    Hide Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree9Likes
Old 03-31-2014, 11:56 AM   #2971
Jordan Anderson's Avatar
I heard someone locally actually got a B5M kit late last week.
Anyone else got their B5M yet?
JORDAN // EVAN
R/C GEARS , TRUKZ/KARZ , VRC PRO
Jordan Anderson is offline   Reply With Quote
Old 03-31-2014, 12:04 PM   #2972
Logi Maker's Avatar
Trader Rating: 49 (100%+)
Originally Posted by thecman26 View Post
FYI: If anybody else is in search of the front clamping hexes, Nitrohouse has them in stock, i don't know how but they do!
http://www.nitrohouse.com/Front-Clam...5_p_16643.html
Looks like the B4 ones. How are those supposed to work on the new axles or do you need different ones?
Kyle Predmore
FB AE Fanboy/Insta @ae_fanboy
Sticky Kicks RC\Prolevel RC\MIP\Schelle
Logi Maker is offline   Reply With Quote
Old 03-31-2014, 12:14 PM   #2973
Trader Rating: 124 (100%+)
Originally Posted by Matt Trimmings View Post
Actually Jesse, its the position of the front caster block. You shim it differently to maintain wheelbase. AE shouldnt have said "rear casterblock" It should have just said casterblock.
Originally Posted by Dan Hamann View Post
The rear shim on the [front] caster block. Not the rear of the car. To maintain overall wheelbase, you adjust the caster block spacing to counter the movement of the axle with the different trailing positions. The "Rear Caster Block Wheelbase Shim."
Ok. I'm with you so far. Part number 91400 includes the 2mm shim. What do you use for 1mm if you want to run 3mm trailing axles?
Chris Gierse is offline   Reply With Quote
Old 03-31-2014, 12:16 PM   #2974
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 156 (100%+)
2x 1mm shims. Shim the block 1mm on each side.
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 03-31-2014, 12:27 PM   #2975
Thanks Matt. Do you have a part number for the 1mm shims?
Old 03-31-2014, 12:30 PM   #2976
Super Moderator
just search 1mm shim on amain. i use the ASC4617 for ball stud washers, they come with .5, 1 and 2mm shims.
Old 03-31-2014, 01:12 PM   #2977
Thanks for the info. I thought maybe they had a specific part # for this.
Old 03-31-2014, 01:54 PM   #2978
My local shop (Mike's RC World in Bellingham WA) had them a month ago
Justinb86 is offline   Reply With Quote
Old 03-31-2014, 02:13 PM   #2979
azwheelman's Avatar
just got it last sunday @hobbytown srs there last 1 of 6
still needs electronics
Deckers Jackrabbit track ,
B5 , B5m
azwheelman is offline   Reply With Quote
Old 03-31-2014, 02:16 PM   #2980
RCBuddha's Avatar
Trader Rating: 35 (100%+)
Still waiting for Amain. They have the ETA as 4/15/14.
RCBuddha is offline   Reply With Quote
Old 03-31-2014, 02:35 PM   #2981
rigor's Avatar
Trader Rating: 37 (100%+)
Good catch! Caster only exists up front.
* Jesse H. *
rigor is offline   Reply With Quote
Old 03-31-2014, 03:20 PM   #2982
pumpkinfish's Avatar
I'm about ready to install the D arm mounts. Which way do the arrows point on the inserts? I also am guessing that on the C arm mounts the number that is installed on top of the insert is what setting the car will have.
pumpkinfish is offline   Reply With Quote
Old 03-31-2014, 05:13 PM   #2983
Trader Rating: 29 (100%+)
Originally Posted by rickster View Post
hey skeeter ..
if you can post your current setup and equipment your using then I can help you from where you are to get as much steering as you would like.
I would love to fill out a sheet and post it but im not very pdf or jpeg savy. Its hard for me to even load pics on computer, i know ha ha laugh all you want im a dumb-a** but anyhow. Ill try my best to list everything
FRONT:
Camberlink inside on tower with 2mm under B.S.
1.6 piston 32.5 wt. white spring, middle on tower and outside on arm
4mm trail, casterblock spaced forward(stock), no bumpsteer spacers or ackermann changes.
Chassis Elecs. Shorty all the way back to tranny, (helps with rear grip)?
REAR: 1.6 piston 32.5 wt GREEN spring middle on tower inside on arm
camberlink: Inside hole(closest to tranny) 2mm B.S. washer under it,
Middle on the 3-hole option on rear hub w/ stud @ top
Hubs spaced all the way back
Anti-squat is whatever the manual says to run!
Skeeter36 is offline   Reply With Quote
Old 03-31-2014, 05:42 PM   #2984
Does anyone know what a stock b5m weights without battery?
I was depressed today I weighed mine. Came in at 1609 grams RTR. My battery is 212 grams so I can save 60 grams there. I'm running titanium screw kit and turn buckles. Along with aluminum top shaft. Carbon fiber battery strap and a few aluminum parts.
Far cry to 1500 grams.
splking1 is offline   Reply With Quote
Old 03-31-2014, 05:47 PM   #2985
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
Alum upgrades to replace plastic parts will mostly likely add weight. IMO the best place to lose weight if you a weight crazy person is in the esc and servo. The tekin rs gen2 and a light weight low profile servo is about as light as you can get. Plus the 150gram battery would get you very low.
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Currently Active Users Viewing This Thread: 3 (1 members and 2 guests)
Moose knuckle
