    Hide Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree7Likes
Old 05-06-2014, 07:16 AM   #4126
BRSracing's Avatar
Trader Rating: 53 (100%+)
Anyone have a Tekin RSX in there B5m? Looking for some wiring ideas in the new mid motor, post pics if you got em please.
BRSracing is offline   Reply With Quote
Old 05-06-2014, 07:26 AM   #4127
So I was told there are alumium cvd made my mip that just replace the stock one and I don't need to spend 90$ on a puck system
xTotalghost is offline   Reply With Quote
Old 05-06-2014, 07:38 AM   #4128
gticlay's Avatar
The pucks system includes outdrives as well as the bone and pucks. But yeah, a TLR aluminum bone will fit on the B5.
gticlay is offline   Reply With Quote
Old 05-06-2014, 07:42 AM   #4129
Tech Legend
Wild Cherry's Avatar
Update:
Removed the triple Ae slipper.
& the B5 slipper spring.
Replaced with vented twin pad & heavy duty sc 10 slipper spring.
Next is the removing 1 mm from bump steer.( was highly suggested to do)
Won't do today , need to run with out tonight for base test and then change for Fridays club race .
Any driver can copy a great set up, a Champion however will steal it .
If Jesus returned as a Rc car he be a Rc10 B5M
George W. Cherry
Wild Cherry is offline   Reply With Quote
Old 05-06-2014, 08:02 AM   #4130
Send a message via ICQ to JiuHaWong
Originally Posted by Wild Cherry View Post
... & heavy duty sc 10 slipper spring.
part #?
오늘의 청소년들이 미래의 문제를 처리 할 준비가 병 슬프게도 있습니다 우려하고있다.
JiuHaWong is offline   Reply With Quote
Old 05-06-2014, 09:24 AM   #4131
Trader Rating: 22 (100%+)
tlr does fit but maybe a little too long when compressed. ae is flat at the end and tlr is round. just need to shave flat like ae one and/or add an o-ring to the shock shaft so it doesn't compress all the way down.
JVilla is online now   Reply With Quote
Old 05-06-2014, 09:30 AM   #4132
Update:
How do you remove 1mm from bumpsteer? Right now there are no washers under the stud (at least stock setup) are you talking about on the rack (adjusting Ackerman)
On the rear camber links are u using the alum brace with with 4mm on the low side. (that would be +2 from stock)
thanks
Sponsers: Schumacher, Santiam Hobbies, Fantom Racing, Racing-cars.com, Flawless RC, Discountrcstore.com
Theroc is offline   Reply With Quote
Old 05-06-2014, 09:37 AM   #4133
Tech Legend
thanks
have to grind 1 mm off the steering knuckle , leave Ackermann the same
Yes ,using 4mm on the low side with the alloy rear camber brace.
George W. Cherry
Old 05-06-2014, 09:42 AM   #4134
Thanks!
Old 05-06-2014, 11:50 AM   #4135
Mason's Avatar
I'm glad I'm not the only one with the bump steer issue. I considered flipping the steering arms around, just haven't had the time to mess with it. Not sure if spacers would fit down in the nut cavity naturally or not.
Mason McCombs
NewRed Hobbies & Indoor Facility
Off-Road, Dirt Oval, Crawlers & Pullers
Mason is offline   Reply With Quote
Old 05-06-2014, 11:52 AM   #4136
Mason's Avatar
So far the only "problem" i have had with my b5m is the spring slightly jumped off the lower cup. No mechanical failures yet. Just need to start using chassis protectors!
Mason McCombs
Old 05-06-2014, 02:03 PM   #4137
Cridd's Avatar
Trader Rating: 16 (100%+)
What problems are you feeling?
Chris
B6D / T5M / SC5M
Cridd is offline   Reply With Quote
Old 05-06-2014, 04:17 PM   #4138
rigor's Avatar
Trader Rating: 37 (100%+)
Doesn't 4mm on the low side of the aluminum rear ballstud mount just equal to if you ran it on the built in +2 high side ? I know using 2mm washers on the low side puts it at "zero" (like plastic mount with no washers).
* Jesse H. *
rigor is offline   Reply With Quote
Old 05-06-2014, 04:45 PM   #4139
Yes that is correct I think he didn't want to flip the bracket or something. You can achieve the same height if you flip the bracket with no spacers.
Low side -2mm
High side +2mm
This is what I got from reading previous posts about the alloy camber block.
leskai is offline   Reply With Quote
Old 05-06-2014, 05:11 PM   #4140
Send a message via AIM to slappomatt
Originally Posted by Jake S View Post
so I was right? the pic doesnt show anything different IMO. Just higher shocks.
slappomatt is offline   Reply With Quote
