    Hide Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree9Likes
Old 05-09-2014, 09:04 PM   #4261
Default FT Low Friction X-Rings
Looking for a little advice. When using the FT Low Friction X-Rings, do you use anything on them like green slime or will the oil on the shock shaft be sufficient?
Thank you.
Jose_FL is offline   Reply With Quote
Old 05-09-2014, 09:15 PM   #4262
gticlay's Avatar
Thank you.
Green slime.
gticlay is offline   Reply With Quote
Old 05-09-2014, 09:18 PM   #4263
thecman26's Avatar
Trader Rating: 99 (100%+)
Thank you.
I always use green slime or shock snot when building shocks.
Chris Keen: Viola, Kansas
Kyosho RZ6, TLR 22 3.0, TLR 4.0 SR (soon),& 22T 3.0
"I'm too drunk to taste this chicken!", Col. Sanders
thecman26 is offline   Reply With Quote
Old 05-09-2014, 09:22 PM   #4264
gticlay's Avatar
Originally Posted by Wild Cherry View Post
Spent over $450 extra on upgrades...
Tommorow grinding & modifying mass...
Doing a inline shorty mod...
Yes, spend all you can , still not enough for Tacomptom...
Always something to do , change , buy & grind...
Personally I think you should have tried it box stock except for the rear camber plate and ti turnbuckles. Are you turning lower lap times back to back with the Centro or ?? I tried a box stock one for a day along with my RM and when it was moist and a lot of traction I was consistently faster than my RM. When it loosened up things were closer. Gonna start by testing white springs F&R and gray springs F&R.
Old 05-09-2014, 09:29 PM   #4265
Originally Posted by gticlay View Post
Green slime.
Thank you.
Old 05-09-2014, 09:29 PM   #4266
Thank you.
Old 05-09-2014, 09:57 PM   #4267
Tech Legend
Wild Cherry's Avatar
Originally Posted by brian cox View Post
How you liking the 5m George
Going same pace as old C4 right off , over all times very close.
B5 way easier to drive with the improved jumping & landings.
Can hurl the B5 harder into the corner too.
Driven um all, B5 best ever.
Any driver can copy a great set up, a Champion however will steal it .
If Jesus returned as a Rc car he be a Rc10 B5M
George W. Cherry
Wild Cherry is offline   Reply With Quote
Old 05-09-2014, 10:07 PM   #4268
Tech Legend
[QUOTE=gticlay;13251321]Personally I think you should have tried it box stock except for the rear camber plate and ti turnbuckles. Are you turning lower lap times back to back with the Centro or ?? I tried a box stock one for a day along with my RM and when it was moist and a lot of traction I was consistently faster than my RM. When it loosened up things were closer. Gonna start by testing white springs F&R and gray springs F&R.[/
Already have been running base setup.
Only new changes has been the alloy hubs & rear Hard tower & arms.
inline deal is cool.
Esc in back under the water fall.
Also thinning the chassis brace.
Hang at Trcr & you'll always grinding & testing .
George W. Cherry
Old 05-09-2014, 11:58 PM   #4269
Default Spring cups?
I may not be getting something here, but the numbers on my spring cups seem to be all wrong. to get a matching set of spring cups I have to run 2 different numbers. For example: When I grab a "3" and a "3" they are very different sizes. Right now I am running a "1" and a "3" up front but they are actually the same size.
mk2rocco is offline   Reply With Quote
Old 05-10-2014, 12:09 AM   #4270
The numbers on the parts indicate cavity number in the mould, so used for production / maintenance purposes. I guess AE thought the difference in height would "speak for itself", so no special identification needed..
B5M
22 2.0
B44.2
TC4
SC10 4x4
Pellefa is offline   Reply With Quote
Old 05-10-2014, 12:45 AM   #4271
Thanks for clearing that up! I thought I was crazy
Old 05-10-2014, 07:24 AM   #4272
ridgerunner1's Avatar
Trader Rating: 21 (100%+)
Hey George after getting my ride set up last Tuesday night i moved mine inline but i didn't cut any plastic, i only have the large receiver so putting it in front of the short pack it fit just right, i also changed out the stock slipper and put in the shelle slipper and it dropped 10g on weight coming over today before racing and try that out, i am just waiting on my screw kit, mip top shaft and new cut gears to try I'm going to try the top shaft and cut gears before i think about the puck system.
Mike Craig
A&E B5M - Viper ESC
New Home Track Tacoma TRCR http://www.tacomarc.com
RIP Beremerton RC race way
ridgerunner1 is offline   Reply With Quote
Old 05-10-2014, 07:38 AM   #4273
Tech Legend
Ridge
This inline mod has the Esc placed in the rear of chassis with the inside middle of the water fall trimmed. You put the Esc under the water fall, receiver goes on rear side next to battery like we use to do with b4.
We're also trimming the side rails of chassis brace thinner so the chassis can flex more in the area in front of the water fall to the servo.
Trim the plastic in between the battery thumb screws so battery fits inside.
Doing the mod today.
George W. Cherry
Old 05-10-2014, 07:44 AM   #4274
Trader Rating: 310 (100%+)
Ridge
This inline mod has the Esc placed in the rear of chassis with the inside middle of the water fall trimmed. You put the Esc under the water fall, receiver goes in rear side next to battery like we use to do with b4.
I'm doing the mod today.
Can we get pics?
Jermaine Mitchell
I laugh at serious racers acting like B****
Free Agent racing team. No sponsors needed.
Mercenary Racer
jmoneym is offline   Reply With Quote
Old 05-10-2014, 07:49 AM   #4275
Originally Posted by jmoneym View Post
Can we get pics?
Nice I'll wait for pictures or I'll see it on Tuesday night.
Mike Craig
A&E B5M - Viper ESC
