    Hide Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree6Likes
Old 04-11-2014, 08:49 AM   #3421
Originally Posted by adam lancia View Post
Raise the rear ride height and lower the front so you're at a 1mm split biased to the rear (rear higher). To go along with that, I would add another limiter to the front shocks to keep the weight on the front end. Unless you have tried those things already, then kindly disregard
To be honest i havent tried that. Was to caught up in trying everything else. Ill give that a go. Was running 24 mm front and back
splking1 is offline   Reply With Quote
Old 04-11-2014, 09:01 AM   #3422
Here is what it looks like under the hood
Old 04-11-2014, 10:12 AM   #3423
racer_guy's Avatar
since there are alot of settup questions, here is a link i found that explains in great detail what each adjustment does. i found it very helpfull considering it has been many years since i have raced. hope it enlightens some as it did me...
http://www.hudy.net/xhudy/products/p...81&kategoria=0
W.E.D. Winning Edge Designs
racer_guy is offline   Reply With Quote
Old 04-11-2014, 10:14 AM   #3424
racer_guy's Avatar
how did you take off the front body mount? dremel? pliers?
Old 04-11-2014, 10:17 AM   #3425
lbckevin's Avatar
Trader Rating: 89 (99%+)
Just dremel the front body mount / nipple off
Kevin Smith
Hobbywing * Pro-Line * MIP * Paint Monster
lbckevin is offline   Reply With Quote
Old 04-11-2014, 10:51 AM   #3426
Yep that's what I did. Also dremaled out all the channels
Old 04-11-2014, 11:00 AM   #3427
racer_guy's Avatar
seems that bk was running an unusual rear wing at cactus...jconcepts prototype??
http://events.redrc.net/event-galler...c/?nggpage=10#
Old 04-11-2014, 11:06 AM   #3428
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 156 (100%+)
Been out for a while now....JConcepts Hi Tension wing
http://www.amain.com/product_info.ph...Wing-66-Wide-2
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 04-11-2014, 11:24 AM   #3429
Mason's Avatar
that would potentially allow the chassis to flex giving more bite to the rear since your weight is there. just another thing to try later on.
Mason McCombs
NewRed Hobbies & Indoor Facility
Off-Road, Dirt Oval, Crawlers & Pullers
Mason is offline   Reply With Quote
Old 04-11-2014, 12:29 PM   #3430
rigor's Avatar
Trader Rating: 37 (100%+)
Parts are trickling in I guess? Just got backorder notification from Amain for B5 Rear arms and HARD caster blocks. I have 4 other items still showing out of stock.
* Jesse H. *
rigor is offline   Reply With Quote
Old 04-11-2014, 12:39 PM   #3431
rigor's Avatar
I just used wire cutters and cleaned it up with an exacto knife. Came out clean and easy.
* Jesse H. *
Old 04-11-2014, 01:10 PM   #3432
Jake S's Avatar
Trader Rating: 65 (92%+)
Send a message via AIM to Jake S Send a message via MSN to Jake S
front hexes from tower to go with the axles i got over a month ago. lol still no rear hexes tho.
VooDoo Racing Cells | Flying Farmer RC | Trackside Hobby | Prochko Paintz | RG1
Jake S is offline   Reply With Quote
Old 04-11-2014, 01:35 PM   #3433
rigor's Avatar
I am running front & rear Proline hexes from my old B4 w/o issue?
* Jesse H. *
Old 04-11-2014, 01:47 PM   #3434
rigor's Avatar
Hartson's setup from the MHOR race last weekend:
http://www.teamassociated.com/pdf/ca...ls_Hartson.pdf
* Jesse H. *
Old 04-11-2014, 01:50 PM   #3435
BIGTIME's Avatar
Trader Rating: 82 (99%+)
I keep hearing if you are running stock and stock only B5R is better.
Is there any truth to that?
BIGTIME is offline   Reply With Quote
