    Hide Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree6Likes
Old 03-26-2014, 02:24 PM   #2776
offroad dude's Avatar
Trader Rating: 25 (100%+)
Originally Posted by Graham11 View Post
I have both but havent driven both because I am selling my rb6, its built but ive never used it cus b5m has been great.
Thanks for the response!
offroad dude is offline   Reply With Quote
Old 03-26-2014, 03:02 PM   #2777
Originally Posted by Cridd View Post
the build on B5m is a 3 + 1 on rear toe and droop. Anybody change insert and what did you see? Going to read up on it now.
Doesn't that mean 3degrees toe and 1 degree squat??
Oldgearhead is offline   Reply With Quote
Old 03-26-2014, 03:47 PM   #2778
Super Moderator
Trader Rating: 17 (100%+)
yeah, 3-1 is 3 toe 1 anti.
Tekno|JConcepts|ProTek|Amain|VRP|BOOMrc
Bob Barry is offline   Reply With Quote
Old 03-26-2014, 04:15 PM   #2779
Trader Rating: 14 (100%+)
Another thing that helps is run the smallest spur possible. I'm running 66/33, puts the motor that much farther back.
"Go that way really fast, if something gets in your way, turn"
TLR 22 3.5 SR, TLR 22-4 1.875, Sanwa M12S, Savox, Hobbywing, Schuurspeed, Protek
DG Designs is offline   Reply With Quote
Old 03-26-2014, 06:28 PM   #2780
Anyone try a gear diff on the b5m yet? I just installed one going to try it out tomorrow.
splking1 is offline   Reply With Quote
Old 03-26-2014, 07:38 PM   #2781
BillPear's Avatar
Send a message via Yahoo to BillPear
Don't know why I would...
BillPear is offline   Reply With Quote
Old 03-26-2014, 07:43 PM   #2782
rigor's Avatar
Trader Rating: 37 (100%+)
I suggest putting an oversized washer between the plastic rear hub insert and ballstud to better spread the mounting pressure from the stud. You can only get the replacement plastic inserts by purchasing the entire rear hub set. I went with the HARD version now since I had to buy anyway.
* Jesse H. *
rigor is offline   Reply With Quote
Old 03-26-2014, 07:54 PM   #2783
I've wondered about this also. The factory guys were running gear diffs at the IFMAR and CC races.
roundguy is offline   Reply With Quote
Old 03-26-2014, 07:56 PM   #2784
BillPear's Avatar
I'm not going to say they weren't but I see them refreshing there ball diffs all the time. Unless Cav and Hartson don't count.
Old 03-26-2014, 07:59 PM   #2785
pumpkinfish's Avatar
I just finished my B5m build. Car feels like a tank. Can't wait to drive it this weekend. One question on electronics...will a Savox 1233SG fit properly? Also did anyone else have broken shock eyelets in the box? I had two that were split down the middle. Weird.
pumpkinfish is offline   Reply With Quote
Old 03-26-2014, 08:00 PM   #2786
rigor's Avatar
Ball diffs for OCRC since it's med to high bite. Only need those gear diffs for super high bite I believe.
* Jesse H. *
Old 03-26-2014, 08:36 PM   #2787
Trader Rating: 22 (100%+)
Originally Posted by rigor View Post
If you're having issues getting on the power exiting corners, try all 4 of the following rear end changes together:
1.6 pistons
AE 30 weight oil
AE White Springs
Inner hole shock mounting position up top on the rear tower.
After that you can toy with the inner rear camber link ballstud height. I am currently happy with 0 washers, bringing the ballstud down.
These changes along with the flat front arms/tower made me much happier with the B5m so far! To each their own style and preference of feel.
Good luck
hey rigor,
just wanted to say thanks. knocked off at least .5 off my times. haven't had a chance to try flat arms but laying shock down was money with those springs. appreciate it man.
JVilla is offline   Reply With Quote
Old 03-26-2014, 08:57 PM   #2788
Trader Rating: 29 (100%+)
I dont want to offend anyone but if you cant get a RM car around the track then MM probably isnt going to help you. GEAR DIFFS, Unless your on HIGH HIGH bite astro, then i dont think its worth messing with, or its for lazy people? I run on high bite dirt/clay that MM car will wheelie down the straight and we all run ball diffs w/ no issue. we will run them for 6 months w/ no gritty feeling at all. Its all in the build and break in and final sttings. I love the B5M, great car, as good or better than anything available IMO. I have owned 22 2.0, RB6,and the B5M and I prefer the B5M for its steering characteristics. I wont bore you fellas anymore but just my thoughts!!
Skeeter36 is offline   Reply With Quote
Old 03-26-2014, 09:17 PM   #2789
Does anyone know if the aluminum top shaft part #91427 will work in the b5m? They just came into stock on associated site but don't list what cars it will work in.
Old 03-26-2014, 09:26 PM   #2790
Thumbs up
Yes, that is the part number for the B5 and B5M.
SPDBuggy is offline   Reply With Quote
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
