    Hide Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree7Likes
Old 04-14-2014, 08:47 PM   #3526
Tech Legend
Wild Cherry's Avatar
Lol
All I get is " you don't have your B5 yet " ?
A cruel joke ....
Any driver can copy a great set up, a Champion however will steal it .
If Jesus returned as a Rc car he be a Rc10 B5M
George W. Cherry
Wild Cherry is offline   Reply With Quote
Old 04-14-2014, 08:49 PM   #3527
rigor's Avatar
Trader Rating: 37 (100%+)
Originally Posted by evolution03 View Post
thanks for the confirmation So that means the maifield warehouse setup would be like using the the plastic ball stud mount with no spacers.
Which is a dialed setting, always been my preference. That and I like the inside rear shock tower mounting hole as well.
I drove my B5m today with the B5 rear arms, shimmed forward. Rear is totally planted. Had a great day at the track
* Jesse H. *
rigor is offline   Reply With Quote
Old 04-14-2014, 08:49 PM   #3528
rigor's Avatar
Originally Posted by Justinb86 View Post
I have the ryobi cordless screwdriver. The only downfall is it does not have a setting as low on the slipper setting that goes low enough for me.
I ended up picking up the dewalt Gyroscptic cordless screwdriver. On the lowest setting it usually won't even screw the bolt in all the way on my Rc cars. So u don't have to worry about stripping out the plastic or aluminum threads. At the same time it has more power overall tho. Best of both worlds.
The gyro feature is odd and takes a bit to get used to. U don't have a forward or reverse. Or even a speed setting. U pull the trigger and turn the gun the way u want to go. The farther u turn the faster it goes. Simply turn it the opposite direction to reverse and again the farther u turn the faster it goes. It's just like using a hand tool the way u normally would. It does still have 15 slipper settings.
The other model I would concider is the Hitachi cordless screwdriver. It's just as adjustable with standard controls.
Both are more than the ryobi. But worth it to me. I have 5 cars. Saves a lot of time. I keep it on a low setting and tighten the last bit by hand to prevent stripping anything.
Thanks for the detailed insight on this. I'll look into the others before doing anything.
* Jesse H. *
Old 04-14-2014, 08:58 PM   #3529
Suspended
Originally Posted by lbckevin View Post
Rudy doesn't own a mid motor....still on back order
I could have sold him one of my 3
Pimp Formally Known as OG
PFKAOG is offline   Reply With Quote
Old 04-14-2014, 09:08 PM   #3530
Jason Turner's Avatar
Trader Rating: 63 (100%+)
Wow cool that's a pic of my car! Seems to be working pretty good. Here's A pic of the outside!
Originally Posted by rigor View Post
3M or Scotch Outdoor Mounting Tape. It's a red & gray roll. Stuff is fantastic. Super strong, rolls off completely clean by finger. Only like $8 for a huge roll that'll last you years.
I'm going to be changing my electronics configuration today as well, but I need to do be able to swap out between 2 lipos while at the track. So I'll be doing the following like the attached pic.
Jason Turner is offline   Reply With Quote
Old 04-14-2014, 09:09 PM   #3531
rigor.. I run the alloy rear mount with the -2 deg. side and no spacers.. for outdoors it really smooth's out the rear and plenty of traction when you have the rear arms all way forward with spacer.. even on dry dusty tracks.
rickster is offline   Reply With Quote
Old 04-14-2014, 09:12 PM   #3532
No problem. Spend the money on a good one and u won't regret it. If u turn wrenches a lot ur gonna kick Ur self for not doing it sooner.
Justinb86 is offline   Reply With Quote
Old 04-14-2014, 09:57 PM   #3533
rigor's Avatar
Sorry Jason. I didn't even think about being certain who's car this was and crediting them here. I was just excited to see it. I had just thought of it the night prior to going to sleep. Then BOOM! There's your car! Hah
Nice job
* Jesse H. *
Old 04-14-2014, 10:34 PM   #3534
rigor's Avatar
Yeah that makes sense. I run med to high bite indoor clay, and the 0 washers setting seems to be really good for me with the rest of my rear suspension setup.
* Jesse H. *
Old 04-15-2014, 07:00 AM   #3535
Carranza76's Avatar
Originally Posted by gticlay View Post
Of note: stock buggy winner was a Rear Motor B5.
Correct, I have known Rudy since he started racing RC, good kid and great parents.
Imagine how fast he will be with a mid motor once he gets it dialed in. In all honesty I dont think he needs to switch to MM but who knows for sure.
Pegasus Raceway
IERC Raceway
TLR & Tekin are my main squeeze's!
Yokomo BD7
Carranza76 is offline   Reply With Quote
Old 04-15-2014, 07:19 AM   #3536
Send a message via ICQ to JiuHaWong
Default New B5M body
http://www.redrc.net/2014/04/sweep-b...zle-bodyshell/
오늘의 청소년들이 미래의 문제를 처리 할 준비가 병 슬프게도 있습니다 우려하고있다.
JiuHaWong is offline   Reply With Quote
Old 04-15-2014, 07:32 AM   #3537
Stanfsu's Avatar
Trader Rating: 294 (100%+)
Send a message via Yahoo to Stanfsu
Nice Body
Losi | Futaba
Low Ballers will be ignored!
Stanfsu is offline   Reply With Quote
Old 04-15-2014, 07:41 AM   #3538
SilentHunter's Avatar
Originally Posted by Stanfsu View Post
Nice Body
+1 looks nice! Can you get these in the US?
SilentHunter is offline   Reply With Quote
Old 04-15-2014, 08:45 AM   #3539
Wade....'s Avatar
Default Stock Buggy Carpet Setup
Just sharing my carpet setup for anyone interested.
Small indoor carpet astroturf, wooden medium size jumps. More grip than you can deal with. Most tuning is to take away grip.
Tires: Dboots Terrabyte A Comp Front (inner and outer row of pins trimmed off), Dboots Nanobyte A Comp Rear
Everything kit setup except:
white springs 1.6 piston 32.5 oil all 4 shocks
Shorty battery full forward
3mm spacer under rear inner link (+1mm from kit)
RTR Weight ~1560g.
21mm ride height
Can drive super hard due to being very safe, no rolling issues at all. So fun!
Wade Huesman, TCORC Secretary/Pencil Pusher
Wade.... is offline   Reply With Quote
Old 04-15-2014, 09:49 AM   #3540
gticlay's Avatar
Originally Posted by Wild Cherry View Post
Lol
A cruel joke ....
Poor WC. Is this your Centro in the video?
+ YouTube Video
gticlay is offline   Reply With Quote
