    Hide Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree6Likes
Old 11-24-2016, 02:10 PM   #20866
Jordan Anderson's Avatar
In low grip / bumpy conditions, the 'lite' chassis or the heavier original chassis?
Besides the "Ray Munday setup guide", any other tips for success with the mid motor car on low grip?
Go to tires are blockades rear and ribbed front, so we're not dealing with a modern high grip clay track.
Do the brass C/D suspension mounts work well? Make the car easier to drive?
4 gear transmission is better for low grip?
JORDAN // EVAN RC8.2e, B5, B5M, EB48SL, SCT410.3
R/C GEARS , TRUKZ/KARZ , VRC PRO
We're not sponsored, but would recommend:
Team Associated, Tekno, A Main, Action, PM
Futaba, Schelle, Avid, Proline, Lunsford
Jordan Anderson is offline   Reply With Quote
Old 11-24-2016, 04:50 PM   #20867
Trader Rating: 15 (100%+)
If it's really that low grip, adding weight under the battery helps a lot, like 50-100g, 4 gear, 3 hole pistons, low oils.....but even better is running it in rear motor.
Daragh Slowey
22-4 2.0/R10/Scorpion5.5/S6040/Nosram shorty
B5R/R10/LRP8.5/1258TGBlk/Nosram shorty
EB48SL/RX8/TekinT8i/Hitec7599/SMC4500(4S)
Grasshopper/Tekin FX/Twister 27T/FutabaS9551/Speed power
HeavyD99 is online now   Reply With Quote
Old 11-25-2016, 07:52 AM   #20868
GasGod's Avatar
anyone try to mount a b6 laydwn tranny in the 5m?
F! Metal Militia,VTA NATION--Team SloMoFo
losi 8t,mbx5t,rc8
rc8,Kyosho rb5,SCR
ft4 MT wallet
cyclone;xxx-s;x-rayT2;crc gen xl;bmi 12rrl
GasGod is offline   Reply With Quote
Old 11-25-2016, 04:27 PM   #20869
It's a lot of work.
https://youtu.be/V0pu9xV6ycI
_danimal_ is offline   Reply With Quote
Old 11-26-2016, 07:32 PM   #20870
has anyone ever put 1mm washers under the 4 corners of the rear pivot blocks?
twisted is offline   Reply With Quote
Old 11-26-2016, 08:34 PM   #20871
tc5 man's Avatar
Not in all 4 corners just the Front end it was on medium high traction and it was a ton of turn in to much made the Rear end come out on exit.
Losi SCTE 4x4, Tekno SC410 4X4 SC, Associated T4.1, Hitec 7954sh, mamba monster 2200kv, airtronics MX-3 X. Losi SCTE 4x4, Tekno SC410 4X4 SC, Associated T4.1, Mugen MBX6 ECO .
Hobby Hut offroad, Mushroom bowl offroad, Fun Center raceway.
GS HOBBY , Stormer Hobbies, Amain Hobbies, RRP Hobby .
Old 11-26-2016, 08:47 PM   #20872
so really all you did was change the anti squat. you could of done that with a pillow swap.
what iam thinking is lowering the cg and dog bone plunge.
Old 11-26-2016, 08:55 PM   #20873
tc5 man's Avatar
No I left the anti squad alone just tried out the 1mm spacers on the camber link on the shock tower.
I run the stock suspension blocks .
Cant say I had a issue with dog bone plunge lowering the cg a laydown transmission would do the most or a lower roof body .
Old 11-27-2016, 07:10 PM   #20874
Trader Rating: 41 (100%+)
I posted this on the b6 thread but didn't get a lot of response....any help here?
Hey guys, could use some advice here. I will be running on a carpet off road track but it's not ozite, it's a slightly looser nap home improvement store carpet. To further complicate the set up equation, we are required to run Primes or Smoothies. The track is on the smaller size...think 12-13 second laps. The overall message is that it is far lower traction than carpet with pins and staggers. The question: would I be better off to run a b6 or my old b5m (it's a championship edition so I have gullwing arms, 3 gear, a gear diff, etc) set up for carpet in this situation. Or would I even be able to tell a real difference in this situation? Thanks everyone!
rccars4scott is offline   Reply With Quote
Old 11-28-2016, 05:05 AM   #20875
Ed237's Avatar
The same wheels/tires will fit either car so I would get the right tires and run your b5. If your happy and/or competitive with it, keep it. If it is off the pace get to a b6.
Ed Toth
LCRC Raceway and Bumps & Jumps.
Ed237 is offline   Reply With Quote
Old 11-29-2016, 03:57 AM   #20876
ray_munday's Avatar
Hi Jordan,
If you are running on that kind of track, I recommend the std (heavy) chassis, brass c at least (makes a huge difference). If the layout is point and shoot and you need forward traction, 4 gear and brass D help. If its flowing, you generally only need brass C.
Any questions let me know.
Ray
Team Associated Factory Driver: B6/B6D, B64D, SC5M
JConcepts Factory Driver: Tyres, Rims, Wings, Bodies & Accessories
Reedy Factory Driver: Blackbox 510R ESC, Sonic 3 BL motors, Lipo
KO Propo EX-1 KIY_____www.keilorrc.com.au
Check out my help thread: http://www.rctech.net/forum/10587838-post1.html
ray_munday is offline   Reply With Quote
Old 11-29-2016, 06:13 AM   #20877
Mason's Avatar
Can't say I have but it should just raise the roll center. You would also need to keep an eye on drive shaft plunge.
Mason McCombs
NewRed Hobbies & Indoor Facility
Off-Road, Dirt Oval, Crawlers & Pullers
Mason is offline   Reply With Quote
Old 11-29-2016, 09:13 AM   #20878
Originally Posted by ray_munday View Post
Hi Jordan,
Ray
Thanks, I'll try the heavy chassis and brass C/D!
Old 12-02-2016, 08:04 PM   #20879
thecman26's Avatar
Trader Rating: 98 (100%+)
I would say just bradd c and aluminum d. Brass d can make it wash out in corners since the weight is too far rearward. Plus it'll save a couple $ for tires!
Chris Keen: Viola, Kansas
Kyosho RZ6, TLR 22 3.0, TLR 4.0 SR (soon),& 22T 3.0
"I'm too drunk to taste this chicken!", Col. Sanders
thecman26 is offline   Reply With Quote
Old 12-04-2016, 04:54 AM   #20880
eper's Avatar
Trader Rating: 14 (100%+)
Put on lead weights first and see if it's what you need before u spend mo eye on the brass parts
new milford ct,
WOLCOTT HOBBIES.. TEAM SCREAM..PRO-LINE RACING,,RC Truck Stop, and FTM grip
I CALL IT HOW I SEE IT!!!!!
eper is offline   Reply With Quote
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
