    Hide Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree6Likes
Old 08-22-2016, 08:53 AM   #20641
Trader Rating: 16 (100%+)
Originally Posted by Wildcat1971 View Post
I see 3 setup sheets on petit that show 2k for mod, and 1 setup sheet from Jeff Helms showing 5k in 17.5. So I would use that info for a starting point.
Thanks.
MX304 is offline   Reply With Quote
Old 08-22-2016, 10:05 AM   #20642
Phillip F's Avatar
Trader Rating: 15 (100%+)
So yesterday at the track was my first time running mod 7.5T in my B5Mlite. It handled pretty well in in the corners BUT in the jumps it bottomed out when I want to clear the triples. I was running a higher shock oil 2.5 higher than usual (when I used to have a 17.5T in it). Should I go thicker shock oil or even change a smaller hole pistons?
AND.. a big problem too is when I was bottoming out HARD...my differential gears went from smooth to super gritty. How do I avoid this? I never had this problem running stock.
Phillip F is offline   Reply With Quote
Old 08-22-2016, 07:13 PM   #20643
Originally Posted by MX304 View Post
For those running on high grip carpet, what's a good starting point for oil weight in a gear diff?
I race on high grip carpet in 17.5 blinky. I'm using 5k right now and it feels perfect. I haven't tried any other weight though. Haven't needed to
When temps get cooler I'll try 4k or 3k maybe.
To finish first, you must first finish.
B6
I get my rug burns at Northwest Hobbies.
_danimal_ is offline   Reply With Quote
Old 08-23-2016, 12:26 AM   #20644
Phillip F's Avatar
Update..
My local hobby shop thinks the diff problem I had was due to the fact that I used the wrong diff rebuild kit. I used the MIP rebuild kit for the b5M. The hobby shop said it was for the puck system. While I was rebuilding the diff I observed that one of the thrust washer was not flat unlike the stock one. Hopefully this is the culprit. I change the thrust washer to a flat one. ..so both sides now are flat. Will see once I run it at the track this weekend. Also had to change to a stiffer spring setup from green rears to white then from white front to grey.
Old 08-23-2016, 03:15 AM   #20645
czrlaker's Avatar
Trader Rating: 23 (100%+)
Originally Posted by Phillip F View Post
Update..
I installed the MIP ball diff rebuild kit in both my B5m's both came with one grooved and one flat washer for the thrust. Just FYI.
czrlaker is offline   Reply With Quote
Old 08-23-2016, 03:19 AM   #20646
Phillip F's Avatar
Were you running a mod motor?
Old 08-24-2016, 12:54 PM   #20647
BIGSKI15's Avatar
Trader Rating: 18 (100%+)
Putting in a gear diff in my sons car but when I took it out of his b5m team kit to put into my old b5m factory light I didn't pay attention to the orientation of the gear diff and can't find info about it. The supplement only shows how to build it.
Which way should the gear diff cap be positioned. Left or right if you were looking over the top of the car.
B6D
B5M
Airtronics M12
BIGSKI15 is offline   Reply With Quote
Old 08-24-2016, 01:29 PM   #20648
Super Moderator
Matt Trimmings's Avatar
Trader Rating: 156 (100%+)
just like a ball diff....doesn't matter
Thanks to: JConcepts ~ Schelle ~ Kustom RC Graphics
#MakeRCTechGreatAgain
Matt Trimmings is offline   Reply With Quote
Old 08-24-2016, 01:37 PM   #20649
BIGSKI15's Avatar
Thanks Matt
B6D
B5M
Airtronics M12
Old 08-24-2016, 02:05 PM   #20650
Phillip F's Avatar
Ball diff thrust bolt head usually face where the spur gear is.
Old 08-24-2016, 02:28 PM   #20651
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
Oh here we go again.
In my 25+ years of racing it didn't matter what side the diff thrust head bolt was on. The vehicles all performed as expected.
If you find a method that works for you, great! I don't plan on trying to convince you one way is better than the other.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 08-24-2016, 02:35 PM   #20652
3n90t's Avatar
From a mechanical point of view, either way works.
From a adjusting / service point of view, it's easier to adjust both diff and slipper from the same side.
AE: B5, B5M, B44.3, B6D, B64D
Tamiya: MF-01X Suzuki Jimny JB23
3n90t is offline   Reply With Quote
Old 08-24-2016, 02:42 PM   #20653
Super Moderator
Kraig's Avatar
Good point but my diff bolt is on the opposite side of the slipper because it is easier for me to access it and quickly adjust it. Something about not seeing as good as I used to when I was younger probably has something to do with it. I will go back to my cave now.
Old 08-24-2016, 03:22 PM   #20654
Wildcat1971's Avatar
Trader Rating: 80 (100%+)
I always face mine opposite of the spur. So I can use a different adjusting get wrench without less effort.
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
Old 08-28-2016, 04:18 PM   #20655
Butch Mann's Avatar
Trader Rating: 27 (100%+)
Default Low Pro Servo
I'm trying to run a Spektrum low profile servo S6070, in my B5M Lite but the steering link contacts the front of the servo and doesn't allow full travel with the stock servo arm. Do you run a longer servo arm or mill the servo case to clear?
Pit Stop Hobbies www.pitstophobbies.net
Bumps and Jumps RC www.bumpsandjumpsrc.com
Butch Mann is offline   Reply With Quote
