    Hide Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree9Likes
Old 04-28-2014, 08:19 PM   #3901
you should just build the car.. it only takes 10-15 minutes to change out the front end parts when you get them.. then you can compare the 2 front ends.
personally I like the gull wing better as its a little quicker reacting. but again its not the arms its the tower that makes the difference, but you have to use the gull tower with the gull arms and same with rmb5 tower and arms.
rickster is offline   Reply With Quote
Old 04-28-2014, 10:54 PM   #3902
Cridd's Avatar
Trader Rating: 16 (100%+)
I like the gull wings myself, but a lot of good things said about the flat arms.
Chris
B6D / T5M / SC5M
Cridd is offline   Reply With Quote
Old 04-29-2014, 12:07 AM   #3903
So the B5M and B5 come with different springs in the kit? My B5 came green fronts, white rears. I just got 2 B5Ms in the mail and both have green rears, white fronts.
SDRC
Associated
TLR
Tekno
uclabruins89 is offline   Reply With Quote
Old 04-29-2014, 02:32 AM   #3904
Originally Posted by Wildcat1971 View Post
A while probably. No date was given by AE. My guess is later this year or next year "if" they release one. People waiting for the FT to buy the kit crack me up. Aside from Ti turnbuckles the current kit is fine. I dislike the AE TI turnbuckles, so I would most likely replace them with lunsfords on the FT kit when it comes out. Unless your racing stock, the kit is fine as is. For stock, your spending has just started and even the FT wont have what you need. In fact, the FT kit will be even heavier because of the alum parts. IMO the alum parts are for durability, but the car does not really seem to be weak anywhere accept maybe the rear inner ballstud mount. That might be the only "required" bling.
Thanks for your feedback
racer
racer_hh is offline   Reply With Quote
Old 04-29-2014, 04:13 AM   #3905
gticlay's Avatar
They should be different, yes.
gticlay is offline   Reply With Quote
Old 04-29-2014, 07:48 AM   #3906
Tech Legend
Wild Cherry's Avatar
Liked the car with the flat arms ,driven it with both...
Any driver can copy a great set up, a Champion however will steal it .
If Jesus returned as a Rc car he be a Rc10 B5M
George W. Cherry
Wild Cherry is offline   Reply With Quote
Old 04-29-2014, 07:56 AM   #3907
BillPear's Avatar
Send a message via Yahoo to BillPear
Originally Posted by Micah123 View Post
Seems a bit harsh mate. Try being nicer next time. Life is so short.
That question has been asked and answered MORE THAN ONCE, in this thread! If he cant be bothered to search for it, I cant be bothered to answer it.
Life is to short to suffer laziness.
BillPear is offline   Reply With Quote
Old 04-29-2014, 08:07 AM   #3908
Konich's Avatar
So is the general consensus for high bit clay the following?
-B5R Flat Front Arms
-B5R Front Shock Tower
-B5R Rear Arms flipped with .5mm spacers
-Shorty pack
Thanks!
Tresrey Spec DEX410 - Yaiba Spec B5M
Konich is offline   Reply With Quote
Old 04-29-2014, 08:09 AM   #3909
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 156 (100%+)
5mm spacers? All the rest looks good.
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 04-29-2014, 08:32 AM   #3910
rigor's Avatar
Trader Rating: 37 (100%+)
-B5R Rear Arms flipped with 5mm spacers
-Shorty pack
Thanks!
The first two items go hand in hand; don't do one w/o the other.
5mm spacing ? No. Get the arms and you'll see no spacing is needed, aside from maybe some small shimming forward if you are running the plastic arm mounts.
* Jesse H. *
rigor is offline   Reply With Quote
Old 04-29-2014, 08:40 AM   #3911
Trader Rating: 18 (100%+)
Originally Posted by BillPear View Post
I know, you'd know too, if you would read the thread.
It would've taken less effort to answer the question, and you'd save someone the hassle of having to sift through 200+ pages of this thread. A little bit of civility makes this place a lot more enjoyable.
Sorcerer001 is offline   Reply With Quote
Old 04-29-2014, 08:46 AM   #3912
Super Moderator
Seriously....There is a little search button on the top of this thread, it will only search in this thread. Just type "factory team" and view the responses. You can only answer a question 37 times before it gets old.
Here, i did it for you:
http://www.rctech.net/forum/search.p...rchid=18310695
Old 04-29-2014, 08:53 AM   #3913
Konich's Avatar
Sorry I meant .5mm spacers as it looks like from what others are saying it takes a little shimming forward to switch the rear arms out.
Old 04-29-2014, 08:56 AM   #3914
Send a message via ICQ to JiuHaWong
Or someone can just post the information on the first page. Something like:
THERE IS NO ETA ON THE FACTORY TEAM KIT.
오늘의 청소년들이 미래의 문제를 처리 할 준비가 병 슬프게도 있습니다 우려하고있다.
JiuHaWong is offline   Reply With Quote
Old 04-29-2014, 09:03 AM   #3915
Tech Legend
yes !!
friendly & more help forever....
George W. Cherry
