    Hide Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree6Likes
Old 05-06-2014, 05:15 PM   #4141
Wildcat1971's Avatar
Trader Rating: 80 (100%+)
lol. yep its all the same. you should skip the flat arms
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 05-06-2014, 05:23 PM   #4142
Tech Legend
Wild Cherry's Avatar
Default Alloy rear camber brace
Originally Posted by rigor View Post
Doesn't 4mm on the low side of the aluminum rear ballstud mount just equal to if you ran it on the built in +2 high side ? I know using 2mm washers on the low side puts it at "zero" (like plastic mount with no washers).
Could of just flipped it , no shims..
Or
no flip, but can adjust the amount of shim's for more tuneability.
Any driver can copy a great set up, a Champion however will steal it .
If Jesus returned as a Rc car he be a Rc10 B5M
George W. Cherry
Wild Cherry is offline   Reply With Quote
Old 05-06-2014, 05:33 PM   #4143
Tech Legend
seems like the shock eye is below the front bulk head with the gull
Flat arm shock eye is even if a little above on bulk head
Get sure the top shock eye is a whole hole different between the two.
George W. Cherry
Old 05-06-2014, 05:55 PM   #4144
Jake S's Avatar
Trader Rating: 65 (92%+)
Send a message via AIM to Jake S Send a message via MSN to Jake S
tower closer on the top, and shocks laid down more.
VooDoo Racing Cells | Flying Farmer RC | Trackside Hobby | Prochko Paintz | RG1
Jake S is offline   Reply With Quote
Old 05-06-2014, 06:01 PM   #4145
Send a message via AIM to slappomatt
thank you. I will look into it. Didnt notice it in the pics.
ETA is anyone running hard arms? I am wondering how they handle regular racing. I am affraid they might be brittle?
ETA 2 wouldnt running your shocks on the inner hole at the top do basically the same thing?
slappomatt is offline   Reply With Quote
Old 05-06-2014, 07:26 PM   #4146
Tech Legend
@ the track
Just installed the new Ae alloy hubs...(black)
Number's facing same side as shocks.
middle of arm
Camber location is inside hole
using 3mm spacing under stud & 4mm spacing under alloy chassis camber stud
George W. Cherry
Old 05-06-2014, 08:20 PM   #4147
Check out the relation to the lower shock mount and pivot points of lower arm. Also check out tower mounting bolts vs upper shock mounts.
Official Team Associated RC10 B5m Mid-Motor Thread-b5-gullwing.jpg   Official Team Associated RC10 B5m Mid-Motor Thread-b5-flat-arm.jpg
Hacksback is offline   Reply With Quote
Old 05-07-2014, 08:01 AM   #4148
djhSPAWN's Avatar
So, after trying to get out of the hobby I am pulled back in and have a B5M on the way. I just wanted to make sure all my basis are covered after reading through so many pages of this thread. As of now I am not going to do the little things that I see the more vet people doing (cutting and what not). I plan on racing this in stock and as of now my driving skills are still whats slowing me down. So here is what I got for the B5M.
Lunsford Ti Turnbuckle
B5 Front Shock Tower and Arms
Any other things I am missing?
SC10 / DEX210
djhSPAWN is offline   Reply With Quote
Old 05-07-2014, 08:06 AM   #4149
the rear alum camber link would be good for durability. In the past it has appeared to be a little weak.
Old 05-07-2014, 08:09 AM   #4150
Think you got it right to first concentrate on your driving skills. Once you start competing with the other drivers in your class you can get an aluminum top shaft, mip puck system, slipper eliminator. This car is great right out of the box. I would build it per the manual before doing anything. Get used to the stock setup first so you can compare any changes to stock when you make them. You made the right decision with this model. Super strong and drives great. Enjoy the build and good racing to you.
Micah123 is offline   Reply With Quote
Old 05-07-2014, 08:57 AM   #4151
djhSPAWN's Avatar
Thank you for the information. Could I get a link for alum camber link and the slipper eliminator?
SC10 / DEX210
Old 05-07-2014, 09:00 AM   #4152
you can get what ever you want. personally I would hold off on the slipper eliminator. I know a lot of people that dislike it. If you want to shed rotating mass, then I would get the AVID Triad slipper. The stock slipper is pretty heavy for 17.5. And temps could be an issue in 17.5
Old 05-07-2014, 09:15 AM   #4153
djhSPAWN's Avatar
Awesome, thanks for the information.
SC10 / DEX210
Old 05-07-2014, 11:10 AM   #4154
Here you go. http://www.exotekracing.com/
Heard different opinions on eliminator. I run a tight slipper anyway so I was used to controlling things with my trigger finger. Definitely an item you can wait on until you have a chance to practice some more. FYI, I had tightened my stock slipper to the max to emulate an eliminator but still had the associated weight of a slipper. Normally, you want to back off the throttle when landing with a tight slipper or eliminator but I have not had a problem stripping idler gears to date. The 17.5 does not have the torque of my 7.5 (strip idler gears frequently on my sc10) so probably not so critical to be off the throttle on landings.
Old 05-07-2014, 11:23 AM   #4155
I think the 2 pad slipper with vented disks is a better way in stock. Only reason is dont like the idea of the trans taking a big hit on big air landings or crashes. It will also transmit back to the motor too. Just my 2 cents
Bubonic-X is offline   Reply With Quote
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
