    Hide Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree7Likes
Old 04-27-2014, 09:56 AM   #3856
Tech Legend
Wild Cherry's Avatar
Originally Posted by uclabruins89 View Post
Whats the best lubricant to use on the gears inside the transmission case for minimum friction, i'm running stock class.
I have permatex white lithium grease, plus the normal RC greases.
Use Krytox from Dupont.
Lithium, slime, clear diff lube all dry up & bake from the heat , clogs up between the teeth .
Oil works better then above , but the Krytox stays clear and with stands the heat with no problems..
Any driver can copy a great set up, a Champion however will steal it .
If Jesus returned as a Rc car he be a Rc10 B5M
George W. Cherry
Wild Cherry is offline   Reply With Quote
Old 04-27-2014, 10:02 AM   #3857
Send a message via ICQ to JiuHaWong
edit: Which grease, there seems to be a few types...
오늘의 청소년들이 미래의 문제를 처리 할 준비가 병 슬프게도 있습니다 우려하고있다.
JiuHaWong is offline   Reply With Quote
Old 04-27-2014, 10:59 AM   #3858
Originally Posted by aeRayls View Post
AE alum rear hubs:
Mid car=etching to the rear
Rear car=etching to the front
Do you or anyone know what hole and ball stud spacing I would need to use to equal the old set up were I had the two hole insert outer hole B
splking1 is offline   Reply With Quote
Old 04-27-2014, 11:46 AM   #3859
Phelps's Avatar
Which product are you using Cherry?
Vision Racing, Lunsford Racing, Sick Graphics, 541 RC.
www.visionracing.net
Phelps is offline   Reply With Quote
Old 04-27-2014, 12:01 PM   #3860
aeRayls's Avatar
For the 2 hole insert? No... However, just install the hubs and screw the ballstud into a hole that gives you the same camber setting.
Team Associated~Reedy~LRP~XP Digital~JConcepts~92zero Designs~Big Horn Designs~
Go that way really fast... if something gets in your way... TURN!
aeRayls is offline   Reply With Quote
Old 04-27-2014, 12:08 PM   #3861
Yeah thats a good idea but I would have to reinstall the old hubs. That was going to be my last resort. Was hoping someone knew the setup. AE didn't even know when I called.
Old 04-27-2014, 01:06 PM   #3862
Leodis's Avatar
Trader Rating: 16 (100%+)
I've been out of racing for about a year and decided I'd get back into it with a new build, but I can't decide on whether to get a B5 or B5M and I don't want to get both of them. I plan to race mod buggy on a small clay indoor track with tight turns and medium-to-high grip. I've had every version of RC10 since the original gold tub chassis and I tend to throw my buggies around the track so I'm leaning towards the B5, but B5M's have been selling like hotcakes at the local track this week. Any feedback would be appreciated.
Leodis is offline   Reply With Quote
Old 04-27-2014, 01:18 PM   #3863
suby723's Avatar
Trader Rating: 21 (100%+)
Get the b5m its a fantastic car. If you can't get it dialed in you can get the ae conversion kit to make it the rear motor car.
suby723 is offline   Reply With Quote
Old 04-27-2014, 01:30 PM   #3864
Tech Legend
240 ac
remember it says something like high performance lube on the tube.
A white grease in appearance.
After you get some you will appreciate , best I'v used so far..
I stole a small amount (bearing tube worth ) from my team mate Michael S.
I will try to get part # and post later.
YIkes ! That's right $240 for a tube..( aero space grade)
George W. Cherry
Old 04-27-2014, 01:34 PM   #3865
rigor's Avatar
Trader Rating: 37 (100%+)
"clay indoor track with tight turns and medium-to-high grip"
Get a B5m. You won't be disappointed once setup well.
* Jesse H. *
rigor is offline   Reply With Quote
Old 04-27-2014, 01:37 PM   #3866
rigor's Avatar
which camber link location is a good start for the rear aluminum hubs?
You want 3mm shim under the ballstud on the aluminum hub, back row, up to you whether inside or outside hole.
Based upon recent setup sheets and photos, Both Hartson and Jarosz are running with a 3mm shim on the hub, and my understanding is that provides the same height as top row standard hub insert.
* Jesse H. *
Old 04-27-2014, 01:53 PM   #3867
seth556's Avatar
Trader Rating: 42 (100%+)
240 ac
I think I'll stick with diff lube for now...
seth556 is offline   Reply With Quote
Old 04-27-2014, 01:54 PM   #3868
240 ac
http://www.amazon.com/DuPont-Krytox-...s=krytox+240ac
I'll stick to a small dab of diff lube on each gear!
Old 04-27-2014, 02:39 PM   #3869
Tech Legend
worst lube you can choose, in just one pack the clear turns it into black guke in-between teeth.
A oil will out perform.
All about heat & pressure .
Difficult to find a lube that works because of the loads these gears perform under.
Understanding what happens when you use clear is important though.
George W. Cherry
Old 04-27-2014, 02:50 PM   #3870
Chief's Avatar
Trader Rating: 14 (100%+)
So... What's the next best lube
____________
TC6
B4.1
FT SC10
Chief is offline   Reply With Quote
