    Hide Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree6Likes
Old 05-04-2014, 11:08 PM   #4081
Originally Posted by slappomatt View Post
lol its stock racing. You need every single upgrade ever made. and then get out the dremel and cut everything in half. Thats how the stock guys are around here.
seriously though its a fairly heavy car. anything to shed weight would help. Al screws, ti turnbuckles, alum top shaft and one of the lighter slipper alternatives is where I would start.
I was looking at mine tonight and kinda want to have a buddy lathe some of the metal out of the one piece front axles.
Jakelopez is offline   Reply With Quote
Old 05-04-2014, 11:13 PM   #4082
MaricopaAgent's Avatar
Trader Rating: 27 (100%+)
My kid drives it.. and yes, One front bulk head and nothing else.. Not the only one I have seen broke.
MaricopaAgent is offline   Reply With Quote
Old 05-05-2014, 03:45 AM   #4083
Fabulous's Avatar
Trader Rating: 42 (100%+)
Originally Posted by Jakelopez View Post
Can some one give me a list of upgrades for stock racing
To cut the weight down; Titanium screw kit, AE aluminum top shaft, Schelle slipper eliminator. remove battery strap, thumb screws & foam, cut out all braces behind servo, between battery post, and triangle sections next to tranny mount. AKA Typo tires. Oh yea and the dog bones were polished chrome to make it go faster.
Official Team Associated RC10 B5m Mid-Motor Thread-b5m.jpg   Official Team Associated RC10 B5m Mid-Motor Thread-b5m2.jpg
22 4.0 - Mod
22 3.5 - Stock
22-4 2.0 - 13.5
8ight E 4.0
Fabulous is offline   Reply With Quote
Old 05-05-2014, 03:53 AM   #4084
anyone know where to buy most affordable titanium screws or screw kit? add mpi puck system to above list.
Micah123 is offline   Reply With Quote
Old 05-05-2014, 08:05 AM   #4085
bilster44's Avatar
The Typos you have on are why your car is illegally lite too. If you had golds on, you would be in the 1520's to 30's.
"Let Your Racing Speak"
bilster44 is offline   Reply With Quote
Old 05-05-2014, 08:20 AM   #4086
gticlay's Avatar
Originally Posted by Wild Cherry View Post
http://2wdmod.com/2014/04/29/schoett...concepts-trcr/
Starting with this..
Cept was advised to change to 4mm under rear chassis stud.
Also not using the Kyosho springs.
Instead using Ae grey front & Ae white rear...
So, you are using the plastic rear inner camber plate plus 4mm ballstud spacers or the aluminum +2mm or the aluminum +4mm (like +6mm on plastic)?
gticlay is offline   Reply With Quote
Old 05-05-2014, 08:29 AM   #4087
suby723's Avatar
Trader Rating: 21 (100%+)
Will the c4.1 finisher body fit the b5m correctly?
suby723 is offline   Reply With Quote
Old 05-05-2014, 08:42 AM   #4088
Tech Legend
Wild Cherry's Avatar
[QUOTE=gticlay;13238356]So, you are using the plastic rear inner camber plate plus 4mm ballstud spacers or the aluminum +2mm or the aluminum +4mm (like +6mm on plastic)?[/QUOTE
Using the alloy camber mount .
Just 4mm, did not flip over camber mount.
Tip
There's a new camber location info for rear. Will post when I get the new alloy hubs later this week.
The dweebs may be trollN after I post the info , can you remember BK's Sc10 4x4 camber mod ?
Today I'm burying my sensor wire under the batteries and breaking un a fresh set of Jc Dirt Webs.....
My ride is the best car I have ever driven.
Yesterday was its first runs.
Any driver can copy a great set up, a Champion however will steal it .
If Jesus returned as a Rc car he be a Rc10 B5M
George W. Cherry
Wild Cherry is offline   Reply With Quote
Old 05-05-2014, 08:46 AM   #4089
What are ur gearing for 17.5 I'm running 69/33 and it's feels like I don't have much top or top speed
xTotalghost is offline   Reply With Quote
Old 05-05-2014, 08:57 AM   #4090
gticlay's Avatar
[QUOTE=Wild Cherry;13238427]
Tip
Noooo, I don't want my car to look like that!
Old 05-05-2014, 09:06 AM   #4091
gticlay's Avatar
BTW, here's my build so far. I decided to spend a little money on a nice paint job this time around instead of neon green spraybomb. Have my 4wd painted the same.
Old 05-05-2014, 09:06 AM   #4092
Tech Legend
But you'll have a much nicer rear hub design.
Bridgewater has all the newest modifications.
We were testing all Sat afternoon.
Paint is very good...
George W. Cherry
Old 05-05-2014, 09:30 AM   #4093
bilster44's Avatar
Your car looks real nice! Question: Why doesn't Lunsford make turn buckle kits that will allow the threads to bury all the way? Even the kit "steelies" will bury the threads, because they are 2" long.
Old 05-05-2014, 09:35 AM   #4094
Wildcat1971's Avatar
Trader Rating: 80 (100%+)
my 1 7/8 bury in all the way. Imo 1 3/4 is probably the best length. burying the treads makes setting camber more resistant.
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 05-05-2014, 09:36 AM   #4095
gticlay's Avatar
Because the ballcups were getting so tight that they would pop off when you tried to adjust them later. So they shortened them up just a little bit. There's still a ton of engagement but, for example, when I go to adjust (on my RM) later, they make that little snapping sound from being tight but the ballcups don't pop off.
Also, they do make a kit with all 2" links if you want them to go all the way in.
