    Hide Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree6Likes
Old 09-23-2016, 08:46 PM   #20731
CCristo's Avatar
Trader Rating: 55 (100%+)
Originally Posted by Eddie_E View Post
Has anybody used the front end parts off the B6 in the B5M? I'd like to replace the front hubs and steering blocks, so I don't have to glue the bearing inserts next time.
Yes, they bolt right on
Chris Cristo
Pro-Line RacingHobbywingMIPBOOMrcFutabaPT RC Racing Oils
CCristo is offline   Reply With Quote
Old 09-24-2016, 03:51 AM   #20732
Krio's Avatar
Trader Rating: 150 (99%+)
However, the geometry is different and you will mess up your bump steering and ackerman angles. It isn't a suggested modification.
Someone could make different bolt on steering posts for the b6 hubs to mimic the ball stud location of a b5. There's a free aftermarket parts idea for anyone with a cnc mill.
www.kriostasis.com
Krio is offline   Reply With Quote
Old 09-25-2016, 11:45 AM   #20733
Default b4.x parts
hey just wondering if anyone has tried using any of the old b4.x parts for b5m ??? like front/rear hubs, knuckles, front/rear arms, diffs ?? im not to keen on using the old shocks as i like the big boar with alm caps with bleed screw....
thanks.
fliedlice is offline   Reply With Quote
Old 09-25-2016, 12:34 PM   #20734
does anyone know if the b6 wing mounts fit the b5m?
jl34 is offline   Reply With Quote
Old 09-25-2016, 07:36 PM   #20735
team green's Avatar
No they do not.
team green is offline   Reply With Quote
Old 09-25-2016, 08:14 PM   #20736
Does anyone know if the RPM front wide bumper will fit on a B5M? The 4 hole pattern looks the same. If not do they make a front wide bumper for the B5M?
http://www3.towerhobbies.com/cgi-bin...FZKMaQodIFcLiQ
tylem28 is offline   Reply With Quote
Old 09-25-2016, 09:48 PM   #20737
Originally Posted by team green View Post
No they do not.
thanks team green!
Old 09-25-2016, 09:51 PM   #20738
not sure on the rpm, this will fit if you are interested:
https://tboneracing.net/11147-tbr-ra...ciated-b5-mid/
Old 09-26-2016, 07:41 AM   #20739
sport10's Avatar
Or a way to retrofit the b6 steering section into to b5m would be cool
Hot Bodies VE8 w/ RX8-1900 combo
Losi XXX-SCT CRC conversion MMP/hacker 13.5
Associated B44
Associated B6
Durango DESC410V2 Pro
sport10 is offline   Reply With Quote
Old 09-26-2016, 09:49 AM   #20740
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 156 (100%+)
Completely different design. You guys want to but B6 parts on a B5m...buy the B6.
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 09-28-2016, 06:12 AM   #20741
AMitchell05's Avatar
I have a basic b5m chassis with the shapeways laydown. Is anyone using the shapeways with the factory lite chassis? From the pictures of the chassis I dont think it will work because of the holes that have to be drilled for the laydown and the locations of the chassis cutouts. I just dont want to spend $50 on a chassis to have to put my standup back in.
AMitchell05 is offline   Reply With Quote
Old 09-28-2016, 06:27 AM   #20742
I ran that gearbox in my FL chassis. Just didn't drill forward holes. You could always drill the holes and shim the difference if you felt like you needed to.
Team Associated / Reedy / JConcepts / BoomRC
boucher is offline   Reply With Quote
Old 09-28-2016, 04:47 PM   #20743
morris's Avatar
Trader Rating: 40 (100%+)
Default Mid motor stuff for b5m
Hey guys.was looking into putting a lay down setup on my b5m.
Don't know if I'm looking in the right places.but I can't find no info on the parts needed.could someone get me some help?i would really appreciate it.
AE/VIPER/XPERT/DIRTCHEAPRC.COM/JCONCEPTS
A big thx to all the tracks that I race at:cause if it wasnt for these guys..we wouldnt have a place to race our r/c cars!!!
morris is offline   Reply With Quote
Old 09-28-2016, 07:07 PM   #20744
Shapeways.com
And about using the shapeways laydown with factory lite chassis. I did it and drilled the holes. Didn't have any issues
Juicebox315 is offline   Reply With Quote
Old 09-29-2016, 12:14 PM   #20745
morris's Avatar
Originally Posted by Juicebox315 View Post
Shapeways.com
I have the standard B5m.not sure if the chassi is different.you have to drill new holes in the chassis?
I not know much info to do the swap
