    Hide Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree9Likes
Old 03-13-2014, 05:19 PM   #2131
anybody running the avid slipper?
xTotalghost is offline   Reply With Quote
Old 03-13-2014, 05:21 PM   #2132
Trader Rating: 91 (100%+)
Originally Posted by VegasHB View Post
I went through front bearings with stock axles...I felt it could be the trailing axle inserts too, they might be off a bit or don't seat correctly. I switched to the hard hub/inserts and the stock axle then had a little play in it so the bearings weren't being smashed in when tightened.
I really like the stock axle design...never been a fan of the clamping hubs.
i have had no trouble with anything, on mid or rear motor. i have them both
redracerd is offline   Reply With Quote
Old 03-13-2014, 06:01 PM   #2133
BillPear's Avatar
Send a message via Yahoo to BillPear
Yes
BillPear is offline   Reply With Quote
Old 03-13-2014, 07:20 PM   #2134
Trader Rating: 14 (100%+)
Allows me to run a 66 spur and get the motor back over the wheels more.
"Go that way really fast, if something gets in your way, turn"
TLR 22 3.5 SR, TLR 22-4 1.875, Sanwa M12S, Savox, Hobbywing, Schuurspeed, Protek
DG Designs is offline   Reply With Quote
Old 03-13-2014, 07:46 PM   #2135
Originally Posted by DG Designs View Post
+1
66 and what size pinion for ur 17.5? And what motor
Old 03-13-2014, 08:35 PM   #2136
SNR Graphite's Avatar
Trader Rating: 19 (100%+)
Default Battery strap
www.snrgraphite.com
SNR Graphite is offline   Reply With Quote
Old 03-13-2014, 08:48 PM   #2137
Wildcat1971's Avatar
Trader Rating: 81 (100%+)
Originally Posted by SNR Graphite View Post
I am more interested in your Sanwa esc
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is online now   Reply With Quote
Old 03-13-2014, 09:01 PM   #2138
GraphiteChassis's Avatar
Originally Posted by tropmonky View Post
The box setup (with box springs) are on the soft side. I often see guys with the problem of the rear end coming around after coming off the gas; this is is often one of two things.
1. too much drag brake
2. Too soft of a spring on the front allowing the car to transfer too much weight to the front and the rear gets light.
I've been running between the gray front and green front springs depending on how much front end bite I need and how rough the track is.
On the rear I've been sticking with white. Please note I'm running with a ultra shorty pack with a running weight of around 1510g, running weight when at OCRC without added weight is around 1490
If you're running with a FULL SQ pack on a high bite clay track like OCRC then I would say you REALLY need to go up on the springs from the stock ones, like bad!
What battery is getting you down that light? I can't get below 1560 with a reedy shorty...
GraphiteChassis is offline   Reply With Quote
Old 03-13-2014, 09:05 PM   #2139
he is using a pan car battery. 3300mah 2s lipo 150ish grams
Old 03-13-2014, 09:06 PM   #2140
vr6cj's Avatar
Trader Rating: 124 (100%+)
i hate those batts. Bad luck I guess. Seen to many puff
vr6cj is offline   Reply With Quote
Old 03-13-2014, 09:06 PM   #2141
Sorry not my car don't know.
www.snrgraphite.com
Old 03-13-2014, 09:12 PM   #2142
31 with Reedy Mach 2.
Old 03-13-2014, 09:22 PM   #2143
Double Dee's Avatar
how long are your mains. 6min 8min
Darin Duncan. @ TRCR/BRCR
Double Dee is offline   Reply With Quote
Old 03-13-2014, 09:34 PM   #2144
5. To be honest I haven't run it yet though. I used to run 66/32 in my b4.2 and never had issues.
Old 03-13-2014, 09:52 PM   #2145
well its a 4 gear transmission now. wouldnt it change stuff?
