    Hide Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree7Likes
Old 04-07-2014, 11:30 AM   #3256
rigor's Avatar
Trader Rating: 37 (100%+)
Originally Posted by splking1 View Post
I'm running black springs all around. What oils are you running?
Black springs all around? Sounds too soft. The white springs all around is pretty dialed. 1.6 pistons all around is good too. 32/30 oil front/back or 30/27. Should feel pretty good. I like the inner most hole for mounting the rear shocks on the tower, like Maifield's setups have reflected.
EDIT: Note, these setup tips are for indoor clay.
* Jesse H. *
rigor is offline   Reply With Quote
Old 04-07-2014, 11:32 AM   #3257
rigor's Avatar
Originally Posted by Matt Trimmings View Post
Servo Tape.....the good stuff
3M Outdoor Weather tape is bomb. It's gummy and comes off completely clean by finger rolling it. It'll hold lipos down no issue.
* Jesse H. *
Old 04-07-2014, 11:37 AM   #3258
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 156 (100%+)
That's the stuff!
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 04-07-2014, 02:05 PM   #3259
Bcholka's Avatar
Originally Posted by Wild Cherry View Post
Gull wing for lower traction, they tip in more but steer less in the middle & exit.
Flat for high traction
Tip in is smoother , a little more steering in the middle and exit.
+1
2-Tekno EB48.2's, 1-Tekno ET48, 1-Tekno NB48, 1-Tekno NT48, 1-Tekno SCT-410, 1-AE B5, 1-AE B5M, 1-Kyosho RT6, 1-Kyosho MP9e TKi, 1-TLR Losi Mini 8ight
Our Awesome Sponsors: Tekno RC, AKA Tires, Dialed Designs Airbrushing
Special Thanks to: Trackside Raceway, Clark R/C Park & RC Scoring Pro
Bcholka is offline   Reply With Quote
Old 04-07-2014, 02:12 PM   #3260
Thanks for the replies on the gearing. Yeah idk it's weird that it gets so warm. I thought about the undergearing too but if I gear up anymore the car feels like it has no low end around the technical sections in 17.5. I am going to do some more playing around tomorrow with just gearing and see what I can figure out. Also on Maifields Warehouse3 setup it says he is running 23/81 gearing with a 7.5 and timing 0. Would that mean he retarded the timing back to 0 on the motor or left it at the stock 20? I'm having issues at 21/81 with my 7.5 getting hot and stock timing of 21/81.. so maybe that explains the 0 timing.
ktmderf is offline   Reply With Quote
Old 04-07-2014, 02:34 PM   #3261
-WHEELMAN-'s Avatar
Trader Rating: 266 (98%+)
Zero means zero timing not what it came set at from the manufacture. Try going up to a 23 just watch temps closely. Brushless motors can produce more power all the way around when geared properly.
BRETT T. RICHARDS = SUPPORT YOUR TROOPS, LOCAL TRACKS AND HOBBY SHOPS OR THEY COULD ALL BE GONE ONE DAY!
-WHEELMAN- is offline   Reply With Quote
Old 04-07-2014, 02:42 PM   #3262
predu's Avatar
maybe you are expecting too much. switching from 7.5 to 17.5 is a pretty huge difference. also batteries make a huge difference in stock.
SC10.2 , LRP, SCHUURSPEED 17.5
B4.2, LRP, SCHUURSPEED 17.5
TC6.1, LRP, SCHUURSPEED17.5
TC7 , LRP, SCHUURSPEED 17.5
10R5.1, H/W, SCHUURSPEED 17.5
predu is offline   Reply With Quote
Old 04-07-2014, 03:24 PM   #3263
Trader Rating: 14 (100%+)
Originally Posted by Bcholka View Post
+1
My car has a little push going in and then gets better mid and exit and I'm running gw arms. Guess I don't need flat arms.
"Go that way really fast, if something gets in your way, turn"
TLR 22 3.5 SR, TLR 22-4 1.875, Sanwa M12S, Savox, Hobbywing, Schuurspeed, Protek
DG Designs is offline   Reply With Quote
Old 04-07-2014, 04:21 PM   #3264
Thanks for the advise. I'll try all whites tomorrow before switching oil
splking1 is offline   Reply With Quote
Old 04-07-2014, 04:22 PM   #3265
Originally Posted by Wildcat1971 View Post
Are you downsiding the landing? I normally see this on flat landings.
Yeah flat landing and occasionally downsiding
Old 04-07-2014, 04:57 PM   #3266
BillPear's Avatar
Send a message via Yahoo to BillPear
That's the stuff!
Yep.com Home Depots the place for that!
BillPear is offline   Reply With Quote
Old 04-07-2014, 04:58 PM   #3267
BillPear's Avatar
This is kinda crazy. I was able to drop another 22 grams off the car. I normally run for 5 minutes and my temps are 160-165. Today we were doing 7 minute heats and my motor only got up to 135 degrees. I was pretty shocked. I was able to turn the timing up 2 degrees on the motor and temps got up to 150. My car should be close to the 1500 mark i think this week with the lighter battery.......maybe dropping the weight helps
Thanks BillPear for all the help!!!
Your Welcome.
Old 04-07-2014, 05:04 PM   #3268
BillPear's Avatar
I've been having trouble with heat with my B5ms. I have a car for both stock and mod. I haven't seen a whole lot about that trouble in this thread but I did see where dropping weight has made it better especially in stock. My stock comes in at almost 1600 grams but I have it geared at 29/75 which is pretty conservative compared to others and with 30degrees of motor timing in blinky mode. So I don't quite get why it's getting hot. Is it the weight? I ran the same setup on my 4.2 and it used to come off just warm. I don't see how some guys are running gearing like 69/32 with 17.5 and not getting way too hot? I'm running on an indoor track that isn't big but it isn't tight. Even with my mod car I'm running a Reedy 7.5 with gearing at 21/81 and it will come off at 185 and that's with stock timing at 20 degrees. I just saw Maifields latest setup and he's running the Reedy 7.5 gearing at 23/81 with 0 degrees of timing. Does that mean he retarded the timing on the motor from the stock 20 to 0? Or is 0 in reference to the stock 20? If that makes any sense lol. Any tips are really appreciated. My 17.5 is also a Sonic Mach 2.
Don't know why your so hot, I run my SchuurSpeed at 69/32 and 40 degrees without it even getting to hot to touch. Is it the same Reedy you ran in the centro or another one, if its another one maybe you got one that runs hot.You could cut out the vent in the body that over the top of the motor and see if that helps. And, everyone say it with me, losing weight will help.
Old 04-07-2014, 05:11 PM   #3269
n8b
Trader Rating: 108 (100%+)
Anyone have any issues with the pin in the bone not being center? It looks like it's not drilled centered. I didn't notice till I went to put it in the diff outdrive and it wouldn't go. Spun it 180 and it went in. Haven't finished the build yet, but that can't be good for balance.
n8b is offline   Reply With Quote
Old 04-07-2014, 06:03 PM   #3270
Thanks wheelman for the answer on the timing. Bill pear, it is the same motor/ESC setup out of my previous car. I am getting a set of the lighter shorty packs from a main so I'll see if that'll help. I already have the aluminum screw kit and top shaft. It wouldn't bother me so much if I didn't notice it during the run. Probably the last minute or minute and a half of a 5 minute qualifier the throttle gets incredibly soft to the point where I can't clear doubles that I could clear easily in the beginning of the run. I've tried a different battery to check that and it was the same thing.
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
