    Hide Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree6Likes
Old 03-31-2014, 07:38 AM   #2956
Tech Legend
Wild Cherry's Avatar
Originally Posted by RonBegeot View Post
that bad huh........I guess I'm behind the research curve. What's the due date?
Still don't have my ride yet...
Now that's behind the curve...
We have some parts at Trcr & more arriving every few days.
On interest to you may be the alloy steering arms & front arm brace.
Any driver can copy a great set up, a Champion however will steal it .
If Jesus returned as a Rc car he be a Rc10 B5M
George W. Cherry
Wild Cherry is offline   Reply With Quote
Old 03-31-2014, 08:27 AM   #2957
thecman26's Avatar
Trader Rating: 98 (100%+)
FYI: If anybody else is in search of the front clamping hexes, Nitrohouse has them in stock, i don't know how but they do!
http://www.nitrohouse.com/Front-Clam...5_p_16643.html
thecman26 is offline   Reply With Quote
Old 03-31-2014, 08:29 AM   #2958
Trader Rating: 20 (100%+)
Originally Posted by Skeeter36 View Post
I run on high bite and I have the reedy square, saddles, and a shorty and so far my car feels the best with a shorty. I NEED MORE STEERING.... I have tried a few things to get more but nothing seems to add the amount im looking for. I love a car that is a little twitchy, just my driving style. Any help is greatly appreciated
For more steering on high bite... I moved the shorty forward with the thin battery spacer in front.
My setup
Front: kit stock
Rear: white spring, 1.6 pistons, 30 wt oil, 1 mm spacer under camber link, upper shock inside hole, camber link ran in stock position on inside and hub.
Bad news is our local track just closed, so my one practice day old B5m may be up for sale.
GTSSTANG is offline   Reply With Quote
Old 03-31-2014, 08:33 AM   #2959
Why use these other than the stock?
xTotalghost is offline   Reply With Quote
Old 03-31-2014, 08:46 AM   #2960
thecman26's Avatar
The stock ones suck!
Its a widely known issue, the stock hexes are tiny and thin, make changing tires a headache, and that silly screw has been know to pop out letting loose a wheel at the least opportune moment!
If ya get the clamping axles (which are equally as hard to find) and the clamping hexes and your good to go!
Plus the anno'd blue aluminum looks better too!
Old 03-31-2014, 08:48 AM   #2961
Super Moderator
Trader Rating: 17 (100%+)
I've had the front hexs. Just not the axles.
Tekno|JConcepts|ProTek|Amain|VRP|BOOMrc
Bob Barry is offline   Reply With Quote
Old 03-31-2014, 10:45 AM   #2962
Trader Rating: 123 (100%+)
I'm a little confused. When you change the axle from 2-3-4mm trailing the manual tells you to change the rear caster block. What part exactly am I changing? The rear hub?
Chris Gierse is offline   Reply With Quote
Old 03-31-2014, 10:50 AM   #2963
Super Moderator
There are 2 inserts. 3mm has the hole centered so you just put it in. 2/4mm has the hole offset. If you want 2mm you put the hole so that it's more forward. If you want 4mm you put the hole so it's more rear.
Old 03-31-2014, 10:56 AM   #2964
I understand that part. What I don't understand is the last column.
Old 03-31-2014, 11:02 AM   #2965
Super Moderator
Oh i believe that is referring to if you space the caster block forward, middle, or rear.
Old 03-31-2014, 11:06 AM   #2966
rigor's Avatar
Trader Rating: 37 (100%+)
Edited / Deleted due to confusion & incorrect info
* Jesse H. *
rigor is offline   Reply With Quote
Old 03-31-2014, 11:10 AM   #2967
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 156 (100%+)
Originally Posted by rigor View Post
It's referring to running the rear hubs in the Forward, Middle, or Back position on the outer (wheel) position hinge.
Actually Jesse, its the position of the front caster block. You shim it differently to maintain wheelbase. AE shouldnt have said "rear casterblock" It should have just said casterblock.
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 03-31-2014, 11:11 AM   #2968
Dan Hamann's Avatar
Trader Rating: 14 (100%+)
The rear shim on the [front] caster block. Not the rear of the car. To maintain overall wheelbase, you adjust the caster block spacing to counter the movement of the axle with the different trailing positions. The "Rear Caster Block Wheelbase Shim."
RCAmerica - Xray - Hudy - RC^2 - Motiv - Team EAM - Sanwa - Avid - Max.FX - Protoform - Pro-Line - Gravity R/C - Prolevel R/C - 2MM Designs
Dan Hamann is offline   Reply With Quote
Old 03-31-2014, 11:34 AM   #2969
Jake S's Avatar
Trader Rating: 65 (92%+)
Send a message via AIM to Jake S Send a message via MSN to Jake S
other way around for me, i got the axles in my bag, but no hexes lol
VooDoo Racing Cells | Flying Farmer RC | Trackside Hobby | Prochko Paintz | RG1
Jake S is offline   Reply With Quote
Old 03-31-2014, 11:37 AM   #2970
rigor's Avatar
Wow! This place has cheap prices like another online shop in my county... but this one is just 7 miles down the (same) street from my house and also offers local pickup
Thanks for the shop tip
* Jesse H. *
Currently Active Users Viewing This Thread: 5 (1 members and 4 guests)
lexusbest
