    Hide Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree9Likes
Old 04-13-2014, 07:17 AM   #3481
pumpkinfish's Avatar
Originally Posted by Wildcat1971 View Post
You pretty much just need to get the car close and drive accordingly. Mixed traction sucks and from my experience, even more so in MM.
That is what I did and finished 3rd. I just lost so much time trying to keep it going the right direction while the rear motor guys were just beating their cars like mules, lol So it seems I did all I can do. I did try saddle packs compared to my shorty and the car felt a little better. I'm thinking I may try Hartson's electrics layout first to see how the car reacts.
pumpkinfish is offline   Reply With Quote
Old 04-13-2014, 07:54 AM   #3482
rigor's Avatar
Trader Rating: 37 (100%+)
Originally Posted by fdpRASTA View Post
Thanks. I see another few people have also now confirmed this is good to go. This is the one I had my eye set on, but just wanted confirmation before pursuing.
* Jesse H. *
rigor is offline   Reply With Quote
Old 04-13-2014, 08:02 AM   #3483
celt's Avatar
Don't be so hard on yourself...
That's 2WD buggy racing in general. Whenever traction is in question, they all get more sketchy to drive, that's just the way the class works. I think a person has to like that round by round challenge. Most every track changes from heat to heat. Here in the Midwest, it can change drastically. A tire that was stunningly good the previous round, can almost be unusable the next. rarely do you have a chance to test in between heats when the program continues through rotation.
I've started paying close attention to the color of the surface. I make a note of it when I do my first run. Usually darker is more moisture and lighter less - sometimes that's all you've got. The rest of the time? Throttle control and wheel it...
"Soon they will get everything they deserve. This isn't about trite elitism, but the otherwise intellectual and educated classes refusing to think for themselves. I call it situational ignorance, and painfully intolerable."
Stan Garvin
celt is offline   Reply With Quote
Old 04-13-2014, 08:03 AM   #3484
rigor's Avatar
Originally Posted by slappomatt View Post
really diggen that modified battery tray as I plan to only run shorties and hate all the electronics jammed up front with wires everywhere. How is he doing battery hold down now?
3M or Scotch Outdoor Mounting Tape. It's a red & gray roll. Stuff is fantastic. Super strong, rolls off completely clean by finger. Only like $8 for a huge roll that'll last you years.
I'm going to be changing my electronics configuration today as well, but I need to do be able to swap out between 2 lipos while at the track. So I'll be doing the following like the attached pic.
* Jesse H. *
Old 04-13-2014, 08:28 AM   #3485
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
i like that version with the battery strap.
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 04-13-2014, 08:32 AM   #3486
predu's Avatar
That's how mine is, been working good for a month now.
SC10.2 , LRP, SCHUURSPEED 17.5
B4.2, LRP, SCHUURSPEED 17.5
TC6.1, LRP, SCHUURSPEED17.5
TC7 , LRP, SCHUURSPEED 17.5
10R5.1, H/W, SCHUURSPEED 17.5
predu is offline   Reply With Quote
Old 04-13-2014, 08:34 AM   #3487
What is the gray "stuff" sitting in the chassis and where do you get it?
DWill is offline   Reply With Quote
Old 04-13-2014, 10:45 AM   #3488
This is exactly how our C4.2's electronics are set up and I think it works great. With 12 grams between the battery and motor goo'd to the chassis the cars are planted in most any indoor clay condition (wet, dry, blue groove, mixed traction) and turn hard with the right tires.
34x17 is offline   Reply With Quote
Old 04-13-2014, 11:43 AM   #3489
rigor's Avatar
The battery foam ? AE gives you 1 large and 2 thin pieces right in the B5m kit. You can also buy extra if you need to from a number of sources. It's just stiff foam
* Jesse H. *
Old 04-13-2014, 04:04 PM   #3490
When using this 3m tape make sure to clean both surfaces with motor spray. Then use a heat gun or hair dryer to heat the tape and surface it will be going on. It will adhere WAY better if its warm. It will hold longer too.
Be careful not to damage anything with the heat gun. Run it on low and use common sense. Have not had any of my electronics fall out since I started taking the extra time and effort to do that.
Justinb86 is offline   Reply With Quote
Old 04-13-2014, 04:39 PM   #3491
rigor's Avatar
I've always cleaned the surfaces with rubbing alcohol or motor spray / brake cleaner... but never used a heat gun. I've never had anything even remotely come loose with that stuff. In fact, it's still quite difficult to get back out. I usually have to use an X-acto knife or real small flathead screwdriver (like for eye glasses size) and get under the mounted equipment to get it loosened up to be able to pry out by hand. I might have to try heating it up to see any difference. Tough stuff no matter what
* Jesse H. *
Old 04-13-2014, 04:43 PM   #3492
I have used the heat gun to warm the surfaces and tape. Helps for sure in the colder months
Old 04-13-2014, 04:49 PM   #3493
Need to purchase a square battery. I know that Reedy and SMC makes them, any others?
MugenMan99 is offline   Reply With Quote
Old 04-13-2014, 05:21 PM   #3494
Logi Maker's Avatar
Trader Rating: 49 (100%+)
http://www.superiorhobbies.com/istar...RIREV2027-5!SH
That's $25 less than Stormer!
Kyle Predmore
FB AE Fanboy/Insta @ae_fanboy
Sticky Kicks RC\Prolevel RC\MIP\Schelle
Logi Maker is offline   Reply With Quote
Old 04-13-2014, 06:24 PM   #3495
rigor's Avatar
Just get the SMC. You're overpaying for anything else, IMO. Lipos have the biggest and craziest of markup pricing in RC. I just got 2 SMC shortys for like $80 shipped and they are great so far
* Jesse H. *
