    Hide Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree6Likes
Old 04-08-2014, 12:52 PM   #3286
Next question/comment...
I still cannot get used to these cab forward (IMHO "stealth fighter") bodies. Has anyone heard if there are any "traditional" bodies in the works? Something a little more like the original B4 body?
DropPass is offline   Reply With Quote
Old 04-08-2014, 12:56 PM   #3287
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 156 (100%+)
Originally Posted by DropPass View Post
Been out of the loop for a while, so can you elaborate on why people punch homes in the tires? I image it is partly due to moisture?
Back in the day we used to drill holes in the rims, but we didn't use foam and our tires were never glued so it wasn't as big of an issue.
air does not move through closed cell foams the way it does in open cell. If you dont have holes in the tire with an open cell foam you can trap air between the foam and the tire and it can feel bouncy. just gives another spot for air to go.
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 04-08-2014, 01:06 PM   #3288
Here it is at ready to run with battery.
splking1 is offline   Reply With Quote
Old 04-08-2014, 01:50 PM   #3289
Wildcat1971's Avatar
Trader Rating: 80 (100%+)
is your tire touching the scale? if so, it will throw off the numbers. Also it will be thrown off by not centering the weight on the scale.
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 04-08-2014, 02:07 PM   #3290
3srcracing's Avatar
Trader Rating: 25 (100%+)
While on topic of holes in tires, when do you do it in the rim. And when do you do it on the tire? What difference does it make? Or does it not make a difference?
3srcracing is offline   Reply With Quote
Old 04-08-2014, 02:11 PM   #3291
No its not. Also on this scale it read the same far right or far left or center. I can take another pic if needed but the tires are not touching
Old 04-08-2014, 02:17 PM   #3292
Here is the pic again. I just switched to the titanium shock bolt set up
Old 04-08-2014, 02:25 PM   #3293
my only concern would be the threads sticking out the front of the front tower. more likely to catch on something and snap the tower. I wonder why lunsford made them so long.
Old 04-08-2014, 02:25 PM   #3294
bilster44's Avatar
I believe those bodies are here to stay.
"Let Your Racing Speak"
bilster44 is offline   Reply With Quote
Old 04-08-2014, 02:26 PM   #3295
bilster44's Avatar
Where can I get a milled/machined motor plate? (that is in stock NOW) LOL
Old 04-08-2014, 02:30 PM   #3296
Yeah I totally agree. I'm going to put some ball stud washers behind the nut to take up that slack.
Old 04-08-2014, 02:48 PM   #3297
gticlay's Avatar
He used the wrong nuts. I used the flanged nuts and they are a perfect fit.
gticlay is offline   Reply With Quote
Old 04-08-2014, 02:52 PM   #3298
So your nuts are bigger than his?
Old 04-08-2014, 02:59 PM   #3299
gticlay's Avatar
Definately
Old 04-08-2014, 03:03 PM   #3300
-WHEELMAN-'s Avatar
Trader Rating: 266 (98%+)
Nowhere
BRETT T. RICHARDS = SUPPORT YOUR TROOPS, LOCAL TRACKS AND HOBBY SHOPS OR THEY COULD ALL BE GONE ONE DAY!
-WHEELMAN- is offline   Reply With Quote
