    Hide Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree9Likes
Old 09-09-2016, 02:00 PM   #20686
Phillip F's Avatar
Trader Rating: 15 (100%+)
Originally Posted by Matt Trimmings View Post
Thanks. So what's the advantage to this in handling ? Is this only good for dirt tracks or clay high bite tracks?
Phillip F is offline   Reply With Quote
Old 09-09-2016, 02:49 PM   #20687
Trader Rating: 56 (100%+)
Originally Posted by JsK View Post
An off the shelf 89.00 one or a 200+ dollar hand built, shimmed , top 5% of the top 5% ? Big difference.
Is he running aluminum pucks? Cut gears? Slot car pinion? Right at 1500 grams? There is alot you can do and never get into charging beyond 2c.
No pucks according to him. Didn't ask the weight. The schuur speed is definitely a 100$ motor but I didn't think the difference would be so drastic. Maybe my TrakPower MS 17.5 really just sucks.
Ride1226 is offline   Reply With Quote
Old 09-09-2016, 04:40 PM   #20688
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 156 (100%+)
Its good for everything....it allows the chassis to flex properly. I have ran it outdoors / indoors, low traction / high traction.
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 09-09-2016, 07:56 PM   #20689
big james's Avatar
Trader Rating: 119 (100%+)
whats good starting point for gearing 10.5 motor stock spur on high byte clay track
AMAIN HOBBIES |Protek RC | AXIAL | TEAM TEKIN | Airtronics/Sanwa | Factory R/C | Kyosho Mini-z | PN Racing | Rite Eye Designz... Painting Vegas.....
big james is offline   Reply With Quote
Old 09-09-2016, 07:58 PM   #20690
thecman26's Avatar
Trader Rating: 99 (100%+)
Some guys will just comment rtfm.
I say the manual is a good start. 24/78
Chris Keen: Viola, Kansas
Kyosho RZ6, TLR 22 3.0, TLR 4.0 SR (soon),& 22T 3.0
"I'm too drunk to taste this chicken!", Col. Sanders
thecman26 is offline   Reply With Quote
Old 09-09-2016, 08:11 PM   #20691
big james's Avatar
thanks
Old 09-09-2016, 08:46 PM   #20692
thecman26's Avatar
thanks
Rock on, the manual does tend to be a bit conservative.
Old 09-17-2016, 09:33 PM   #20693
snaggy's Avatar
My Hitec servo is a super tight fit even with the spacers removed, anyone experience binding of the linkage? I am thinking of using a dremel to create a little room.
B5M Reedy SMC Hitec Coffee
Dirt Burners Livonia
SCX10 JKU
snaggy is offline   Reply With Quote
Old 09-17-2016, 10:13 PM   #20694
DHooter's Avatar
Trader Rating: 23 (100%+)
That's what I had to do when I added the alum steering rack.
Daniel Hooten
SEE YA IN THE FIRST TURN!
DHooter is offline   Reply With Quote
Old 09-18-2016, 10:22 AM   #20695
Considering a lay down from shapeways for my b5m FL. Before I do tho, curious how a b5m with a lay down stacks up against the new b6. Is the b6 noticeably better than the b5m? Or does a dialed in b5m with lay down contend well against the new car? Considering I run same power plant (17.5) setup in each chassis, does one out perform the other?
beansor2bacon is offline   Reply With Quote
Old 09-18-2016, 12:11 PM   #20696
Trader Rating: 29 (100%+)
My opinion is for 99% of racers it really doesn't matter.
DustinEich is offline   Reply With Quote
Old 09-18-2016, 12:35 PM   #20697
Phillip F's Avatar
I have both... B5M Lite and B6. The only advantage the B6 has is in the corners. Now, I run the B6 with laydown and gear diff and the XB2 carpet edition on clay med/high traction track. Both are fast in the corners and easy to drive. (when setup right to your driving style)
Old 09-19-2016, 03:46 PM   #20698
jabroni racing's Avatar
Trader Rating: 36 (100%+)
Send a message via Yahoo to jabroni racing
Anyone run a 4 gear & 3 gear transmission and can yu tell me the difference in feel??? All ive even know is AE 3 gear, last car was a b4, looking at a b5m & have option of either trans
www.facebook.com/jay3638
jabroni racing is offline   Reply With Quote
Old 09-19-2016, 11:43 PM   #20699
Hasi's Avatar
Hey guys,
I own a B5R myself and have to do a little maintenance to the shocks, but I'm a little bit confused.
I have not upgraded the shocks in any way, they're completely box stock.
Wanted to buy the #91615 and #91619 Shock Shafts (V2), TiN, but Asso states they're for the Kashima shocks and are not compatible with the E-clip shafts.
What does that mean? Is there any difference in the Kashima shocks except the coating to the stock shock bodies?
If #91615 und #91619 fit the stock bodies, do I need new pistons or what does the term 'These screw-mounted shafts are not compatible with our E-clip shafts.' mean?
Also I want to upgrade to the X-rings - does #91495 '12mm V2 X-Ring Rebuild Kit' fit the stock bodies?
I hope you guys can help me with this issue
Onroad: Tamiya TT-02, Tamiya TA-02SW, Xray T2'008
Offroad: Asso B5, Asso SC5M, Asso B64D, Tamiya Avante 2011 Re-Release
Trucks: Tamiya Mercedes SK 2638 6x6, Tamiya Mercedes 3553 8x4 heavy haulage
Hasi is offline   Reply With Quote
Old 09-20-2016, 01:03 AM   #20700
thecman26's Avatar
Originally Posted by Hasi View Post
Hey guys,
If I were you I would get the following to upgrade your stock shocks:
91495 X-Ring rebuild kit
91305 (X2) Ti_Nitride shock shafts Rear
91306 (X2) Ti_Nitride shock shafts Front
You're set!
