    Hide Wikipost
R/C Tech Forums Thread Wiki: Official Team Associated RC10 B5m Mid-Motor Thread
Last edit by: RCBuddha
Quick link to the front page
First Page
Print Wikipost
Like Tree6Likes
Old 08-19-2016, 06:03 AM   #20626
buckeye dan's Avatar
i just finished my first Yok tranny on my B5m .. I like the fit and finish of the tranny.. right now working on a template for my other b5m so it will go easier!!I think it will hold up better than shapeways seems 3d printed plastic not as durable. just my opinion no offense to anyone !!
Buckeye Dan
buckeye dan is offline   Reply With Quote
Old 08-19-2016, 07:24 AM   #20627
Any body have a CAD file of a B5M chassis they could share with me for a project?
Many thanks
Liam
londonaliam is offline   Reply With Quote
Old 08-19-2016, 05:02 PM   #20628
Recently picked up the MIP pucks kit #14230. It has the aluminum outdrives and shafts. Ive read a few places that the aluminum upgrade kit is "too light" and drastically changes the balance of the car, and decreases performance in some cases. Also, I noticed it is stated for best use with a 17.5 stock set up. Im currently running a 13.5 M3 with a reedy blackbox 800z. Has anyone had experience with the pucks upgrade running with a 13.5? Or experience with them in general? any tips would be appreciated. thanks!
beansor2bacon is offline   Reply With Quote
Old 08-19-2016, 11:12 PM   #20629
Super Moderator
Grizzbob's Avatar
Well, I haven't tried it with a 13.5, but I did try the system in mine for the first time last Sat. with a 17.5, & honestly, I couldn't tell any difference in car balance, felt just as good as the previous Sat. with the kit diff & universals. But I did confirm that the little orange pucks themselves do wear pretty quickly, mine are not ready to replace yet, but I did notice more wear than I would've expected from one race day. But aside from that I'm pretty pleased with it....
Bob Seay
Tamiya TRF417, TA05v.2, TRF211XM, M-05ver.2R, XRAY X12, Associated B5m Factory Lite
Go Pokes!!!
Grizzbob is offline   Reply With Quote
Old 08-20-2016, 02:35 AM   #20630
Nice! Glad you dig it. I suppose ill just keep a good eye on the pucks. Maybe the 13.5 with go through em a tad bit faster but i guess we'll see.
Old 08-20-2016, 07:50 AM   #20631
Finalist's Avatar
I'm running the ful Al system and added a 25gram brass d mount. The net weight gain was 6 grams with 25 gram brass d mount.
My pucks seemed to wear faster too. I was not planning on replacing them yet but I had to check my diff and while in there I noticed my orange pucks had more wear on them than I've ever had. I'm glad I caught it because at that rate they would have split on the next race day.
Finalist is offline   Reply With Quote
Old 08-20-2016, 08:14 AM   #20632
What is the size for the grub screw for the rear hub?
https://www.amainhobbies.com/team-as...c91549/p298952
SlashBash10 is offline   Reply With Quote
Old 08-20-2016, 09:04 AM   #20633
Dang, by the looks of it...pucks seems to be the exception to the upgrade. Im running aluminum c & d mounts. Ive got a decent setup running the stock components at the moment thats gotten me a few podiums, so Im a bit reluctant to swap anything. But am i missing out on performance that the pucks could deliver? I suppose I should install the pucks and report back.
Old 08-20-2016, 09:05 AM   #20634
looks like an m3 2mm set screw, don't quote me on that though.
Ready, fire, aim!
RC8.2e- 150a 2200kv HW + 1283sg
rcbuggies is offline   Reply With Quote
Old 08-20-2016, 09:19 PM   #20635
Phillip F's Avatar
Trader Rating: 15 (100%+)
So I'm putting a mod motor in my B5M lite (to try it out) since I have the B6 for stock racing. My B5M was pretty dialed to my driving style when I didn't have the B6 yet. My question is ... since I have all that power, should I stiffen the suspension a bit to compensate ?
Phillip F is offline   Reply With Quote
Old 08-20-2016, 09:20 PM   #20636
thecman26's Avatar
Trader Rating: 98 (100%+)
I sure would!
Chris Keen: Viola, Kansas
Kyosho RZ6, TLR 22 3.0, TLR 4.0 SR (soon),& 22T 3.0
"I'm too drunk to taste this chicken!", Col. Sanders
thecman26 is offline   Reply With Quote
Old 08-20-2016, 09:29 PM   #20637
Phillip F's Avatar
Originally Posted by thecman26 View Post
I sure would!
like how much? maybe keep the springs and piston setup and just go higher on the shock oil? or a bit more drastic?
I ran stock with rear(green springs, 2 hole-1.7 pistons, 27.5 oil) ; front (white springs, 2-hole 1.6 pistons, 30 oil)
Old 08-21-2016, 12:46 AM   #20638
thecman26's Avatar
I would start out with a lil thicker oil for starters.
Old 08-22-2016, 08:42 AM   #20639
Trader Rating: 16 (100%+)
For those running on high grip carpet, what's a good starting point for oil weight in a gear diff?
MX304 is offline   Reply With Quote
Old 08-22-2016, 08:50 AM   #20640
Wildcat1971's Avatar
Trader Rating: 80 (100%+)
I see 3 setup sheets on petit that show 2k for mod, and 1 setup sheet from Jeff Helms showing 5k in 17.5. So I would use that info for a starting point.
Support: Team Associated | Reedy Motors & ESC's | Sanwa Radios | Avid | Proline Tires
Wildcat1971 is offline   Reply With Quote
