    Hide Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree9Likes
Old 10-17-2016, 06:01 AM   #20791
CrawJac's Avatar
Need servo recommendations.
Hello all, I am need to replace my servo and need some help with a good replacement. I am looking for something in the mid-level range that will hold up, but not break the bank. Any suggestions?
Blue Heron Racing homepage -> www.BlueHeronRC.com
Our track homepage -> www.PhilHurdRC.com
CrawJac is offline   Reply With Quote
Old 10-17-2016, 06:33 AM   #20792
awtwac's Avatar
Can't beat Savox 1258's for value. If you want to drop a bit more coin, Xpert 4k series servos come in around $80, cheaper with coupons or used. Good specs and mine have been bulletproof.
awtwac is offline   Reply With Quote
Old 10-17-2016, 07:00 AM   #20793
thecman26's Avatar
Trader Rating: 99 (100%+)
Protek 100SS = $50
Chris Keen: Viola, Kansas
Kyosho RZ6, TLR 22 3.0, TLR 4.0 SR (soon),& 22T 3.0
"I'm too drunk to taste this chicken!", Col. Sanders
thecman26 is offline   Reply With Quote
Old 10-17-2016, 07:45 AM   #20794
Originally Posted by tylem28 View Post
Does anyone have a recommendation / one they have used and works well? Also when doing so did you replace the servo horn or bearings? Anything else that should be replaced at the same time?
No one has replaced their bellcrank?
tylem28 is offline   Reply With Quote
Old 10-17-2016, 08:04 AM   #20795
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 156 (100%+)
Not necessary. You replaced the one on your b4 to eliminate the servo saver, the b5 rack already does that for you.
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 10-17-2016, 08:15 AM   #20796
Trader Rating: 17 (100%+)
I've run the stock steering on both my B5m and SC5m with zero breakage
Associated TC7.1
Associated B6 x2
Associated T5M
Tekno EB48SL
Scott R is offline   Reply With Quote
Old 10-17-2016, 08:48 AM   #20797
Trader Rating: 57 (98%+)
Thank you for the help! Forgive me ignorance but when setting up the shocks is their a tool you use to get the 1.6/37.5? How do you determine those numbers? I'm only a couple months into the hobby / sport and still learning. Also would moving my shock location on the shock tower help any? To make the car sit lower would I move that out? (further away from the inside of the car and moving to the outside?
As far as tires I have Electrons and also proline primes. These both seem to be the tires of choice for everyone and I see a mixture of both.
I do need some help with the DX4C controller as well. The stock settings are set at 100% steering L/F. With this I dont get full travel of the wheels. If I set it to Max (150%) then I get full travel. Do any of you run at 150% travel or just stick with 100%? Also what does the Expo do for steering or throttle? I haven't changed any of those settings. Also I typically run the drag brake a little bit (setting on the controller) so that the car slows down a little when letting off the throttle. Would I be better off leaving that at neutral?
As someone said above.. which to Schumacher carpet tires, your problem is solved and watch your lap times drop
AE TC7.1
AE B6D
Mugen Mbx7R Eco
jjreed is offline   Reply With Quote
Old 10-17-2016, 11:37 AM   #20798
sport10's Avatar
If your place allows them.
Hot Bodies VE8 w/ RX8-1900 combo
Losi XXX-SCT CRC conversion MMP/hacker 13.5
Associated B44
Associated B6
Durango DESC410V2 Pro
sport10 is offline   Reply With Quote
Old 10-18-2016, 12:51 AM   #20799
team orion vortex 1605
I wouldnt run a savox ever again, and certainly not a low profile servo in a buggy
the orion has been bullet proof, its fast, waterproof, strong and despite the best attempts of my lil girl..... its still working LOL
no idea what they cost in the USA, here they are 80GBP.
TonyCooperUK is offline   Reply With Quote
Old 10-18-2016, 06:54 PM   #20800
What would everyone recommend for rear axles / drivetrain for carpet?
Old 10-18-2016, 07:57 PM   #20801
sport10's Avatar
+1 on the Savox 1258.
Associated B44
Associated B6
Old 10-20-2016, 12:19 PM   #20802
Has anyone tried to mount Kyosho rb6 shocks on their b5 or b5m? The stroke is about the same, I'm wondering about the top and bottom mount holes?
TIA
MrLean is offline   Reply With Quote
Old 10-20-2016, 05:56 PM   #20803
That's interesting because Savox is the OEM for Team Orion servos.
Phantom56 is offline   Reply With Quote
Old 10-21-2016, 12:43 AM   #20804
Johnny-RC's Avatar
Trader Rating: 24 (100%+)
The irony is uncanny!
Products I run
| Hobbywing | Gens Ace | Highest Servos | Sanwa | Team Associated | AKA |
Johnny-RC is offline   Reply With Quote
Old 10-22-2016, 10:07 PM   #20805
need help troubleshooting a gear issue, I've stripped the idler gears twice, what would cause this? I replaced both idler gears and the gearbox (left and right side) and it happened again. thanks!
jl34 is offline   Reply With Quote
