    Hide Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree6Likes
Old 03-27-2014, 06:36 PM   #2821
Tradin Paint's Avatar
Originally Posted by Wild Cherry View Post
the b4 plastic steering arms weight almost 1/2 of the alloy.
Alloy weights about 5 g..
Plastic 2 g
Are these B4 or B5 measurements? The aluminum b5 steering parts look much smaller (thinner) than the stock plastic which is why I was originally asking. If they suck and don't work properly then it is a non issue and I'll just move on
Happy with: Team Associated, Team Tekin, Airtronics, Avid, JConcepts, Fantom motors and Aero Model batteries.
Proud Supporter of Warehouse 3 RC Hobby Shop, that just happens to have an indoor track
"Because Size Does Matter"
Ryan H.
Tradin Paint is offline   Reply With Quote
Old 03-27-2014, 06:51 PM   #2822
Tech Legend
Wild Cherry's Avatar
Parts were all B5
Part performs great, no problems...
Thanks to everyone that posted the screw hardware links..
Just picked up a set of the Ae alloy for B5.
Very blue...
Any driver can copy a great set up, a Champion however will steal it .
If Jesus returned as a Rc car he be a Rc10 B5M
George W. Cherry
Wild Cherry is offline   Reply With Quote
Old 03-27-2014, 07:15 PM   #2823
Trader Rating: 14 (100%+)
By the way looks like the hard parts are heavier as well. Put on rear hubs and uprights and added a few grams. Lol
"Go that way really fast, if something gets in your way, turn"
TLR 22 3.5 SR, TLR 22-4 1.875, Sanwa M12S, Savox, Hobbywing, Schuurspeed, Protek
DG Designs is offline   Reply With Quote
Old 03-27-2014, 07:27 PM   #2824
Tech Legend
easy solution
Lunsford Ti
Ball studs, suspension pins , screw set & Ti hex front axles..
George W. Cherry
Old 03-27-2014, 07:34 PM   #2825
Suspended
move on
Pimp Formally Known as OG
PFKAOG is offline   Reply With Quote
Old 03-27-2014, 07:45 PM   #2826
I may chase grams but in this case the sarcasim font is needed.
Old 03-27-2014, 07:48 PM   #2827
Super Moderator
Trader Rating: 17 (100%+)
Originally Posted by PFKAOG View Post
move on
Tekno|JConcepts|ProTek|Amain|VRP|BOOMrc
Bob Barry is offline   Reply With Quote
Old 03-27-2014, 08:05 PM   #2828
BillPear's Avatar
Send a message via Yahoo to BillPear
Originally Posted by Bkautz View Post
Pic 1 of my rewire and new layout
Swap that R10 out of your SC10.2, otherwise its going to waste Novel approach running the motor wires through chassis brace, mine are too short for that. I'd like to hear how often you need to unsolder them, after a few months,
BillPear is offline   Reply With Quote
Old 03-27-2014, 08:07 PM   #2829
BillPear's Avatar
I'm planning on giving those grams back when AE finally releases the aluminum hubs with the vertical ballstud mount those things are SWEEET!
Old 03-27-2014, 08:24 PM   #2830
predu's Avatar
Nice, i did that to mine two weeks ago since we are on low/medium bite. Only difference was i kept my batterystrap, i only cut the middle out
SC10.2 , LRP, SCHUURSPEED 17.5
B4.2, LRP, SCHUURSPEED 17.5
TC6.1, LRP, SCHUURSPEED17.5
TC7 , LRP, SCHUURSPEED 17.5
10R5.1, H/W, SCHUURSPEED 17.5
predu is offline   Reply With Quote
Old 03-27-2014, 08:55 PM   #2831
Tech Legend
Picked up the Ti axles today also...
Ha !
George W. Cherry
Old 03-27-2014, 09:21 PM   #2832
I have tried the alloy steering to the stock and there is no feel difference in the car driving it.. the alloy stuff you will need to use locktite to keep ballends in... and they are a little heavier. I took it back out after having the ballstud loosen up twice... and now run the stock stuff.
nice wiring job but you limit a lot of tuning on a mid motor by limiting yourself to one battery position.
rickster is offline   Reply With Quote
Old 03-27-2014, 09:26 PM   #2833
Cridd's Avatar
Trader Rating: 16 (100%+)
Pic 2
Nice outside the box thinking.
Chris
B6D / T5M / SC5M
Cridd is offline   Reply With Quote
Old 03-27-2014, 09:52 PM   #2834
Trader Rating: 29 (100%+)
who makes the solid battery pins that the wires soldier to ?? and who sells them....
Mdoc is offline   Reply With Quote
Old 03-27-2014, 09:59 PM   #2835
Mopar's Avatar
Originally Posted by Jake S View Post
http://www.amain.com/product_info.ph...ter-Set-TLR-22
is what i used, also takes a slight ream to slide on easy. guessing 4mm-ID shim is whats needed
Are these shims all the same thickness or varied?
Schumacher KF2se, Associated B5m CE (sold), Hot Bodies D413, Associated T5m, Axial Exo Terra, Schumacher Mi5, CRC 1/12, 3Racing FGX full suspension, Associated 18r
Mopar is offline   Reply With Quote
