    Hide Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree9Likes
Old 09-29-2016, 06:18 PM   #20746
Send a message via AIM to loosenut
Just recently finished building my b5m. Took it out for a run in front of my house and it ran great! The only thing I've noticed is that if I give it full throttle it'll tend to veer to the right. Not bad but enough so that I would have to think about it when I'm running it on the track. If I feather or ease into full throttle then it'll go straight. Also, when I break hard, it'll want to spin. Again, easing into my break with no problems.
What can I do to fix this? Does it have to do with my setup (tire camber)? Or should I just simply just adjust my transmitter (MT4) to dial down the throttle response (dual rate or even the exponential). I also can tweak my HW Xerun V3 ESC (punch and break control).
Just want to get folks thoughts on this before I tweak too many things. Thanks in advance!
Tekno SCT410//B44.x Avid Chasis//B5M//HW 3656 - 4700 kv// HW V10//MT-4
loosenut is offline   Reply With Quote
Old 09-29-2016, 06:24 PM   #20747
Cappy's Avatar
Trader Rating: 14 (100%+)
Id check to make sure your Diff is adjusted properly. Sounds to me like it may be a lil on the loose side.
Tekno EB48.3 RX8 Gen2 T8 1900 19T..
Tekno ET48.3 RX8 Gen 3 T8 2000
Tekno |Sweep | Dialed Inc | Boca Bearings | Mels Shells
SLOW THE F%&# DOWN so you can go fast !!!
Cappy is offline   Reply With Quote
Old 09-29-2016, 06:38 PM   #20748
Awesome! I will try adjusting the diff first! Thanks for the advise.
Old 09-29-2016, 07:09 PM   #20749
tc5 man's Avatar
Yup samething happen to me first time outdoors with the B5M .
Old 09-29-2016, 07:18 PM   #20750
Default Diff rebuild
Any opinions on the mip diff rebuild kit? Or would it be better to buy separate parts from other companies?
Not sure if it needs it all but it's a car I got and don't know the history so like to be prepared when I take it apart
Tbone17 is offline   Reply With Quote
Old 09-29-2016, 07:19 PM   #20751
tc5 man's Avatar
Braking on 2wd especially 4 gear mid motor your better off using ABS brake or just let off a little or stay at neutral and getting on throttle exit .
Old 09-29-2016, 07:21 PM   #20752
tc5 man's Avatar
It's my 2nd time using it not bad they upgraded the T-nut . They just put out a carbibe kit .
Good value and adjust tight enough they will last a decent time .
Old 09-29-2016, 07:55 PM   #20753
tc5 man's Avatar
I have some Rear tires mounted on some (Serpent SX6 2wd buggy) wheels pretty sure 12mm hexs on that buggy the middle of it is more of a deeper dish where the locknut goes what offset it would it be fully tighten down ?
Losi SCTE 4x4, Tekno SC410 4X4 SC, Associated T4.1, Hitec 7954sh, mamba monster 2200kv, airtronics MX-3 X. Losi SCTE 4x4, Tekno SC410 4X4 SC, Associated T4.1, Mugen MBX6 ECO .
Hobby Hut offroad, Mushroom bowl offroad, Fun Center raceway.
GS HOBBY , Stormer Hobbies, Amain Hobbies, RRP Hobby .
Old 09-30-2016, 10:42 AM   #20754
So I did tighten up the diff. I feel that it's pretty tight already - when i hold the rear tires and give it throttle, i hear a bit of slip and then my front end pops up about 2 inches.
So now full throttle from stop is dead straight! Thank you! But full break from from full throttle - the rear of the car still wants to kick it out left - slightly. Is this something that I just have to deal with or should I tighten the diff up even more?
Now I may just dial back the breaks a little with my controller and that may solve the problem! But I really want to tune the car so that it won't have any tendencies to swirl under hard break on high grip asphalt pavement because I would assume that on dirt the effect will be magnified. Thanks.
Old 09-30-2016, 10:45 AM   #20755
suzukipro's Avatar
Trader Rating: 21 (100%+)
dial back the brakes, tightening your diff won't help the brake issue.
Eric
________________________________________________________________________
Tekno, XRAY, Team Associated & Traxxas Powered by SMC.
Innovative Hobbies Raceway, Flyin-High RC Track
suzukipro is offline   Reply With Quote
Old 09-30-2016, 10:45 AM   #20756
tc5 man's Avatar
About the front wheels going up 2 inches you actually don't adjust it like a Rear motor you want the mid motor to pop up a little or one inch . I do it on the track actually adjusting the slipper and listening to the ball diff .
This is on dirt though .
Old 09-30-2016, 10:59 AM   #20757
Trader Rating: 17 (100%+)
stiffer front springs can help the braking issue too. The weight transfer takes weight off the rear wheels under braking. Stiffer springs can lessen that
Scott R is offline   Reply With Quote
Old 09-30-2016, 11:23 AM   #20758
Cappy's Avatar
Old 10-02-2016, 10:17 AM   #20759
Quick Diff question,
Tried searching and didn't come up with any results.
just ran my car in 17.5 for the first time. First heat race car was working well, with a couple minutes left my ball diff seemed to loosen off all on its own causing it to slip and I got a dnf.
Took it all apart checked everything to make sure it was good, swapped the t nut with a new one thinking that might be the issue. Got back out for the C main and was blowing everyone away when the exact same issue happened. Diff got loose all in its own and I couldn't finish the race.
What would cause the diff to back itself off? we run on ozite carpet with slicks. I ran the same car in mod last year with zero issues with the same diff
Slammed80 is offline   Reply With Quote
Old 10-02-2016, 10:36 AM   #20760
Maybe the thrust bearing? If it's not smooth it could be loosening the screw as the diff works
Currently Active Users Viewing This Thread: 4 (0 members and 4 guests)
