    Hide Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree6Likes
Old 04-02-2014, 10:40 AM   #3076
skrichter's Avatar
Send a message via AIM to skrichter
Originally Posted by rigor View Post
I'm pretty happy with mine now, and I only drive indoor clay (OCRC & LRH).
Everything is "kit" stock setup if not mentioned here:
Front End:
FLAT front arms & tower
4mm trailing
1mm under the front inner ballstud on tower
32.5 oil / 1.6 piston / AE White spring / middle shock hole on upper tower
24mm ride height
-1 camber
Rear End:
0 or 0.5 hub inserts
0 washers under inner ballstud on "tower" mount
30 oil / 1.6 piston / AE white spring / inside shock hole on upper tower
23.5mm ride height
-1 to -1.5 camber
Standard hub insert position for outer ballstud link
I prefer the car with saddles vs shorty so far. Batteries all the way pushed back.
Good luck
+1 on this setup.
I run a shorty however. With the large pad to the rear. I run on a tight indoor track. I also do not run a washer under the front inner ballstud.
LiveRC.com | Dirt Heaven Hobby & Raceway
skrichter is offline   Reply With Quote
Old 04-02-2014, 10:52 AM   #3077
Anyone know of someone or any place that has the 90-100c 155 gram shortys for sale? Wanted to give it a try in my B5M to see if its really a big difference for lap times since my battery is coming in at 212 grams.
splking1 is offline   Reply With Quote
Old 04-02-2014, 11:40 AM   #3078
Finally got my low profile servo to fit but I just noticed it doesn't center correctly. Like I powered up the servo and I set my controllers trim to 0 then put the servo horn on and I noticed the servo turns to the right farther than the left. What would be the problem? Oh and yes my travel is set to both 100% left and right
chancejeff is offline   Reply With Quote
Old 04-02-2014, 11:50 AM   #3079
predu's Avatar
endpoints?
SC10.2 , LRP, SCHUURSPEED 17.5
B4.2, LRP, SCHUURSPEED 17.5
TC6.1, LRP, SCHUURSPEED17.5
TC7 , LRP, SCHUURSPEED 17.5
10R5.1, H/W, SCHUURSPEED 17.5
predu is offline   Reply With Quote
Old 04-02-2014, 12:26 PM   #3080
Tech Legend
Wild Cherry's Avatar
Soon ....
Will be posting images of my B5m and all the helpful tuning tips that make racing a Ae the most fun you can buy.
Any driver can copy a great set up, a Champion however will steal it .
If Jesus returned as a Rc car he be a Rc10 B5M
George W. Cherry
Wild Cherry is offline   Reply With Quote
Old 04-02-2014, 12:39 PM   #3081
rigor's Avatar
Trader Rating: 37 (100%+)
Originally Posted by skrichter View Post
+1 on this setup.
Next things I'll be trying one by one are:
30 front / 27.5 rear oils
0 washers under front inner ballstud
3 x 1.4 pistons in the front shocks
Go to outside hole on B rear hub insert
2 degrees anti-squat
B5 rear-motor REAR arms
Got my hands on the aluminum rear ballstud mount yesterday. Now just waiting for the dang rear C & D inserts so I can install those aluminum mounts as well. Got some stainless and titanium screws on their way too
* Jesse H. *
rigor is offline   Reply With Quote
Old 04-02-2014, 12:44 PM   #3082
Trader Rating: 29 (100%+)
http://www.ebay.com/itm/SE-energy-32...f#ht_611wt_720
This is the only one that I can find anywhere....I am hesitant to order it though....I would rather wait for the trakpower or promatch to be available.
jschurig is offline   Reply With Quote
Old 04-02-2014, 12:53 PM   #3083
Wildcat1971's Avatar
Trader Rating: 80 (100%+)
These are out of stock, but just an fyi
http://www.promatchracing.com/products.php?cat=38
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 04-02-2014, 01:29 PM   #3084
rigor's Avatar
Oh yeah... all the AE team guys were at OCRC yesterday doing some B5m setup testing, and some other testing I cannot mention. Cav, Hartson, Kody, BT... even Cliff Lett was there for about an hour (not driving). Always good to see those guys out there pushing the limits
* Jesse H. *
Old 04-02-2014, 01:51 PM   #3085
They should available anytime. Looks like they are to arrive this week and could be shipped to u next week. I'm gonna order a few as well.
Justinb86 is offline   Reply With Quote
Old 04-02-2014, 02:02 PM   #3086
Mason's Avatar
so why mention it?
but since you said it, We will start guessing. Here's a small compilation of possibilities:
front sway bar prototypes
rear sway bar options
different front axle set up
different caster blocks/ballstud mount locations
variable arm mount pills like serpent
different center tray mounts relating to electronics mounting options.
Mason McCombs
NewRed Hobbies & Indoor Facility
Off-Road, Dirt Oval, Crawlers & Pullers
Mason is offline   Reply With Quote
Old 04-02-2014, 02:07 PM   #3087
Send a message via ICQ to JiuHaWong
New 4wd? With Gear diffs?
오늘의 청소년들이 미래의 문제를 처리 할 준비가 병 슬프게도 있습니다 우려하고있다.
JiuHaWong is offline   Reply With Quote
Old 04-02-2014, 02:19 PM   #3088
Tech Legend
Just picked up a couple set of hard flat front arms. Also the alloy hex's & rear ball stud mount..
Parts are starting to trickle in .
George W. Cherry
Old 04-02-2014, 02:26 PM   #3089
Tradin Paint's Avatar
Originally Posted by Mason View Post
so why mention it?
T5?
Happy with: Team Associated, Team Tekin, Airtronics, Avid, JConcepts, Fantom motors and Aero Model batteries.
Proud Supporter of Warehouse 3 RC Hobby Shop, that just happens to have an indoor track
"Because Size Does Matter"
Ryan H.
Tradin Paint is offline   Reply With Quote
Old 04-02-2014, 03:03 PM   #3090
Trader Rating: 14 (100%+)
make sure it isnt hitting on the case. I had that issue
"Go that way really fast, if something gets in your way, turn"
TLR 22 3.5 SR, TLR 22-4 1.875, Sanwa M12S, Savox, Hobbywing, Schuurspeed, Protek
DG Designs is offline   Reply With Quote
Currently Active Users Viewing This Thread: 5 (1 members and 4 guests)
lexusbest
