    Hide Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree6Likes
Old 05-05-2014, 02:03 PM   #4111
Default Just finished my build
I thought the b5m build went together rather nicely. Only a few things concerned me. One were the dog bones. It seemed that the molding for the pin wasn't centered in the manufacturing process so if I insert it into the outdrive one way it binds like hell but if i flop it 180 degrees it fits but with a slight wobble (even tried other outdrive still did the same and it was only one dog bone not both). My second issue I had were the stock turnbuckles. IMO they are junk. The lengths on them are wayyyyy to long. You end up having to bury the threads so far into the tie-rod end that you can't even make adjustments to camber or toe with out the damn things popping off. Since they are so tightly buried into the tie-rod end it also acts like a clamp on the ball stud. So that once free moving ball cup, becomes tight with binding once everything is adjusted to where it should be.
With that said everything else in the build went together flawlessly. I contacted AE about replacement dogbones since it has been an issue with other customers and they said they will replace for free! Awesome! As for the turnbuckles I don't know what I am going to do. Probably find me some shorter length ones or perhaps contact AE again to let them know whats going on.
leskai is offline   Reply With Quote
Old 05-05-2014, 02:24 PM   #4112
gticlay's Avatar
Yeah, if you get Lunsford Ti turnbuckles you won't have that problem. See the pic of mine a page or 2 back and you'll see what I mean.
gticlay is offline   Reply With Quote
Old 05-05-2014, 02:31 PM   #4113
Tech Legend
Wild Cherry's Avatar
[QUOTE=bilster44;13239118]But Cherry you are stating something that is just not true...and that in itself will mislead people. I'm done with this.[/QUOTE
forgive me for trying
What I posted was true ...
Or ?
Some of the ball cups must have defects..
Standing by my word..
The ball cups are not defective and the proof they are good is ...
A shorter rod will never bind the cups & will be smooth ....
Any driver can copy a great set up, a Champion however will steal it .
If Jesus returned as a Rc car he be a Rc10 B5M
George W. Cherry
Wild Cherry is offline   Reply With Quote
Old 05-05-2014, 02:47 PM   #4114
Tech Legend
Of course, my shop doesn't have greys [/QUOTE]
Trcr has lots of um. ha !
Don't waste the time with searching for another brand.
Instead suggest to start with green rear & white front & wait for some greys to try later.
George W. Cherry
Old 05-05-2014, 03:23 PM   #4115
Trader Rating: 85 (99%+)
First ever Associated build and the quality seems pretty decent. Although the diff thrust bolt included in the kit didn't have any threads on the end of it, run to the hobby shop and that was taken care of. Definitely waiting for the lunsford turnbuckles to get back in stock at Amain, used chapstick on the stockers and adjustments still aren't very easy with the cups popping off.
WideOpenThrottle RC is offline   Reply With Quote
Old 05-05-2014, 04:01 PM   #4116
aeMatt's Avatar
So proud of the B5M build I recently finished
Team Associated\\\\\\Reedy\\\\\\JConcepts\\\\\\Airtronics\\\\\\Upgrade RC
www.rc10.com/www.jconcepts.net/www.airtronics.net/www.upgrade-rc.com
aeMatt is offline   Reply With Quote
Old 05-05-2014, 04:36 PM   #4117
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
Originally Posted by Fabulous View Post
To cut the weight down; Titanium screw kit, AE aluminum top shaft, Schelle slipper eliminator. remove battery strap, thumb screws & foam, cut out all braces behind servo, between battery post, and triangle sections next to tranny mount. AKA Typo tires. Oh yea and the dog bones were polished chrome to make it go faster.
Wow, never thought of polishing my dog bones, no wonder why you were so fast this past weekend! Congrats again on a job well done.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 05-05-2014, 06:03 PM   #4118
Default The New Buggy
This is my new ride finished painting the other day can't wait to hit the track!
Old 05-05-2014, 07:40 PM   #4119
Tech Legend
@ the track, switching to twin slipper after running the triple for the start.
Also removed 1mm bump steer.
Lets guys know how it goes later.
George W. Cherry
Old 05-05-2014, 08:28 PM   #4120
Tech Legend
Did not get to removing the bump steer.
Did learn alot about the slipper.
Twin or triple the biggest change in performance is the spring you choose.
Springs
B5 very soft
Sc 10 very hard
for the first 6 packs been fighting a loose slipper no matter how tight I adjusted.
switched to the stiffer slipper spring and now accelerates more Betta .
George W. Cherry
Old 05-05-2014, 08:47 PM   #4121
Fabulous's Avatar
Trader Rating: 42 (100%+)
Originally Posted by bigcracing View Post
Ran my mid motor this weekend in stock and was awesome but I was struggling with front bite. Any suggestions to get more front end bite Seemed to push through the corners. Other than that it was awesome to drive made me look good. Great buggy to build also
Thanks Chris.
Try the straight front arms with shock tower, 3mm trailing axle setup and
caster block bushing, offset p#91403. currently using this setup and has smooth entry, mid and exit steering.
22 4.0 - Mod
22 3.5 - Stock
22-4 2.0 - 13.5
8ight E 4.0
Fabulous is offline   Reply With Quote
Old 05-05-2014, 08:52 PM   #4122
Fabulous's Avatar
Originally Posted by xTotalghost View Post
How does the battery stay in place
3M double sided tape
22 4.0 - Mod
22 3.5 - Stock
22-4 2.0 - 13.5
8ight E 4.0
Old 05-05-2014, 09:17 PM   #4123
Send a message via AIM to slappomatt
This is something else I have been wondering about. assuming the pin angles and locations are the same, changing from the gullwings to straights would only raise the shocks slightly on the car raising the CG. seems like a negative to me. are the angles different?
slappomatt is offline   Reply With Quote
Old 05-05-2014, 10:13 PM   #4124
Jake S's Avatar
Trader Rating: 65 (92%+)
Send a message via AIM to Jake S Send a message via MSN to Jake S
VooDoo Racing Cells | Flying Farmer RC | Trackside Hobby | Prochko Paintz | RG1
Jake S is offline   Reply With Quote
Old 05-06-2014, 06:58 AM   #4125
bigcracing's Avatar
Trader Rating: 32 (100%+)
Bushings that you are referring about the bronze ones are they zero and five degrees? They are not available yet I have the plastic ones. I installed the 5 degrees should I go to the 0 degrees?
Thanks Chris
bigcracing is offline   Reply With Quote
Currently Active Users Viewing This Thread: 4 (0 members and 4 guests)
