    Hide Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree6Likes
Old 11-20-2016, 12:24 PM   #20851
Check into the mono wheels, great deal and work great. I've had great luck with AKA impacts and PL holeshots on the rear and just ribs up front..
RcJunky76 is offline   Reply With Quote
Old 11-20-2016, 01:10 PM   #20852
Most definitely newcomer the Orion and Trinity in 5mm post pods. Just a soft rear tire something that doesn't like to load up.
Keith B is offline   Reply With Quote
Old 11-20-2016, 04:42 PM   #20853
thecman26's Avatar
Trader Rating: 98 (100%+)
Originally Posted by Oldracer1 View Post
Hello, just registered for rc tech. I bought a rc10 b5m with a hobby wing ESC and a speed passion 17.5r motor. Looking for some shorty packs. I was looking at the team Orion 4500 or 5000. Also I need to get some wheels and tires. Jconcepts wheels and tires for an outdoor track. I will be racing at lake part in Tampa. I think they are running a pin type of tire.
You should look into SMC or Fantom packs, Orions are way overpriced for the same performance. As for tires you should ask the locals what is a good tire to run. Pretty difficult to answer that online.
Chris Keen: Viola, Kansas
Kyosho RZ6, TLR 22 3.0, TLR 4.0 SR (soon),& 22T 3.0
"I'm too drunk to taste this chicken!", Col. Sanders
thecman26 is offline   Reply With Quote
Old 11-20-2016, 05:04 PM   #20854
jabroni racing's Avatar
Trader Rating: 36 (100%+)
Send a message via Yahoo to jabroni racing
I have to say i love these nano-tech batteries, Awesome price & i have 3, they run just as good as my trinity ones, almost half the price..
https://hobbyking.com/en_us/turnigy-...-approved.html
www.facebook.com/jay3638
jabroni racing is offline   Reply With Quote
Old 11-21-2016, 03:34 AM   #20855
eper's Avatar
Trader Rating: 14 (100%+)
Team scream batteries great prices great performance
new milford ct,
WOLCOTT HOBBIES.. TEAM SCREAM..PRO-LINE RACING,,RC Truck Stop, and FTM grip
I CALL IT HOW I SEE IT!!!!!
eper is offline   Reply With Quote
Old 11-21-2016, 09:35 AM   #20856
Hi there!
I asked a couple of days ago if the PL-body for the centro-conersion kit will fit the B5M: well, I did not get an answer so I ordered the body and tried myself:
... it does fit! okay, it does not fit exactly but it is quite okay, it is just the chassis part around the servo that is not perfect.
Now I have two more questions (I red almost 200 pages of this thread and did not find answers, so I apologize for not reading the hole thread first):
1: my shocks tend to leak; any recommendations on what o-rings I have to use?
2: which one to prefer?: screwed pistons (V2 shock shafts) or the the std ones (clipse)
thx for an answer!!
Lorangos is offline   Reply With Quote
Old 11-21-2016, 04:57 PM   #20857
I've had good luck with the Pro-Line Holeshots for the front and the Pro-Line Calibers for the rear, best to ask the locals what tires work best though
jl34 is offline   Reply With Quote
Old 11-21-2016, 06:02 PM   #20858
I would recommend associated x-rings. Since I installed x-rings in two cars none of them have leaked a drop. Good stuff.
The shafts with the screwed pistons are better, you can use machined pistons which are more precise, Not a deal breaker, the other shafts work fine. Your call.
francomang is offline   Reply With Quote
Old 11-22-2016, 06:05 AM   #20859
Mason's Avatar
Leaking occurs most likely due to old/swollen o-rings that have been torn up/split. Just get a shock rebuild kit (they are just the seal parts) and rebuild them slowly. Many people coat the o-rings with the green slime product offered by Associated. This helps keep them from swelling. So smash some of that on the o-rings before you put them in. You could go without the green slime and lube the o-rings with shock oil. This causes the swelling to begin with. It's naturally going to happen anyways. Lube the shaft before you send it through as well. Make sure you get the rest of the parts in there in the correct attitude and in the right order.
Beyond that, there could be a problem with the shaft itself. There's no fixing a shaft issue outside of replacing it.
Last but not least it may be possible but unlikely that the shock body itself has an issue at the seal end but that would take one heck of a massive hit to cause that. I have had somebody land on my shock causing the shock body to dent enough where it couldn't travel.
Mason McCombs
NewRed Hobbies & Indoor Facility
Off-Road, Dirt Oval, Crawlers & Pullers
Mason is offline   Reply With Quote
Old 11-23-2016, 10:21 AM   #20860
... I'm going to rebuild my shocks with new o-rings (x-rings)!
Thanks for your advice!
Olaf
Old 11-23-2016, 10:36 AM   #20861
Jmuck69's Avatar
Olaf
X-Rings are the best. spend a few more and get the machined internal spacers that were release for the B6. It's like butter.
https://www.amainhobbies.com/team-as...c91494/p507396
B6D | B64D
Schelle Racing Concepts - www.schelleracing.com
Amain Hobbies - www.amain.com
Jmuck69 is offline   Reply With Quote
Old 11-23-2016, 04:24 PM   #20862
ive decided to stick with my b5m for this season instead of getting a new car. i have a friend that was able to get me the wwhd tranny and the car is pretty good. im just looking for some unique items that may be out there to help even a little more. i like to be different. anyone know of anything?
twisted is offline   Reply With Quote
Old 11-23-2016, 07:37 PM   #20863
tc5 man's Avatar
What do you guys do for more turn in with this buggy i run 3 gear /mod motor on med traction to high clay ? I have tried to use 1mm spacers on the camber link on tower but it was to aggressive with it was higher grip anyways.
I been running mostly Dirtwebs, Typos on rear and Dirtwebs up Front . Ride height is 23mm/24mm rest is stock accept the slipper clutch .
Losi SCTE 4x4, Tekno SC410 4X4 SC, Associated T4.1, Hitec 7954sh, mamba monster 2200kv, airtronics MX-3 X. Losi SCTE 4x4, Tekno SC410 4X4 SC, Associated T4.1, Mugen MBX6 ECO .
Hobby Hut offroad, Mushroom bowl offroad, Fun Center raceway.
GS HOBBY , Stormer Hobbies, Amain Hobbies, RRP Hobby .
Old 11-23-2016, 07:45 PM   #20864
It's all in the inserts and the front hubs. Go way back somewhere near the beginning of this thread. Back when guys were just getting their cars. Out of the box the car is set up with mild, easy to drive and stable turn in (initial oversteer) I can't remember off hand which insert to change but your answer will be found there.
Alan_r is offline   Reply With Quote
Old 11-23-2016, 07:56 PM   #20865
tc5 man's Avatar
Ok thanks the stock setup was good on a faster more open layout but now its a technical track with tight turns .
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
