    Hide Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree6Likes
Old 03-29-2014, 03:12 PM   #2911
Originally Posted by steam View Post
I'm sorry what? Why would a top shaft impact anything but rotating weight?
I hope you do know he was being sarcastic
chancejeff is offline   Reply With Quote
Old 03-29-2014, 03:22 PM   #2912
What holes are you guys using on the stock wing? The forward or rear holes?
splking1 is offline   Reply With Quote
Old 03-29-2014, 03:40 PM   #2913
Vegas456's Avatar
I run the forward holes. That is what seemed "right" and that is what other people are running at my local track as well
Team Losi Racing~Spektrum~Trackside Hobbies~Motiv RC~Gravity RC~MIP~R17~RC Scoring Pro
Vegas456 is offline   Reply With Quote
Old 03-29-2014, 03:59 PM   #2914
dirty petcock's Avatar
Can anyone think of a reason why I can't use a b4 Diff gear? The b5 gear is wider but it's the same number of teeth. The Difference is only about a 1/16th
dirty petcock is offline   Reply With Quote
Old 03-29-2014, 04:01 PM   #2915
I'm running a jconcept wing now. I'm going to switch to the stock wing it came with. I noticed it's a totally different shape. Wondering if that will make a difference.
Old 03-29-2014, 04:06 PM   #2916
I've tried it. Works fine
Old 03-29-2014, 04:31 PM   #2917
Trader Rating: 14 (100%+)
I am actually running the rearward ones. I started with it simply because i don't like the wing looks hanging so far off the back. The car worked so well i am afraid to try anything new!
"Go that way really fast, if something gets in your way, turn"
TLR 22 3.5 SR, TLR 22-4 1.875, Sanwa M12S, Savox, Hobbywing, Schuurspeed, Protek
DG Designs is offline   Reply With Quote
Old 03-29-2014, 04:39 PM   #2918
Did you trim the front of the wing then so it doesn't hang so far over the body that way?
Old 03-29-2014, 04:44 PM   #2919
Vegas456's Avatar
I am actually running the jconcepts b4.2 wing. I used the stock wing as a stencil and I drew new lines on the JC wing and cut it along the new lines.
Old 03-29-2014, 05:20 PM   #2920
Not really, it's hanging over the tower though.
Old 03-29-2014, 05:30 PM   #2921
Not to bad.....ill have to try both locations.
Old 03-29-2014, 05:31 PM   #2922
BillPear's Avatar
Send a message via Yahoo to BillPear
Over/under on how many don't realize you used the sarcasim font.
1 so far...
BillPear is offline   Reply With Quote
Old 03-29-2014, 05:31 PM   #2923
What line did you use on the rear wing to cut it down to?
Old 03-29-2014, 06:05 PM   #2924
Originally Posted by racer_guy View Post
aight guys in the manual its got a couple racer tips. set screw 4670 for the caster block insert and hinge pin, and the rear hub inserts and hingepin. anybody done this? not done this? advantage or not needed? feedback plz
I did. My car had a little slop in it after running it for a few packs. The screws took out the slop, and I can still change the inserts.
roundguy is offline   Reply With Quote
Old 03-29-2014, 06:16 PM   #2925
pumpkinfish's Avatar
Guys need some input on setup. I am setup with Cavalieri's Cactus setp outside of tires. I run on a high grip indoor clay track using slicks and traction compound. The traction was through the roof today. My rear was so locked I had to almost stop to make turns. The only other mid motor car (Centro) had the same issues. I moved battery all the way forward and still couldn't turn too well on the 90 degree turns or the 180. Once the track dried out some after the mains the car was feeling better but still had the push. Any ideas on what to start with?
pumpkinfish is offline   Reply With Quote
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
