    Hide Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree6Likes
Old 05-12-2014, 04:02 PM   #4351
Jason Turner's Avatar
Trader Rating: 63 (100%+)
Any pics of yours? I don't understand fully. Also i'm not a fan of reciever on the right anyone putting it up on a tray or something different?
Originally Posted by Wild Cherry View Post
Mark
Grind all the tray off flush to the vertical sides of the brace . Be careful of the screw locations, don't remove. Cut each thumb screw separate from the tray then remove middle plastic between thumb screws.Each thumb screw is separate and uses the one screw for attachment.
Remove inside legs off water fall.
Slide Esc under water fall, only a 1/4 of Esc fits under the water fall.
Battery in front of Esc.
Receiver on right side of battery.
Note:
Grinding the battery tray is for more flex in front of waterfall to achieve more traction.
Jmoney, test each and tell everyone your results. Prove your theory...
I already done, and posted the results however..LOL
Jason Turner is offline   Reply With Quote
Old 05-12-2014, 05:54 PM   #4352
vito's Avatar
what battery pack fit this will a shorty fit
the happy racer
drango 410 v 4
am dyslexic
b5 mid motor
vito is offline   Reply With Quote
Old 05-12-2014, 06:58 PM   #4353
Of course....haven't you seen all the pictures of this car?
Deluxe312 is offline   Reply With Quote
Old 05-12-2014, 07:33 PM   #4354
Fabulous's Avatar
Trader Rating: 42 (100%+)
Originally Posted by Jake S View Post
if you cut the waterfall for the battery to go back to the motor there looks to be room with a normal servo.
I'm confused ! I don't have a waterfall in my B5m unless your referring to the tranny brace? If so why not just remove the brace instead of cutting it.
22 4.0 - Mod
22 3.5 - Stock
22-4 2.0 - 13.5
8ight E 4.0
Fabulous is offline   Reply With Quote
Old 05-12-2014, 07:34 PM   #4355
Here is my inline setup. I went with the battery all the way back. Also i didnt cut out the battery box. I want to be able to switch back and forth to normal setup and inline setup to see what i like best.
splking1 is offline   Reply With Quote
Old 05-12-2014, 07:37 PM   #4356
Yes that is what every one is referring to. I wouldn't recommend removing it as its considered the front mount for your tranny.
Old 05-12-2014, 07:44 PM   #4357
Fabulous's Avatar
Now I see. Thanks for sharing a pic to better understand. Any difference in handling?
22 4.0 - Mod
22 3.5 - Stock
22-4 2.0 - 13.5
8ight E 4.0
Old 05-12-2014, 08:02 PM   #4358
Tech Legend
Wild Cherry's Avatar
use post #4321
Only difference is I grinded the battery box off and my thumb screws are separated from the brace. This was done to help bring more flex to chassis in front of waterfall.
BTW
Hey Mark ! Good work & well done on your inline.
Any driver can copy a great set up, a Champion however will steal it .
If Jesus returned as a Rc car he be a Rc10 B5M
George W. Cherry
Wild Cherry is offline   Reply With Quote
Old 05-12-2014, 08:12 PM   #4359
Tech Legend
For Trcr
Remove the waterfall or brace and the rear flex becomes excessive and adds to much traction with a lost of stability.
The car's stall is made stronger and becomes quite noticeable .
Whole reason for the inline to reduce the stall all mid motors battle.
George W. Cherry
Old 05-12-2014, 08:22 PM   #4360
Trader Rating: 28 (100%+)
Very nice. Double sided tape for battery? What did your car weigh this way?
Team I'm Over It
racenut123 is offline   Reply With Quote
Old 05-12-2014, 08:26 PM   #4361
Originally Posted by racenut123 View Post
Very nice. Double sided tape for battery? What did your car way this way?
Thank you. No it still uses the battery strap. Just didn't have it on in the pic. As for weight not sure. Haven't weight with this set up.
Old 05-12-2014, 08:44 PM   #4362
Send a message via AIM to slappomatt
look at the CG of the battery. You might as well have left it stock. Havent changed anything.
slappomatt is offline   Reply With Quote
Old 05-12-2014, 08:53 PM   #4363
If the focus is to get the weight over the rear then the battery back makes sense. Considering he runs the shorty servo and is able to get the electronics relatively inline as far as weight goes,how is this even similar to stock?
Explain this to me like I am 5 because I am obviously not seeing your point.
Team I'm Over It
Old 05-12-2014, 08:55 PM   #4364
Not even close to the same CG as I ran before. No were near stock
Old 05-12-2014, 09:06 PM   #4365
I'll be testing it tomorrow. Thanks Wild Cherry for sharing this mod.
