    Hide Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree9Likes
Old 05-14-2014, 10:54 AM   #4441
skrichter's Avatar
Send a message via AIM to skrichter
Originally Posted by gticlay View Post
Sometimes when your car is already very good, better doesn't feel much different. That's why you have to test with the computer lap counter on.
Agreed -- its all about lap times. My lap times didn't show improvement.
I didn't try 2x1.6 or 3x1.4 either, though.
LiveRC.com | Dirt Heaven Hobby & Raceway
skrichter is offline   Reply With Quote
Old 05-14-2014, 11:25 AM   #4442
Quick question. I just rebuilt my diff last week. Can i use those dif balls in a different setup? Or should I just buy new ones again?
splking1 is offline   Reply With Quote
Old 05-14-2014, 11:40 AM   #4443
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
safest bet. replace them.
In many instances you can reuse if you dont have flat spots. Figuring out if you have flat spots may not be the easiest. That is the nice thing about the ceramics....no flat spots. I am sure the "fast" guys replace them and the cheap guys do not. If your old diff was gritty, replace. Keep if it was smooth , but if its smooth, why are you replacing parts anyway...
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is online now   Reply With Quote
Old 05-14-2014, 11:40 AM   #4444
Originally Posted by dezertranger96 View Post
I still can't find a reliable screw supplier, anyone know of any? I know there was a Japanese supplier, but I can't seem to find them again
Lunsford makes a kit. I'm running that. It's pricy. 110 bucks
Old 05-14-2014, 11:42 AM   #4445
In many instances you can reuse if you dont have flat spots. Figuring out if you have flat spots may not be the easiest. That is the nice thing about the ceramics....no flat spots. I am sure the "fast" guys replace them and the cheap guys do not. If your old diff was gritty, replace. If it was smooth keep, but if its smooth, why are you replacing parts anyway...
Yeah the dif balls are only a week old. Is the cermaics a better choice?? Some guy said they were to hard to break in or dial in. Never ran them so I wouldn't know.
Old 05-14-2014, 11:43 AM   #4446
I am sure he is looking for the cheap ones that are as soft as alum screws, lol. I bought the tlr Ti screw kit when it was $20. As it turned out, they were just as soft as the alum screws.....I dont think any of the "cheap" screws will be at lunsford's quality.
Old 05-14-2014, 11:47 AM   #4447
well the ceramics have less "bite" on the rings. that is what he is referring to. If they are only a week old and still good, keep. but you can get flat spots on day 1 with improper break in. My b5 diff is still like butter, so I dont feel the need to rebuilt yet. When I do, I will replace the balls with tungston carbide and the thrust with avid caged ceramic. I have noticed that a LOT of the grit can be removed just by replacing the thrust bearing and plates. I only race once a week, so my diffs last a long time.
Old 05-14-2014, 01:06 PM   #4448
gticlay's Avatar
Buy the casper RC ceramic thrust and use the stock balls and rings and you'll have a cheap, very long lasting smooth diff.
gticlay is offline   Reply With Quote
Old 05-14-2014, 01:09 PM   #4449
how are casper's balls better
Old 05-14-2014, 01:42 PM   #4450
RCBuddha's Avatar
Trader Rating: 35 (100%+)
They're ceramic and one piece. Avid's are also very good. I have yet to try bfast's version.
RCBuddha is offline   Reply With Quote
Old 05-14-2014, 01:45 PM   #4451
so are avid's. I suggested the avid, then he suggested caspers. I was wondering what was better about caspers.
Old 05-14-2014, 01:48 PM   #4452
Trader Rating: 22 (96%+)
Not looking for ones that are soft like the aluminum ones, actually looking for I believe it is grade 5 titanium or one step up, like I said I am still doing research and a lot of it at that.
dezertranger96 is offline   Reply With Quote
Old 05-14-2014, 01:56 PM   #4453
cool. If you find a good source, I will probably join in if the pricing is good and you can find the same grade.
Old 05-14-2014, 02:07 PM   #4454
RCBuddha's Avatar
I could tell no difference between avid and Casper's one piece thrusts.
They probably get them from the same company.
Old 05-14-2014, 02:24 PM   #4455
wstuart's Avatar
Trader Rating: 112 (98%+)
Send a message via AIM to wstuart
Which slipper should I use for stock?
Should I use the exotek locked slipper to save weight - or does that make it drive poorly
Is anyone having luck using the old b4 twin plate slipper? Is there a disadvantage in stock to using the new heavier multi-plate slippers?
Yokomo Yz-2 x2
Yokomo B-max4iii
Awesomatix a700 evo
Team El Cajon Hobbies
wstuart is offline   Reply With Quote
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
