thinking maybe something is wrong with the motor and it has not gone down much. Can't drop the gear on it much more either as the 17.5s nearly walk me down the front straight now! Transmission seems okay but I guess I need to take it apart and verify.
So let's see some of your ideas!
Mason McCombs
Old 05-16-2014, 04:34 PM   #4528
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
run without a body....:-) I would run a lower turn motor that will run cooler. MM cars always run warmer. I gained 30 deg trying to run MM.
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 05-16-2014, 05:28 PM   #4529
vito's Avatar
iam up to the diff now in the bilud
the happy racer
drango 410 v 4
am dyslexic
b5 mid motor
Old 05-16-2014, 07:41 PM   #4530
Pittsdriver's Avatar
Nice! My B5m is waiting for me at home.
B5
B5M
T4.2
Pittsdriver is offline   Reply With Quote
Currently Active Users Viewing This Thread: 4 (1 members and 3 guests)
GasGod
