    Hide Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree7Likes
Old 03-13-2014, 10:02 PM   #2146
Originally Posted by DG Designs View Post
31 with Reedy Mach 2.
So your running a 2.22 gear ratio. I am running a 2.02. Have you ran it to see temps and speed? i have a tekin gen 2 in my car and i havent ran it yet. I have it set at 0 timing for the first run. ill run it for 4 min and see how it comes off.
xTotalghost is offline   Reply With Quote
Old 03-13-2014, 10:21 PM   #2147
tropmonky's Avatar
Okay, installed the B4.2 MIP Pucks system this eve. I wouldn't suggest it for regular people, just wait for the B5 kit to come out.
It shaved off about 30g total.
Anyhow, here are a few pics. I got my running weight (minus any added weights) down to 1462g now!
I forgot my gear diff cover, so add 1g (if).
tropmonky is offline   Reply With Quote
Old 03-13-2014, 10:25 PM   #2148
vr6cj's Avatar
Trader Rating: 124 (100%+)
[/IMG]
what you do? replace the bearings too?
vr6cj is offline   Reply With Quote
Old 03-13-2014, 10:38 PM   #2149
tropmonky's Avatar
nope, used the rear hubs off my B4.2 and drilled out the Hub Pin hole since the B5M's are a tad bigger.
Old 03-13-2014, 11:42 PM   #2150
Trader Rating: 29 (100%+)
is it worth cutting the diff gears to shave of weight
thanks
ronzo is offline   Reply With Quote
Old 03-14-2014, 12:22 AM   #2151
Nemaris's Avatar
Trader Rating: 18 (100%+)
Has anybody tried the Avid Satellite wheels? Do the fronts fit well? Also since the turnbuckles are the same, I assume you can use a lunsford turnbuckle set for the b4.2?
Nemaris is offline   Reply With Quote
Old 03-14-2014, 05:09 AM   #2152
Trader Rating: 14 (100%+)
Originally Posted by xTotalghost View Post
well its a 4 gear transmission now. wouldnt it change stuff?
Ratio is the same and the extra drag is probably not even measurable. Only reason i went down is the motor does not get as much air.
"Go that way really fast, if something gets in your way, turn"
TLR 22 3.5 SR, TLR 22-4 1.875, Sanwa M12S, Savox, Hobbywing, Schuurspeed, Protek
DG Designs is offline   Reply With Quote
Old 03-14-2014, 05:26 AM   #2153
thanks
I cut the gears on my b4, but I really don't think it's worth it too much anymore. We used to do it for stock class back in the days of nimh batteries and brushed motors, but now with lipo and brushless you literally see no difference whatsoever. I also cut down the gear on my aluminum Topshaft and that didn't save enough weight to show up on my scale, it just couldn't register the difference.
I would just go with the aluminum Topshaft and pucks. Those savings are huge, and they don't really weaken your drivetrain.
iVoid is offline   Reply With Quote
Old 03-14-2014, 09:35 AM   #2154
tropmonky's Avatar
^ +1
Old 03-14-2014, 10:16 AM   #2155
Jmuck69's Avatar
The Satellite wheels works great, lighter and run true. The fronts are a tad tight on the hex but I just rock the wheel a tad when taking it off, no issue. The front axles are the problem and could be tolerance differences in the axles.
B6D | B64D
Schelle Racing Concepts - www.schelleracing.com
Amain Hobbies - www.amain.com
Jmuck69 is offline   Reply With Quote
Old 03-14-2014, 10:30 AM   #2156
Jeff Werner's Avatar
Send a message via Yahoo to Jeff Werner
That is what I found with the Centro. I could not run the same timing and gear with the motor inside the car as I could with the B4.2. Temps were much higher with the Centro and the lack of air flow was the reason.
Jeff Werner is offline   Reply With Quote
Old 03-14-2014, 10:57 AM   #2157
thank you ivoid
Old 03-14-2014, 11:03 AM   #2158
If somebody wants to order a b5m kit in germany, we have plenty in stock.
f.e. "Hk- Modellbau"
maybe the shipping costs are worth the car for you
Ice22 is offline   Reply With Quote
Old 03-14-2014, 11:30 AM   #2159
DKSPLIT96's Avatar
what size drill bit did you use?
Grant Beckwith
Associated, Reedy, Orion, Futaba
DKSPLIT96 is offline   Reply With Quote
Old 03-14-2014, 12:49 PM   #2160
Tradin Paint's Avatar
Has anyone tried the aluminum shock mounts. Not sure what I'm doing wrong but there is a ton of slop between the shock mount and the hole in the shock cap
Happy with: Team Associated, Team Tekin, Airtronics, Avid, JConcepts, Fantom motors and Aero Model batteries.
Proud Supporter of Warehouse 3 RC Hobby Shop, that just happens to have an indoor track
"Because Size Does Matter"
Ryan H.
Tradin Paint is offline   Reply With Quote
